Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. yobuddy
    51,561Coins
    I'm not sure what the force feedback effects would do for GameVibe to tell you the truth.
    We already have the telemetry the FFB effects are created from I believe.
    Yes, both front speakers would simply come thru the front speaker and same for the backs. I would set the max volume for Chassis for 50%, since there will be to sounds coming thru the one speaker.
    Take care,
  2. riton
    riton Active Member
    1,006Coins
    I feel a lot more the glide of the tires in my DD wheel than in GameVibe, that's why I ask the question on how to feel the tires in GameVibe.
    as I feel the information in the steering wheel, I tell myself that it could be interesting with GameVibe
    ok thanks ;) I will continue my tests
  3. tanruoqiao
    tanruoqiao New Member
    - 54Coins
    Help needed! THANKS.
    I use Gamevibe without any bug until yesterday.
    I'm using latest simtools , pcars2 plugin and gamevibe.
    Yesterday I do a little fine tune in vibe creater and saved. Than when I start game again,gamevibe would automatically close.
    After so I tried start gamevibe when at a race, still automatically close.
    But if I close pcars2 , gamevibe would run normally. If I turn off game manager, with pcars2 running, gamevibe still run. Once I turn on game manager, gamevibe would crush.
    I reinstalled gamevibe , still not working.
    Is anybody has any idea about this phenomenon? Thanks a lot.
    153,986Coins
    +11,162 / 57 / -2
    Do you get an actual error message and if so can you please post it.
  5. tanruoqiao
    - 54Coins
    Sorry it just shut down silently.
    The first time I find , gamevibe icon just disappeared.
    If game manager is off. When I turn it on, gamevibe would be no respond for 5 seconds than disappeare without any message.
  6. tanruoqiao
    - 54Coins
    Finally after I uninstall gamevibe with profile removed, reinstall ,it worked.
    Maybe it is because my vibe creator profile is some kind of buggy.
    Thanks for your support.hug:
  7. ilia K
    ilia K New Member
    183Coins
    Hi,I need some advice. I am going to use 8 buttkicker mini LFE with GameVibe.What Power Amplifier do you advise me to use.
  8. yobuddy
    51,561Coins
  9. ilia K
    ilia K New Member
    183Coins
    Thanks,I would like to clarify one point,concerning Behringer power amplifiers.I would like to connect 8 mini LFEs to the one amplifire,rather than to several ones. I mean Behringer iNUKE amp model line.
  10. yobuddy
    51,561Coins
    Do they have a 8 channel amplifier?
    If so, cool!
    If not, it may be easiest to put both amplifiers into a single case to make it look like one amp.
    Take care,
  11. ilia K
    ilia K New Member
    183Coins
  12. yobuddy
    51,561Coins
    So you want to do a 2 channel setup with 4 kickers per channel?
    if so, you may as well just run 2 kickers I think.
    Take care,
  13. ilia K
    ilia K New Member
    183Coins
  14. andreas62
    andreas62 New Member
    17Coins
    I use Simvibe for the time being and Simtools for the movement. Now I would like to do both with simtools. I may need help via Team viewer. Can someone help me?
    153,986Coins
    +11,162 / 57 / -2
  16. andreas62
    17Coins
    OK Thank You @ noorbeast
  17. TR1PL3D
    TR1PL3D New Member
    234Coins
    3DOF, Motion platform
    Hi guys, I have been trying to get Assetto Corsa to play ball with Game Vibe. Game Engine is working fine, I get fully working motion with my platform.
    But no matter what I try, I cannot get any vibes to go to my buttkickers when using AC.
    Audio is working just fine as I am able to test with the vibe creator.
    It seems I am missing something obvious! Help please.
    My currernt config
  18. greatg67
    greatg67 Member Gold Contributor
    509Coins
    153,986Coins
    +11,162 / 57 / -2
  20. yobuddy
    51,561Coins
    @TR1PL3D,
    Please set the Min Vol (Sound Card Settings) to '0' unless you really need it like that?
    What do your Hi/Low values look like for the game?
    Also, you RPM is muted.
    Chat soon,
