SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. noorbeast
    152,355Coins
    +11,075 / 56 / -2
    Plugin download page summaries lists if there is Game Vibe support.
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Thank you very much!!!
    I tried to find a way to summarize the plugin page based on Game Vibe support but I did not find the way.
    Did I miss something? o_O
    Thanks again!!!
    152,355Coins
    +11,075 / 56 / -2
    There is no filter as such that I am aware of. Perhaps @RaceRay could have a look at what that functionality would take to implement.
    But you can use the Custom Google Search box toward the top right of the Recent forum page to find plugins with Game Vibe support.
  4. ilbiga
    Network Engineer
    103Coins
    Thanks!!! As you suggested, I talked about the idea to @RaceRay .
    In the meantime I'm looking "manually" between plugins. Unfortunately, at the moment the Dirt3 plugin does not support Game Vibe :(.
    Dirt 3 is an old game, but I love it because it works very well with my simple 2DOF! :D
    Ciao! :thumbs
  5. ilbiga
    Network Engineer
    103Coins
    Ciao.
    Sorry for the question. A damn virus has damaged my system. :mad:
    I'm trying to restore everything, but when I start Game Vibe I get this error:
    I tried to reinstall the Microsoft .NET frameweork, but I can not fix it. :(
    Any suggestions? :confused:
    152,355Coins
    +11,075 / 56 / -2
    Make sure .net 3.5 is installed: https://www.xsimulator.net/community/threads/simtools-v2-game-vibe.11359/page-7#post-155042
    And reinstall DirectX: https://www.microsoft.com/en-nz/download/details.aspx?id=8109
  7. ilbiga
    Network Engineer
    103Coins
    Thank you @noorbeast ! I have resolved the issue!
    The problem was directx. I do not know why, but reinstalling it from scratch everything started to work again! :cool:
    Thanks again. :cheers
    Game Vibe really adds something more :thumbs
  8. ilbiga
    Network Engineer
    103Coins
    Greetings again @yobuddy .
    This could be a stipulating question, but I need a clarification.
    Using the Game Vibe in "3D mode" and configuring the 4 channels [FR+FL & RR+RL], the positioning of the speakers must follow the same pattern, or the pattern must reflect the configuration of Game Vibe, ie [FRONT+REAR & RIGHT+LEFT]?
    These are two schemes to better explain the doubt:
    Thanks to you and to all the people on the forum that support our projects! :thumbs
  9. yobuddy
    51,099Coins
    Use a setup like in the first pic you posted.
    It just makes more sense as that is how the cars wheels are sitting.
    Take care,
  10. ilbiga
    Network Engineer
    103Coins
    Thanks @yobuddy!!! :thumbs
    I was misled by these flags:
  11. yobuddy
    51,099Coins
    That flips the direction of the 3d output is all buddy.
    should you hit a wall head on and the sound comes from the back, this will fix it.
    Take care,
  12. ilbiga
    Network Engineer
    103Coins
    Ok, now it's clear to me. In fact it is a function that can be useful.
    Thank you @yobuddy ! :thumbs
  13. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Hi all
    Quick question is it possible to get the info from an existing plugin to then add Game Vibe ?
    Goes without saying if it’s possible all credit would go to original plugin dev.
    Regards
    Dag
  14. yobuddy
    51,099Coins
  15. greatg67
    greatg67 Member Gold Contributor
    509Coins
    So, my pc video and sound are going via HDMI to my stereo receiver and when playing VR the sound is output into my headset. Am I correct in assuming that the buttkicker would also need to be connected to the receiver and GameVibe would need to be set up as video card audio in order to get things to work correctly?
  16. noorbeast
    152,355Coins
    +11,075 / 56 / -2
    You should have a separate sound card for Game Vibe: https://www.xsimulator.net/community/threads/gamevibe-manual.11358/
  17. deemjackson
    deemjackson New Member
    cambridge
    99Coins
    anyone have any idea why my soundcard isnt listed in the set up settings? its working fine with sim vibe sim commander...
  18. deemjackson
    cambridge
    99Coins
    scrap that its working how. all the set up seems to be fine and working well, but theres no response in game (assetto 2.0.7). GV tuning center shows output, but no vibration. :( when i ,easure min max values they arent effected.
  19. yobuddy
    51,099Coins
    @deemjackson,
    Maybe open a thread on your GameVibe problem buddy.
    Post some screen shots of your setup for GameVibe and we maybe able to help you with the configuration.
    Take care,
  20. deemjackson
    cambridge
    99Coins
    thanks, ive sorted it now - i thought i was running the latest version simtools but it turned out i wasnt!
