value1
Microsoft Flight Simulator X / Lockheed Martin Prepar3D Plugin 2.0.2.0
SimTools plugin for Microsoft Flight Simulator X and Lockheed Martin Prepar3D
  1. simon884
    simon884 New Member
    france
    56Coins
    Hi all,
    Is anyone have an example of axis assignments for FSX on simtools v2.2.5 ?
  2. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I Uninstaller all fsx, simconnect x3, edit registry killed all of fsx, reinstall fsx gold, ran simconnect, installed aceleration pak, launched fsx and YES its transferring data, and working.
    Although when I powered up, one of the motors went 360 plus n killed the pot,
  3. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Hey guys,
    With the following setup:
    - Prepar3D V4
    - FSUIPC 5
    I get the attached error with Game Manager crashing.
    Any idea?
    Thanks!
    153,830Coins
    +11,151 / 57 / -2
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    yeap. simconect and FSUIPC isnt compatible with this version plugin. If you just put p3d within FSUIPC, it works.
  6. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
  7. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Hi @paulopsx2 and thanks for your reply !
    How do you mean to put P3D within FSUIPC?
    Thanks!
  8. Thanos
    Electronics Engineer
    2,907Coins
    He meant, without the FSUIPC...
    It uses only simconnect
  9. mastrohead
    mastrohead New Member
    italy
    210Coins
    Hi, Do you have find axis assignments for FSX?
  10. Leo Spierenburg
    Leo Spierenburg New Member
    - 12Coins
    We have Prepar3d v4.4 setup and have installed Simtools v2.2
    I have already removed FSUIPC and run the SimConnect installer as advised in https://www.xsimulator.net/community/faq/fsx-prepar3d-net-error.156/
    I have also installed the DirextX June 2010 as advised in another post, neither of these have helped.
    Upon launching game manage + game engine and prepar3d the error:
    "Unhandled exception has occured in your application. ..."
    "Could not load file or assembly 'Microsoft.FlightSimulator.Connect.Version=10.0.61259.0.Culture=neutral.PublicKey.Token=31bf3856ad364e35' or one of its dependenceies. The sytstem cannot find the file specified"
    Any help would be greatly appreciated.
  11. paulopsx2
    brasil
    647Coins
    first of all, you install ALL simconect rev on prepar3d folder (redist )?
  12. Simsalabim
    Simsalabim New Member
    3Coins
    What if you need FSUIPC for other interfacing (like instruments), can you still use it icw Simtools?
  13. Kashif Saeed
    Kashif Saeed New Member
    49Coins
    2DOF, 3DOF, 6DOF
    Hello there,
    i am facing the Microsoft .Net problem while running the FSX.
    i installed SimConnect sdk as well but problem still exist.
    Error picture is attached.
    Waiting for the kind reply.
    TIA
    153,830Coins
    +11,151 / 57 / -2
  15. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
  16. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    I don't have FSX installed, what directories do you have?
  17. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    @noorbeast
    i have following directories in FSX
  18. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    Have a look in the SDKfolder for SimConnect.msi
  19. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    thanks for the kind response @noorbeast
    Following files are available in the SDK folder and i opened SimConnect.msi but nothing happend.:(
  20. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    hey @noorbeast
    i have installed P3D and the same thing is happening into P3D as well.
    i follow the instructions for SimConnect and install them but the problem still exist.
    problem screenshot is attached in this post and i am getting the following text in exception
    System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.FlightSimulator.SimConnect, Version=10.0.61259.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    File name: 'Microsoft.FlightSimulator.SimConnect, Version=10.0.61259.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
    i am working on my 6-DOF flight simulator project. i need your help for this matter.:(
    TIA
