AMC1280USB Motion Simulator Controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Jul 6, 2017.
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    This should explain better what is the issue here:
    The video starts with the old version of the plugin and ends with the new one.
    Same settings in both examples with heave effect desactivated.
    We should see the platform banking a bit up to simulate the axial accel and to the right to simulate the centifuge force while performing the turn.
    This works well with the old version.
    The problem with the old version is that the heave axis is not properly centered.
    Best
  2. Thanos
    Electronics Engineer
    2,907Coins
    The video is not available. .
  3. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    My fault ... sorry. You should read them by now
  4. value1
    14,242Coins
    I see. Thanks for the video explanation. It's clear now. Lemme check the maths in the plugin.
  5. Pit
    30,510Coins
    @Thanos I am rebuilding my simulation platform and would like to add the AMC1280 especially for the Sabertooths. I found a video on youtube which is still up to date?
    Mx AMC1280 is updated to version 3.0.
    Thank you.
  6. Pit
    30,510Coins
    Checked it, it is quite the same.
  7. SeatTime
    Finally got around to getting a copy of Hexpod. Seems to have some nice features with adjustable roll center, DOF mixing etc, but had me scratching my head with version 1.7 as it would not connect to the 1280 o_O. Tried V1.4 and it works fine...Hopefully it may save some other members hair :).
  8. Thanos
    2,907Coins
    Thanks for letting me know. I'll verify the bug with the v1.7, I have been using v1.8 for a while now, i skip to latest version sometimes to compile from source, since I have access to the development. I dont personally test the released one from HexPod team. I work on the shared map memory part, and on the comm module to improve the datalink. Perhaps v1.7 uses the new data ID for v3.0 firmware? But still, the recognition commands are same and should work regardless
    Tomorrow first thing is to short this out.
    Thanos
  9. RandomCoder
    Control Engineer
    1,674Coins
    Try not to blow anything up :grin
  10. SeatTime
    1.7 would not connect to either the old, or new (3.0) firmware - I run an old and new 1280.
  11. Thanos
    2,907Coins
    Hexpod 1.7 needs the new ID format (FF FF) to work.
    I verified it works, even with multiple interfaces connected (wish I could choose which one to connect to):
    If you are still using old firmware before v3.0, it wont work...
    See info to upgrade it here:
    http://motionsim.blogspot.com/2018/08/amc1280usb-firmware-v30-release.html
    Thanos
  12. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    As it might be confusing I am adding here a link to the heXpod package including old ID and new ID versions.
    You will find also the last AMC1280USB firmwares corresponding to the respective version.
    https://www.dropbox.com/s/k1y60d7fzdu4277/heXpod_old_new.zip?dl=0
    recommended AMC1280USB firmware for heXpod with old ID is the 2.4 rev.3
    recommended AMC1280USB firmware for heXpod with new ID is the 3.0 rev.2a
    Please report bugs if any
  13. SeatTime
    Thanks. Is it OK to load this new firmware onto older 1280's?
  14. Thanos
    2,907Coins
    Yes, it will work the same. Just any 12bit outputs setting will not work, as the hardware is not present on older Amc1280usb. The rest hardware remains compatible.
  15. SeatTime
    Well... that was a bit of a disaster :eek:. Just need to find the right image to roll back to - Thank God for limit switches ..
  16. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    I have gren thanos board 6dof all work nice in firewall 2.1c and last day am instal new update 3.0 and now have problem with one sew inverter B.all time light STOP. next two inverter work corect .i see in display change all time numbers and motor moving .only one inventer still light Stop and motor not move.
    PS: after back update to 2.0 all work correct. 3.0 not work for my.I will by fear to update to new versions.!!!
  17. SeatTime
    Yep, I've gone back to 2.1C, and everything is back to normal, but got a real fright as my sim tried to push through my ceiling (6DOF card driving Sabertooth DC motors)- limit switches saved the day.
  18. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    I presume you are talking about the 3.0 rev.2a. Right?
    I've also had issues on the 3.0 rev.1c.
    In my setup, when the new "FF FF" ID and "ser feedback off" is checked, I have no problem.
  19. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I was able to update to 2.0 and try update to 2.1c(connector fail ) why? thanks
  20. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Value1,
    Thank you for your efforts with the third version of the plugin.
    Here is the result:
    For testing, I would recommend to use manual values in the "tunung center" as the new "roll over" feature can work only when 180 value is set for pitch and roll positions.
    This is the simtools matrix where I am mapping the forces for the heXpod Add-On:
    As you can see, I am mapping all 3 rotational and 3 translational accelerations and only 2 positions.
    I am skipping the use of yaw position (magnetic orientation of the aircraft) as the yaw acceleration which retuns to the center seems to be enough for a good realism.
    In the DOF2 column I am mixing the pitch and roll positions with pitch and roll accelerations and in the DOF3 column I am adding sway effect to roll axis and surge effect to pitch axis in order to simulate a sustained acceleration feeling. - pretty simple.
    In the video example, the aircraft is making a slow 360 turn at a constant speed which means we should have a constant value for surge acceleration and also a constant value for sway acceleration (centrifuge force) as you can see them on the telemetry output.
    In this plugin version I see a strange relation between the sway and surge acceleration and the position of the aircraft. The runway is more or less oriented north/south and the plugin's values instead of being stable, strangely tilts the platform when the aircraft is facing east an west and retuns to 0 when the orientation is north/South.
    The ground behaviour of the aircraft (taking off, landing, taxiing) is a crucial part of flight simulation. Only to say how important is to get it right. I hope my explanations will help you finding a correct way to output the x-plane telemetry.
    Best - heXpod
