Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Gadget999
    12,132Coins
    10000 pulses is a lot of resolution and will have the processor working hard for no real gain
    i suggest you go for 360 - 1000 pulses
  2. evolaco
    evolaco Member
    Spain
    694Coins
    More charge to the cpu? I have an i7 6700k, there will be no problem, I just got the problem of knowing every cable that is and if connecting only A + and B + will work
  3. evolaco
    evolaco Member
    Spain
    694Coins
    In the end I will put 4 ibt2, I prefer to play it safe, use the two outputs of the buffer to feed 2 ibt2 each? or better to use two buffer?
    I have passed this photo of a 10000ppr mige encoder, I have not found anything for the reference, I still do not know if I can use that encoder, in the end I will have to buy the Chinese 2500ppr encoder ... IMG-20180819-WA0002.jpg
  4. Gadget999
    12,132Coins
    Try the encoder and see what happens, it may be fine
  5. evolaco
    evolaco Member
    Spain
    694Coins
    but not knowing what each cable is as I can locate encouragement and A B? These encoders have a + a- b + b- u v w ... nothing has been found even all the colors for
  6. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    He didn't thinking of the load for your pc. It could be critical for a Arduino, but I think there should be no problem with the mmos. Actually, the +/- connections is probably RS485 signals, but as you already mentioned, it should work to connect one of the side. Good thing though, is that you have the inverse on the -, so if you have problem to get the index signal to work, just take the other polarity.
  7. evolaco
    evolaco Member
    Spain
    694Coins
    How can I tell if that encoder needs a pullout resistor?
    connecting the encoder to the Discovery is there any test in mmos to see that the encoder works?
  8. danove_b
    Sweden
    1,782Coins
    If it is RS485 you don't need any pullups. Just power up the encoder and measure the outputs. If you get pulsing voltage when you turn it, you don't need it. If you feed the encoder with more than 3.3 V, than you need voltage dividers on the signals because the MMOS signal levels is 3.3 V.
  9. evolaco
    evolaco Member
    Spain
    694Coins
    Alexey put in his 12V scheme to power the encoder, should it be 3.3v? From mmos directly or came the power supply? mine has output of 3.3v. The encoder 10000ppr is not if it is rs485, I read that rs485 is not compatible with the drive ionic, I think that should confirm that it is not. If I feed the encoder, do the outputs turn on voltage directly as a potentiometer? measuring from gnd to the output?
  10. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    The Encoder should have a voltage regulator but to be safe connect the VCC of the encoder to 5v.
    This is why whenever you buy electronics, make sure there is a datasheet available!
    Yes, you should be able to feed all 4 of the IBT with the one buffer, if not buy a second buffer. Probably just easier to buy two buffers as they are cheap.
    To test your encoder connect as shown in the diagram to the STM32F board, use a+ and b+ channels on that encoder.
    Program the board with MMos.
    Start the MMos utility and ensure connection.
    Download Live for speed (small download, fast to load)
    In live for speed select MMos FFB as the input device.
    At the top of the screen will be a bar graph that will show wheel position. turn the steering wheel.
    If the encoder is wired correctly then you will see colour fill up the bar in the direction you are turning the wheel.
    If the direction is incorrect close LFS and click on the reverse encoder input. (NOTE: the motor may spin the wrong way, change the polarity of the motor OR re wire the encoder a/b channel and un-tick the reverse encoder option).
    The encoders u/v/w channels are used for communications so don't use them.
    The STM32F doesnt mind having 5v into the encoder channels, If you have concerns however connect the pullup resistors to the 3.3V output from the STM32F board.
  11. evolaco
    evolaco Member
    Spain
    694Coins
    Can I do the test in the game without a motor? Simply the encoder connected to the discovery and turn it by hand, I suppose so.
    Here is a picture of the connection of an OSW, the encoder goes to the STM32 without resistors and connected to 5V, to the STM32 goes the 0v to the GND and A +, B +, Z + to the ABC channels, the Z is not necessary according to you told me.
    To the stm32 it is necessary to connect the GND of the power supply? Or is not it necessary? When encoder I carry GND from the power supply to 0V
    Following that scheme should go well.
    I also found the colors of the encoder, in theory they should be the same as in the encoder I want to buy.
  12. evolaco
    evolaco Member
    Spain
    694Coins
  13. Carlo_Labati
    Carlo_Labati New Member
    italy
    213Coins
    any info's about switch from DC eletric motor to Outrunner Motor ?
  14. evolaco
    evolaco Member
    Spain
    694Coins
    We started badly ... the stm32 discovery does not do anything when connecting the usb, it does not turn on any led and windows does not do anything either, as if it had not connected anything
  15. Alexey
    Adelaide, Australia
    8,066Coins
    Sorry I forgot to mention, you need both usb cables plugged in to the STM32F and the computer
  16. evolaco
    evolaco Member
    Spain
    694Coins
    I connect both cables and I do not receive any sign of life from the stm32, I will try another cable to see if it is defective
    It was the cable, I tried another and it works fine, so I always have to have the two cables connected? I'll have to buy another 2-meter mini usb
    @Alexey Could I feed the stm32 directly with the 5v of the power supply? So I would only use the micro-usb, is this possible?
  17. Czary
    Czary New Member
    electrician
    Poland
    352Coins
    DC motor, AC motor, Arduino
    Hello, thank you very much guys for sharing this project. I've been following this one for some time now.
    As stated earlier the BTN7971 H-Bridge (Imax=70A) is reported to work better than IBT-2 bridges. Is it possible to connect 2 BTN7971 in parallel connection as seen on Alexey's diagram ?
  18. evolaco
    evolaco Member
    Spain
    694Coins
    Why is it better than ibt2?
  19. evolaco
    evolaco Member
    Spain
    694Coins
    @danove_b mmos gets in mode h-bridge right? what khz is better ny1020? If it makes a little noise I do not care because I go with oculus and I do not listen to the outside
    I have already run the 10000ppr encoder, I can run in assetto moving it haha, now I have to try the motor and the ibt2
  20. Carlo_Labati
    italy
    213Coins
    yes
