Question Ricmotech RS1 to 2dof seat mover with traction loss
Discussion in 'DIY Motion Simulator Projects' started by Stephen Robotham, Mar 12, 2018.
  1. Zeraxx
    Zeraxx Member
    188Coins
    Looks good bud, hopefully the license comes through before to long. Your setup is exactly as mine (except I'm going for under the seat mounting vs back of the seat). Do you by chance have a wiring diagram for your build? I'm doing the exact same thing where I have 1 motor for each MM.
    153,818Coins
    +11,150 / 57 / -2
  3. Zeraxx
    Zeraxx Member
    188Coins
    Yeah I saw the post, but it only has the diagram for the MM wired for two motors for one MM. I did see further down in the post where it shows a wiring diagram for 1 MM/1Motor to the Arudino. and then a wiring description for multi motors, but the text says, "If you want to connect 3 MM please wire described as follows:" so I wasn't sure if it was applicable for 2 MM.
  4. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Here is the wiring diagram for this setup.
    and for the additional motors:
    Arduino -------- Monster Moto
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 3
    6 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    7 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    11 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    The outputs:
    A1 and B1 will have the SAME polarity
    A2 and B2 will have the SAME polarity, too.
  5. Zeraxx
    Zeraxx Member
    188Coins
    Thanks bud that was what I was thinking, I'm assuming your just omitting the 3d monster (pins 6,7,11) on the arudino?
  6. Stephen Robotham
    jamaica
    130Coins
    Yeah correct, i'm not doing the traction loss motor just yet. That will be the next phase of the build.
  7. Zeraxx
    Zeraxx Member
    188Coins
    Perfect, thank you for the info!
  8. Stephen Robotham
    jamaica
    130Coins
    All wired up and ready to go.
  9. Stephen Robotham
    jamaica
    130Coins
    Trying to test the motors with the smc3 utility, but I cannot get them to move. Everthing powers up. the utility connects to the adruino, but no movement.
    I also went ahead and bought the pro version of simtools because its been 1 week since I applied for my diy license and still no response, so I got fed up of just waiting without hearing anything.
  10. Zeraxx
    Zeraxx Member
    188Coins
    Did you test out the MM and measure the outputs before hooking up the motors directly? I know some users have had issues with MM quality.
  11. Stephen Robotham
    jamaica
    130Coins
    Nope, unfortunately I didn't do that because I didntt have a meter available to use.
  12. Zeraxx
    Zeraxx Member
    188Coins
    If you can try to buy an inexpensive one, I got mine from a local hardware store for about $20. It's going to be hard to do any type of troubleshooting without one. It'll also help you troubleshoot further. I know for my setup (did sodering last night for my 2 MM) I had issues with my MM and then when investigating I realized I had a broke lane on my PCB for the MM. Having a meter lets you determine if you have shorts or breaks in addition to what your outputs are going to be.
  13. noorbeast
    153,818Coins
    +11,150 / 57 / -2
    Clone MMs can often be faulty, here are various approaches to testing them: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    With respect to issuing DIY licenses you were advised by email on the 28/6/18 that disruptions have been caused when Xsimulator.net was recently moved to a new server, and that you would be notified by email when that was resolved. It is unfortunate but @RaceRay has been traveling, so we await his return, he is aware of the issue. Please keep in mind that members contribute their time and expertise to maintain Xsimulator.net, create plugins and assist others...sometimes members just have to be a little patient. That said in my view the Pro version of SimTools is well worth it, particularly for the additional integrated functionality like Game Vibe.
  14. Stephen Robotham
    jamaica
    130Coins
    In the smc3 utility, it syas off beside each motor. Is it supposed to say that?
  15. Stephen Robotham
    jamaica
    130Coins
    Step #4 in the setup process says to edit file for mode being used:
    1. Download the SMC3 software attached to this post (SMC3.ino)
    2. Get the Arduino IDE tools installed on your computer if you don't already have them. Follow the Arduino Getting Started guide found here: http://arduino.cc/en/Guide/Windows (Note the step for installing the drivers!)
    3. Open the SMC3.ino with the Arduino IDE
    4. Edit the code at the top if the file to select the MODE you will be using
    5. Compile and Download the SMC3.ino program to your Arduino UNO R3
    How do I do that? I open it in adruino program but dont know what to change, or is it okay as is?
  16. Stephen Robotham
    jamaica
    130Coins
    Power supplies are feeling pretty hot even though the motors haven't moved. Is that normal?
  17. Stephen Robotham
    jamaica
    130Coins
    Couldn't be bothered with these unreliable monster moto, so ordered 1 of these.
  18. Stephen Robotham
    jamaica
    130Coins
    OKay, I got the motors moving, but now I cant figure out how to use the smc3 utilities software. Do I need to configure that before I go to simtools?
    153,818Coins
    +11,150 / 57 / -2
  20. Stephen Robotham
    jamaica
    130Coins
    Thanks for that, I will be going through it in depth, but 1 of the motors has stopped responding and I suspect its the monster moto, so i'm just gonna wait on the sabertooth to arrive and then dive back into it.
