Want to make 3 axis simulator for fly games.
Discussion in 'DIY Motion Simulator Projects' started by grooste_lwd, Nov 23, 2015.
  1. Everh
    Everh New Member Gold Contributor
    Yonkers NY
    134Coins
    Hello, someone has the correct arduino code for this image. I'm new to this. And I'm looking for it like crazy and I can not find it.
  2. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    123Coins
    That's the painting I use for my simulators. This the code to use. Works easy.
    If you have trouble first time.
    - check arduino USB cable! (makes sometimes errors. Bay a good one!)
    - upload SMC3 arduino code to arduino. // check top rule! // IBT-Bridge is mode 2 // #define MODE2
    - repower arduino
    - EXTRACKT SMC3UTILS.zip
    - Edit the file: ===>>> SMC3Utils.ini
    # SMC3Utils.ini
    UDP_PORT=20017
    COMM_PORT=3 //<<<<=///////////Here your comport of your arduino. Check arduino software.
    IMG_PATH=c:\temp
    - Run SMC3Utils v1.01.exe. It must work!
    No need to connect the motors. First check your pots is moving lines. Make your self at home with the progam.
    Check all your axis! hours after hours. Makes sure arduino connection to pots is 100% good.
    - If its the way you like? Connect your motor. Motor go complete wrong way? Our out direct to max one way? Most common error of my. + / - on motors must be changed!
    I hoop it helps you!
  3. grooste_lwd
    123Coins
    Motion sim almost raddy.
    • Like Like x 5
  4. grooste_lwd
    123Coins
    All most ready.
  5. grooste_lwd
    123Coins
    Running Life for speed. no load. Surge, Sway, Yaw! :) Me so happy :)
  6. grooste_lwd
    123Coins
    Life for speed + vorpx + osvr hdk + xsimulator
  7. grooste_lwd
    123Coins
    Simulator seems to work perect. Even on 1 diet. And without balance weights. And 3 motors. Simulator works! But I can only play life for speed. I have activated xsimulator. Plugins installed successfully. If I re-install, there will be min and max settings override. But project cars is not in the list. xsmulator does nothing with it.
    151,479Coins
    +11,041 / 56 / -2
  9. grooste_lwd
    123Coins
  10. grooste_lwd
    123Coins
    My small girl racing VR :) Life for Speed,
    151,479Coins
    +11,041 / 56 / -2
    You should not need to use admin privileges, as that can possibly mess up file access.
    What version of Windows are you using, as XP is no longer supported?
  12. grooste_lwd
    123Coins
    Win7 64bit, a good s new PC. I think I do something wrong. Virus scanner = down, :( ,,, Racing Life for speed! :).
  13. noorbeast
    151,479Coins
    +11,041 / 56 / -2
    It sounds like you have a anti-virus false positive, SimTools has been submitted to some of the common ant-virus vendors: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    Game Manager has the abilities to scan a games memory space so we can get the telemetry from games that don't supply any.
    Therefore you may get a false positive with some anti-viruses.
    To fix this problem, just add it to the exceptions list for your antivirus.
    (windows defender example)
    https://support.microsoft.com/en-us...dd-an-exclusion-to-windows-defender-antivirus
  14. grooste_lwd
    123Coins
  15. grooste_lwd
    123Coins
    Problems fixed, running project cars! a friend of my fixed it. I had 2 simtools installed. 1 very old 2016. All plugin renewed. And works!
  16. grooste_lwd
    123Coins
    Project cars :)
  17. grooste_lwd
    123Coins
    Try xpand rally, fails, no pop up :(.
  18. grooste_lwd
    123Coins
    Have made a new smc controller.
  19. grooste_lwd
    123Coins
    I have completed my simulator. And raced with dirt rally. Want to show this. I drive Pike Usa.
  20. grooste_lwd
    123Coins
    Where do I find bigger motors with same rpm specs as my wiper motor. Just bigger. higher amps?
