6 DOF from scratch
  1. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    That spring thing is quite nice and simple to set-up. Thanks a lot. I will use it, it's almost sure.
  2. haribole
    haribole New Member
    North Carolina, USA
    211Coins
    Hello Pierre
    Thanks so much for sharing your build.
    Wondering about the Sabertooth DC Motor controller, since the max current draw of the motor is only 17A , do you still need the dual 60A controller? Can a 2X32A not be used?
  3. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Probably, but reading on this forum, I found out that there is a lot of peaks that goes beyond that calculated 17A. I have no experience to back up my saying, but it comes from experienced builder. The changes of directions on the actuator may draw more current for a short period of time, and if many actuators change at the same time, it can go pretty high. I have read that some power supply were tripping from it, and other build have relay up to 70 Amp per motors (so I bought too). I also read that some people found 2x60 more stable than 2x32. But again, I have no experiences to backing up my big mouth.
    So, since I hate taking chances, I decided to invest right away on the high end. It may be overkill, but it's also peace of mind.
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,797Coins
    Its got more to do with voltage,
    U=IxR
    a 720watt 12 volt motor ask 60 amp current, and a 720 watt 24 volt motor ask 30 amp
  5. RandomCoder
    Control Engineer
    1,674Coins
    The issue is as @Pierre Lalancette described, the back emf which a motor can induce will potentially destroy electronics. This back emf is induced because the inductance of the motor coils opposes change. With our desire to frequently change motor direction, this can subject the electronics to very high current spikes on a regular basis.
    Here is a snippet taken from this site https://opentextbc.ca/physicstestbook2/chapter/back-emf/ .....
    Consider, for example, the motor coils represented in [link]. The coils have a 0.4ohm equivalent resistance and are driven by a 48.0 V emf. Shortly after being turned on, they draw a current I=V/R = (48V)/(0.4ohm)=120A and, thus, dissipate P=I^2 R =5.76kW of energy as heat transfer. Under normal operating conditions for this motor, suppose the back emf is 40.0 V. Then at operating speed, the total voltage across the coils is 8.0 V (48.0 V minus the 40.0 V back emf), and the current drawn is I=V/R =(8V)/0.4ohm)=20A. Under normal load, then, the power dissipated is P=IV =(20A)/(8V)=160W. The latter will not cause a problem for this motor, whereas the former 5.76 kW would burn out the coils if sustained.
    The equation here is over simplified but hopefully you get the idea.
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    I have new parts! They are the end parts of the actuator where to screw the joint. They are nice, they fit right in and my build cost went up 100$. As far as I know, they worth every penny.
    Also, I finally got back to designing the potentiometer support with the added limit switch. Why was it so long. I was scared I could not do it, and for a reason. It is quite complicated (well, it was for me).
    My first time using support for bridge structure. Quite intriguing.
    Scary to remove, but not that hard.
    But of course, I made it too tight and nothing fits.
    Even with some cut away, I could not make it fit. It has to be redone. I was quite discouraged.
    At least, the switch part was working, even if it needed a bit more clearance for the connectors.
    So, it was back to the drawing virtual table. I was sure I had to start it all over, but no. I could make the adjustments and add some strength to it (so i think). I is printing right now. I'll see in a few hours if I am still discouraged. :)
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Wow! Am I happy?
    I was able to get it right the second time around (if you don't count all the tests I did for each individual parts). It is tight, but it fits.
    As usual, I put the walk of shame beside the finished product. But I should say the path of experience.
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    The top part. Still needs some adjustment here and there, but I am getting good at it.
    Now I need to design the middle part, to replace my puck... That I still thing is a great idea... But I've been recommended to change... Social pressure...
    If I keep on doing one part every weekend, I may finish this by 2010. Wait! What's the year?
    • Funny Funny x 2
  9. Flymen
    Montreal, Canada
    2,433Coins
    DC motor, 6DOF
    hey, i see you again working on the project again!!
    The power supply are on the way for me !!
  10. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Yeah, me too, I'm waiting for parts on the power supply. Someone working on repairing boats told me he gets old, but working batteries that he has to pay to get rid of. I hope he can get me two deep charging 12 Volt batteries.
    During that time, I only miss the middle design off my actuator. But it will be hot this weekend. It sounds like a water park day. I may miss a design deadline task because of that. But it's so fun. :)
  11. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    One of my middle part of my Actuator is printing...
    But since it was not good enough today to go to the water park, we wondered around town today. Look what I found in a pawn shop, waiting all that time for me.
    I am a lucky son of a beautiful mother.
    152,361Coins
    +11,075 / 56 / -2
    Sounds like it was meant to be ;)
  13. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    152,361Coins
    +11,075 / 56 / -2
  15. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Thanks Noorbeast, This is probably how I find it back, after many wondering around the site.
    I cut my cabon tube. I'm better at it and I know how to do it more straight. Warning, I read somewhere that carbon tube powder is highly dangerous. Don't breath it.
    It fitted perfectly into my part. But this is when I found out I was way off in my measurements. Not enough support, the part will need to be longer. Redesign, again.
    Still, I made the setup so I could make it moves. Windows made me wait more than 3 hours for an update. :confused:
    My v-weel attachement are way of, they need a better design too.
    Using the attaches for the strap cracked my part. Redesign.
    For the bottom part, the limit switch is on the wrong side. Will have to redesign.
    The top part is on the right side, but how it is hold in place need to be more compact. It was already called for a correction in the design.
    Here it is in action. There is a lot of vibration, but the carbon tube is way to long and it attached poorly. But, I could see it in action. The weight is unknown. The motor is driven by a simple computer power supply at 12 Volts. The final will be drive at 24 Volt. It did not break a sweat.
    • Optimistic Optimistic x 1
  16. noorbeast
    152,361Coins
    +11,075 / 56 / -2
    I really appreciate your calm matter of fact approach...oh well just another redesign!
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    I have not done much on my build this week, due to incredible weather outside, but...
    Last week, I have redone the design of the ball screw part of the actuator and printed it. But my Solidedge desing was warning me about something, but I could not any problem. I decided to print anyway. Result: a sudden jump in the print.
    But it appended only once. I decide to break it and fix it for test. I know what went wrong and I can correct the design later.
    I had bought rod and nuts, since no screw were long enough for my piece. The springs are for the limit switches and the bearing ball for a test. I also bought the 3 helm joints that I will need later... much later...
    It worked. You can see were I will use the spring with a rod to activate the limit switch. How I will use nails to attach the strap in the middle and pass it over other nails and tie everything up with tie-wraps. The v-wheel works great now against the carbon tubes. They are much stronger than the old model.
    Installed to test. Worked great, even though nothing is fixed permanently.
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Christmass, Christmass, Christmass!
    I totally forgot to put the auto focus on my camera, but, you get the picture. (Ha! Ha! Pun intended!)
    Got 2 new carbon tube because I was not sure to do all 6 500mm actuators with only 4 1m tubes.
    What could be in those boxes?
    My 5 other Ingus bearing (ouch$$$) and a grey pla roll with a orange pla roll. Reading other thread, I would have probably tested eSun PETG. But at the same time, I had next to no trouble with my amz3d pla so far. If it's not broken, don't fix it.
    I put the auto-focus back on my camera. ;)
  19. Thanos
    Electronics Engineer
    2,861Coins
    If the G27 steering wheel is not working well, remember you can reuse them!!
  20. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    LOL! What is that little steering wheel?
    So far, with the right driver, it's working really fine.
