Question Ricmotech RS1 to 2dof seat mover with traction loss
Discussion in 'DIY Motion Simulator Projects' started by Stephen Robotham, Mar 12, 2018.
  1. noorbeast
    152,361Coins
    +11,075 / 56 / -2
    The Sabertooth is a good choice, they are pretty well bulletproof.
  2. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Okay guys sabertooth 2x60 and genuine adruino have arrived. The quality of both are much better.
  3. Stephen Robotham
    jamaica
    130Coins
    Just if anyone is curious. Heres a pic of the genuine adruino beside a clone. Genuine is on the top.
  4. Stephen Robotham
    jamaica
    130Coins
    I need help. I uploaded the smc3 code for the sabertooth and used the smc3 utiliy and everything works great, but when I go to Simtools game engine and try and test output, nothing happens. What am I missing? Here are screenshots of my settings.
    152,361Coins
    +11,075 / 56 / -2
    With SimTools 2 setup in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this [A<Axis1a>][B<Axis2a>]
  6. Stephen Robotham
    jamaica
    130Coins
    Thanks, its working now, but the power supplies keep shutting off after awhile. Gonna try and change some settings and see if I can figure it out.
    152,361Coins
    +11,075 / 56 / -2
  8. Stephen Robotham
    jamaica
    130Coins
    Im not sure what causes it, it happens in the smc3 utility when I turn on motion. It works great for awhile and then stops. When I check whats wrong, the power supplies are off and I have to cycle the power off and on to get them working again. I am gonna try creating a game profile and see if it still does it, thanks.
    152,361Coins
    +11,075 / 56 / -2
  10. Stephen Robotham
    jamaica
    130Coins
  11. Stephen Robotham
    jamaica
    130Coins
    Ok, so I used the calculator and it has given me the following recommendations:
    1: 0.8 Ohms dissipates 180 Watts at 15 Amps
    2: 1 Ohms dissipates 144 Watts at 12 Amps
    Does this sound correct for the pgsaw motors, because the problem I am having now is that locally the biggest resistors are 25 watt, so I would have to by a bunch of them and series them. Where do you guys get resistors?
  12. Stephen Robotham
    jamaica
    130Coins
    I am getting some resistors, but how do I wire to the 2x60 because the pic shown is the 2x32 and where the wires go from the resistor isn't on the 2x60.
  13. Stephen Robotham
    jamaica
    130Coins
    Please help, I don't know how to wire the resistors to the 2x60
    152,361Coins
    +11,075 / 56 / -2
    I didn't realise you were using 2x60, I had presumed a 32, you will need to use a battery to dissipate the regenerative current, as the 60 does not have the same features as the 32.
  15. Stephen Robotham
    jamaica
    130Coins
    Turns out the power supplies were just overheating and shutting down until they cooled down a bit. I put a fan on them and no more problems with that. The only issue i'm having now is sometimes when not in game and the seat is empty the motors vibrate like crazy and to stop them, I just need to apply some pressure to them as though someone was seated. They will then gradually slow down and stop and I can them release the pressure. I'm guessing its something in the smc3 utility, but I don't know what. Other than that, it's working great, just need to spend some time fine tuning my profiles now.
  16. Stephen Robotham
    jamaica
    130Coins
    I'm trying to patch dirt rally so that I can tune the motion profile, but I cant find the directory that it needs. No matter where I direct the game manager to, it says not the correct location. I'm running a steam version, can anyone help?
    152,361Coins
    +11,075 / 56 / -2
    For Codemaster games the patch path is different for 32 and 64bit versions of Windows: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
  18. noorbeast
    152,361Coins
    +11,075 / 56 / -2
    Be mindful the 2x60 has no regenerative current control, as far as I am aware you need a battery so it has somewhere to go.
    Just use the button on the top left of Game Manager to easily turn motion off when not seated on the rig and back on again when you are ready to go.
  19. Stephen Robotham
    jamaica
    130Coins
    Simulator is fully operational and wow it is awesome. Thanks so much for all your assistance. I will try and answer any questions as best as I can to hopefully help someone else to achieve this goal of having a motion sim. Here is a short video of a friend of mine using it with assetto corsa.
    https://photos.app.goo.gl/6kHkazPzEaCGu5NT8
    Up next is a wind simulator.
  20. Stephen Robotham
    jamaica
    130Coins
    Hey guys, sim is working great so far. Had a few little issues but nothing major, but I still can't get dirt working. I cannot find a save game file anywhere, any suggestions or ideas as to where the heck it could be? i have the steam version.
