  1. steiniani
    steiniani New Member
    32Coins
    Perfect. Thanks @noorbeast . I typically lurk in the shadows and read, but will definitely start a thread if necessary.
  2. Bashar Abu Muaileq
    Bashar Abu Muaileq New Member
    Gaza Strib
    28Coins
    Hello
    I'm Mechatronics Engineer
    My Final Year Project :- 2 DOF car simulator but I dealt with www.x-sim.de and now after graduate I hope want work in this field .
    I found out that you are more sophisticated than x-sim.de team
    so I would like to join you .
    How do I learn to use your program and I want to do a car simulator
    without the Internet and easy to use as product Is this possible ?
    What are the things that are required of me ?
    Regards
    Bashar
    153,728Coins
    Welcome @Bashar Abu Muaileq.
    SimTools only requires a net connection once, for license registration, it can then run offline.
    You will find plenty to get you started in the FAQs: http://www.xsimulator.net/community/faq/
    Including a section on SimTools: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    And various code for different hardware: https://www.xsimulator.net/community/faq/arduino.6/category
    I would suggest you try the SMC3 code, as that has a handy application for doing configuration settings: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    When you are ready please start your own project thread here and post details about your simulator on it, including your video and any questions you may have: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  4. Marc Lindgren
    Marc Lindgren New Member
    R & D
    Pennsylvania
    70Coins
    Hello everyone,
    Thanks for the wealth of information to be had here on this site. I've been reading through the many pages of @Nick Moxley's build thread and I hope to follow his lead as far as design is concerned. I like his approach.
    My current rig is stationary and was something I diy'd for use with Iracing, Project Cars 2 and Assetto Corsa. (really looking forward to AC Competizione). I use an Oculus so the need for triple monitor mounts will be put off initially. I have yet to order any parts since I'm still reading up on things here but I definitely have the itch and I can't wait to get started. Knew I'd find a good use for those server psu's, lol
    For anyone who hasn't already seen it, here is the build that I will base mine on:
    https://www.xsimulator.net/community/threads/2dof-to-3dof-diy-seat-mover.5271/
    Once I have the coins to do so, I will download the simtools software and begin trying to wrap my head around everything involved in setting that up, ugh. Hopefully the learning curve isn't too steep.
    Guess it's time to get reading.
    Thanks again for this great site,
    Marc
    I'm adding links here for my own reference later ( hope it's okay)
    https://www.xsimulator.net/community/faq/traction-loss.174/
    https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
    153,728Coins
    Welcome @Marc Lindgren.
    I look forward to hearing more about your project plans.
    If you are seeking build, hardware and software information to get you started, then look in the FAQs: http://www.xsimulator.net/community/faq/
    We have a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Good luck with your project.
  6. Denus304
    Denus304 Member
    600Coins
    Hi there guys i have just joined , i got a link from an iracing forum to join and search the forum in some much needed help.
    I am currently seaking the best way to create my own motion simulator. i will have a look around and get some ideas then post a forum thread if it is ok ?
    153,728Coins
    Welcome @Denus304.
    Have a look at existing member builds, that may help you refine your own project ideas: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, JRKs, Arduino code and motor drivers, plus heaps more: http://www.xsimulator.net/community/faq/
    Feel free to ask questions on your build thread, the members here give freely of both their time and expertise.
  8. pinthi
    pinthi Member Gold Contributor
    - 119Coins
    bonjour à tout les nouveaux membres SimTools et le forum
  9. Genius Wizard
    Genius Wizard New Member
    100Coins
    2DOF, DC motor, Arduino, 4DOF
    I'm also glad I found this community. I always dreamt about having a simulator on my own. I couldnt afford one. Now I can full fill my dream. will soon upload details about my diy project. cheers!!
    153,728Coins
    Welcome @pinthi and @Genius Wizard.
    You have come to the right place, there is a really active community here who freely give of their time and expertise.
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, JRKs, Arduinos and Motor Monsters and more: http://www.xsimulator.net/community/faq/
    @pinthi you can dual language post but must include English, as per the forum rules, using Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
    I look forward to following both of your projects.
  11. Genius Wizard
    100Coins
    I'm already working on a project. and also started a thread. will upload photos and details asap. and realy thanks for the inspiration.
  12. Leadf00t
    Leadf00t New Member
    184Coins
    4DOF
    Greetings from Australia!
    I've recently taken possession of a ProSimu T1000 5 dof which is being a bit of a princess.
    Rear actuators cut out after a few minutes of play. The manufacturer is being less than helpful so any gurus that could help me out would be more than appreciated
    Sorry if this isn't where I should be asking
  13. sam poole
    sam poole Active Member
    midlands
    31Coins
    Are you using simtools?
  14. Leadf00t
    Leadf00t New Member
    184Coins
    4DOF
    Yes. Using sim tools with the iracing and assetto corsa plug-ins
  15. sam poole
    midlands
    31Coins
    Just a thought maybe they are going beyond safe limits and causing cut out think they need to be set around 90 percent in game profile other than that have no idea never used actuators
  16. Leadf00t
    Leadf00t New Member
    184Coins
    4DOF
    They’re set to 65 and still doing it.
    153,728Coins
    Welcome @Leadf00t.
    Start a thread in the Commercial section and add a bit more detail about the circumstances, like is it triggered by a crash or it is the PSU going into protection mode, or something else: https://www.xsimulator.net/community/forums/commercial-simulators-and-peripherie.52/
  18. Jimmy Dean
    Jimmy Dean New Member
    Charlotte, NC
    7Coins
    Hello all. I am looking to ease my way into racing immersion. I am going to start with GameVibe/Transducer project this September. With the ultimate goal to build a 3DOF rig. But I have to attain many skills to reach that goal :).
    Thanks, and looking forward to learning and interacting with the community. :)
    153,728Coins
    Welcome @Jimmy Dean.
    A bit of planning is time well spent, and the community here can help you out as you formulate your ideas about what your Game Vibe and potential motion projects.
    You will find plenty to get you started in the FAQs, including a section on Transducers and Game Vibe: http://www.xsimulator.net/community/faq/
    Feel free to ask questions, the members here give freely of both their time and expertise.
    Good luck with your projects.
  20. Carl Flemister
    Carl Flemister New Member
    236Coins
    My name is Carl and I am a long time video game/sim racer and have a small bit of real life track time. I live around Chicago, IL. With a HUGE amount of help from @nickmoxley I built my first racing rig last year ... I am now looking to upgrade it to a seat mover with traction loss. I look forward to talking with (and hopefully racing with) those that have been down this path already!
