2 DOF SEAT building
Discussion in 'DIY Motion Simulator Projects' started by Joe Neto, May 21, 2018.
  1. Joe Neto
    Joe Neto Emmett Brown 2DOFuture
    System analist
    São Paulo
    192Coins
    [QUOTE = "noorbeast, post: 157976, member: 10786"] Você quer dizer que nada se move no Teste de Saída com um Perfil Padrão configurado para 20% para cada eixo / força?
    Em caso afirmativo, é provável que você retorne às etapas de configuração do código de [USER = 8138] @RacingMat [/ USER] e verifique se tudo está funcionando como esperado: https://www.xsimulator.net/community/marketplace/ arduino-code-2dof-and-2-pins-direction-hbridge-motomonster.67 /
    Ou, se isso for muito complicado, tente o código SMC3 e a ferramenta de ajuste visual de aplicativos: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/ [ /CITAR]
    Hiiiiiiiiiiii lol
    funciona !!!!
    Agora vou testar o LFS
    THANKS noorbeast,
    Thank you for your invaluable help.
  2. Joe Neto
    System analist
    São Paulo
    192Coins
    HI (again,again...) rss
    Eu estou confuso porque não muda em GAME MANAGER para GAME RUNNING.
    vai de "CONECTADO" para "FUNCIONANDO" e de volta para "CONECTADO"
    [MEDIA = youtube] Diwfz7jotrk [/ MEDIA]
    txs a lot. ah ! by your ratting
  3. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi guys
    first test on the track with LFS demo.
    how i said GAME MANAGER starting "CONNECTED" goes to "RUNNING" and back to "CONNECTED".
    then uninstalled LFS S2 and installed DEMO Version.
    This week i have no code to S2. only friday.
    if restart windows, i have uninstall LFS.
    tks.
    153,041Coins
    +11,116 / 56 / -2
    Great to see you got it moving, well done :thumbs
    While I can't see the game screen from the sounds it seems your Surge axis is reversed, it should tilt back under acceleration and tilt forward while braking. So reverse the DIR box settings in Axis Allocations to fix it.
  5. Joe Neto
    System analist
    São Paulo
    192Coins
    ok, noorbeast after this test i changed.
    its very cool. i'm so happy with results.
    but my problem is does restart the machine.
    GAME MANAGER will not to GAME RUNNING.
    only way is uninstall LFS and install again.
    Have you seen this problem before?
    again tks.
    153,041Coins
    +11,116 / 56 / -2
    It sounds like something may be blocking communication between LFS and SimTools.
    Do you have anti virus running and if so what is it? You could try temporarily disabling it.
    Have you run anything as admin while setting up?
  7. Joe Neto
    System analist
    São Paulo
    192Coins
    [QUOTE = "noorbeast, post: 158035, member: 10786"] Parece que algo pode estar bloqueando a comunicação entre o LFS e o SimTools.
    Você tem anti-vírus em execução e em caso afirmativo, o que é isso? Você pode tentar desativá-lo temporariamente.
    Você executou alguma coisa como administrador durante a configuração? [/ QUOTE]
    yes, running all as admin
    no anti-virus instaled
    txs
    153,041Coins
    +11,116 / 56 / -2
    You should not need to have run anything as admin. That may have created a privileges issue.
  9. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi all
    when I tested the first moves, they were not smooth so I had a problem:
    the weld on the shaft had only 4 stitches and they broke.
    the seat then moved about 20 degrees to the right and left.
    this ended up giving me an idea for a Traction loss.
    This above weld broke
    so I had an idea for TL
    if the motor is attached to the shaft it can move
    both for roll and pitch without other mechanisms like wheels ....
    like the picture below
    the troublle:
    I have an arduino nano and a Monstermotor only one output working, another interface with RacingMat code will work for an EXTRA1?
    txs to all.
    153,041Coins
    +11,116 / 56 / -2
    If the pivot for your additional motor is the shaft under the seat then what you would be implementing is yaw not traction loss, as the latter has the pivot point near your feet while the pivot point is centralized for yaw.
  11. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi noorbeast
    ah!
    I'm thinking that roll + yaw gives me a feel maybe TL ...
    I thought I could apply the 3 forces to the shaft and the feel would be like TL
    but had not understood the point of displacement thank you for clarifying
    and MM only one channel
    you see problems ?
    hug:
    153,041Coins
    +11,116 / 56 / -2
  13. Joe Neto
    System analist
    São Paulo
    192Coins
    Hello to all !
    Finally driiiiiiviiiiiinnnnggg !!!!!
    hug: to all
  14. Edaurdo
    Edaurdo Member
    Buenos Aires, Argentina
    190Coins
    Hello @Joe Neto !
    I'm hesitating, if i go to build a simulator like yours or build a compact design (Both motors under the seat).
    Have you tried your simulator with the game NoLimits2? It feels good?
  15. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi, Eduardo i'm use LFS the configuration is good to LFS.
    I'm feeling all DOF's . ( very strong)
    No testing another game still
    i have no money to buy licence
    The my country is broken
    would like me move to ALASKA with the bears. ( rsrsrsr)
    hug:
  16. noorbeast
    153,041Coins
    +11,116 / 56 / -2
    • Optimistic Optimistic x 1
  17. Joe Neto
    System analist
    São Paulo
    192Coins
  18. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi noorbeast,
    I'm very happy get licence... yes yes yes:grin (Already registered now)
    i have a question, with DIY licence i have access to the game plugins ?:sos
    I would like fs9 or fsx plugins and I did not understand how ...
    hug:
    153,041Coins
    +11,116 / 56 / -2
    You use your forum activity coins here to buy a weeks access to as many plugins as you want: https://www.xsimulator.net/community/shop/
    As you are a bit short I have donated some coins so you can go and get whatever plugins you want, have fun.
  20. Joe Neto
    System analist
    São Paulo
    192Coins
    LOL :grin:grin:grin:grin
    Thank you ! thanks ! rrsrsss
    you are a great dude !!
    hug:of bear from Alaska...
