Showroom DIY 3dof Dbox Style Rig with 4 x 750 Watt Linear Actuators 100 mm
Discussion in 'DIY Motion Simulator Projects' started by Ringorumble, May 10, 2018.
  1. fsutton
    fsutton Member
    323Coins
    Looking good!
  2. fsutton
    fsutton Member
    323Coins
  3. GEEDOGG
    GEEDOGG New Member
    Locomotive Engineer
    279Coins
    You would need 4 220v lines correct?
  4. GEEDOGG
    GEEDOGG New Member
    Locomotive Engineer
    279Coins
    I'm still trying to find the hollow shaft I also need the linear bearing with the correct dimensions in the U.S. Smalltec and Dold don't ship to U.S. I've found 30mm x 45mm x 64mm linear bearings but not 30mm x 47mm x 68mm if anyone finds them post links here thanks.
  5. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    The spindle has a 16mm diameter, so i imagine it's pretty thight Frank.
  6. Thanos
    Electronics Engineer
    2,854Coins
    All I'm saying, is that these power converters from 110v to 220v they don't pass though the ground. Your 220v line should have 3 wires, L N and Ground, but in US its usually the 220v is 2phases combined = L1, L2 and N instead of ground.
    The N (neutral line) is not the same as ground, its not the local ground but the remote ground from the power factory that they use for reference!!! It may still have some different in impedance to the real local ground (Local distribution).
    Maybe this will help to understand it visually:
  7. fsutton
    fsutton Member
    323Coins
    Thanks HoiHman. The company on h
    Got it, thanks!
  8. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    @HoiHman who you think about print with nylon ? thanks
  9. fsutton
    fsutton Member
    323Coins
    Anyone in the US having any luck finding alternative sources for parts?
  10. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Just a quick test of all 4 actuators running alongside simtools and simcommander
    I have not made any tweaks or adjustment yet, since i have really looked at all the available setting yet. The servos are now running at 1200rpm max, they can go up to 3000rpm max
    Initial thoughts: I can probably ditch simvibe and it's operation is super quiet
  11. ANiMESoKAR
    ANiMESoKAR Member
    Australia
    365Coins
    3DOF, SCN5
    Great work HoiHman! Actuators are so quiet :)
    I respect SimFeedBack's decision not to share their code for a SimTools plugin but it really would make a big difference to us SimTools users who are already running all their hardware on SimTools :( Hope the team can come to some type of agreement one day. Either way this project is amazing.
  12. steve white
    steve white New Member
    - 55Coins
    3DOF, Motion platform, 4DOF
    has anyone 3d printed these using cura?
  13. BlazinH
    16,661Coins
    Truth is a Simtools plugin is not really necessary. You can output unmixed individual dofs using UDP or shared memory. So all that's needed is for somebody to convert the data if necessary into the format simfeedback needs so it can use it in a plugin.
  14. ANiMESoKAR
    ANiMESoKAR Member
    Australia
    365Coins
    3DOF, SCN5
    That's good to know, definitely above my expertise level though lol
    I was thinking of using Thanos 1280 for SimTools compatibility as the easiest method. I'd also be looking to add limit switches to the actuator build as Thanos mentioned for added safety if possible.
  15. HoiHman
    Mechanic
    The Netherlands
    331Coins
    I could be all wrong about this, but.....
    The source code for writing plug-ins is available in the wiki.
    If there is a possibility to let simtools put out data in the same way as a game, all you need a to write one plug-in for simfeedback for total compatibility of all the games in the simtools library.
  16. BlazinH
    16,661Coins
    Correct. Would need just one plugin then use tuning center as usual for different games.
  17. steve white
    - 55Coins
    anyone used cura to 3d print these parts or is simplify 3d the goto
  18. early_m
    early_m Active Member
    Chelmsford
    857Coins
    I'm looking at taking this design and modifying it to produce a cheaper alternative for myself as 400 euro each is a bit out of my price bracket. New to linear actuators so unsure about a few things.
    Can I use a Nema23 3Nm stepper motor? Enough speed and torque paired with a 1605 ballscrew? (1610 ball screws seem had to come by and more expensive)
    100x100 Ali profile is quite hard to source, so I'm thinking of using 2060 down 2 sides instead.
    Everything else would remain as per the original shopping list.
    Total per actuator currently at £114.
    Any reasons why this isn't feasible? Are limit switches required?
    Thanks.
  19. Ringorumble
    Ringorumble Active Member
    190Coins
    @early_m Maybe you Should ask in the other thread from M hensen, he uses stepper ..
  20. Ringorumble
    190Coins
