value1
Raceroom Racing Experience Plugin 2.1.0.0
SimTools game plugin for Raceroom Racing Experience
  1. Ahmad Said
    Ahmad Said New Member Gold Contributor
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    I got it to work somehow. fiddled with the limits a little made it behave. When capturing max/min in Tuning Center, I got the Values to be 15/-15. But this has less effect when driving, had to really put an effort to bottom out the TL. I end up using 2/-2 for extra1, this makes the driving experience super sensitive, which I very much like. I am using 3 x scn5 btw. Cheers
  2. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    all other effect are 20% ?
    roll 20%
    pitch 20%
    heave20%
    yaw 20%
    sway 20%
    surge 20%
    100% max per axe
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    This is how I do it (see picture) Roll and pitch are both 10 each btw.
  4. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    if it can help
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    Thank You,
    I ended up using this
    roll 20%
    pitch 20%
    heave10%
    sway 30%
    surge 20%
    extra1 100%
    exta1 Filter:
    Not sure about the washout as I think I need to play with it more. But overall now I like it. I am using VR and it is really difficult to tune TL while in VR
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    This is I think the setup I like after a few hours of experimenting with extra1 filter (below). Hope this can also help others like me out there with similar setup as mine
  7. yobuddy
    51,534Coins
    @Ahmad Said,
    Those washout settings look good buddy!
    Thx for the post.
    Take care,
  8. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    very happy for you if you find good setup !
  9. RacingRichie
    RacingRichie Prosimu T1000 3DOF
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
    yeah I still have that issue as well. so did they say anything about it since then? Can you post the link to the sector3 forum here, so maybe we can chime in as well? :)
  10. RacingRichie
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
  11. RacingRichie
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
  12. RacingRichie
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
  13. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello everyone...
    I realized that I have a movement problem when I drive in RaceRoom with my ProSimu T1000 3DOF (and in all other driving sims too).
    The movements of the front left and right SCN actuators are correct, while the rear SCN actuator (dedicated to the traction loss) are wrong, because when the car slides with the rear to his left, the actuator instead of pushing the station to the left moves to the right.
    The same thing happens when the car slides with the rear to his right, the SCN actuator instead of pushing the station to the right moves to the left.
    So the movements are reversed...!
    What should I do to solve this problem?
  14. RacingRichie
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
    invert the axis in the game engine
  15. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Thx for response but... since we have the same 3DOF, you could explain to me how to do it? I'm not very prepared on this... sorry.
    In my ProSimu T1000 3DOF the Axis are configured in this way:
    - Axis 1a... for the right front SCN actuator
    - Axis 2a... for the left front SCN actuator
    - Axis 3a... for the rear SCN actuator (for traction lost movement)
    how should I proceed to invert the axis?
    If necessary I can publish my SimTools Game Engine configuration screens...
  16. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    The Dir box being checked orange or not in Axis Assignments determines which way an axis moves, so make it the reverse to what it currently is on Axis 3a.
  17. yobuddy
    51,534Coins
    The problem is the error is mixed into surge, so it would be very hard to isolate.
    my guess is the problem is in there game's math somewhere.
  18. value1
    14,239Coins
    The values out of R3E are passed through the plugin without modification. So I guess it is due to the data we get from R3E:
    Code:
    Roll_MemMap = r3e_shared.car_orientation.roll * RadToDeg 'Roll
    Pitch_MemMap = -r3e_shared.car_orientation.pitch * RadToDeg 'Pitch
    Yaw_MemMap = -r3e_shared.car_orientation.yaw * RadToDeg ' yaw
    Surge_MemMap = -r3e_shared.local_acceleration.z 'Surge
    Sway_MemMap = -r3e_shared.local_acceleration.x 'Sway
    Heave_MemMap = r3e_shared.local_acceleration.y 'Heave
    So I think there's not a lot one can do wrong:think
  19. value1
    14,239Coins
  20. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Thank you so much value1... :thumbs
