DIY Pedals & Buttons Controller
Discussion in 'DIY peripherals' started by TOPMO3, Jul 30, 2016.
  1. Wergilius
    Wergilius New Member
    43Coins
    Same behavior, if I remove the usb when it has freezes, the software closes.
    Maybe I can try on another computer, I have also order an programmer but as the board seems to have fw 0.14 that should not be needed i guess.
    (unless my board have some odd custom variant...)
  2. TOPMO3
    TOPMO3 Active Member
    Russia
    899Coins
    Hi!
    Currently I'm working on complete redesign of USB exchange protocol in order to eliminate those hangs. Things ate going quite well and first test are good.
    I hope I'll finish new release in week or two, so maybe it'll help to all who experienced in saving/loading problems
  3. Wergilius
    43Coins
    Awesome, thank you for your work!
  4. Wergilius
    43Coins
    For info, I tried on another older (slower) computer (still w10 64bit) and there is work ok so it seems to be usb port/computer related somehow.
  5. TOPMO3
    Russia
    899Coins
  6. kpos
    kpos New Member
    30Coins
    Hello All,
    TOPMO3 thanks for the update.
    Version 0.15 doesn't crash but has some other problem.
    Every time I want to save config it writes OK to the device. Reads ok as well.
    You could restart the chip and the config is still there. But after power cycle all config goes back do default single pin GND.
    Please have a look at that.
    Cheers,
    kpos
  7. kpos
    kpos New Member
    30Coins
    TOPMO3 sorry to bother you again.
    Just have tested antoher STM32 board and everything seems to be working fine.
    Clearly these chinese boards cannot be trusted.
    Have a nice day,
    kpos
  8. TOPMO3
    Russia
    899Coins
    Hi kpos!
    Thanks for testing!
    Did you try to make full chip erase for the first problem board?
  9. kpos
    kpos New Member
    30Coins
    After full chip erase the problem goes away.
    I can confirm all is good now.
    Regards,
    kpos
  10. Matheus Henrique
    Matheus Henrique New Member
    84Coins
    Hi guys, i can use this board to make a steering wheel, with firmware MMos ?
  11. Nick Moxley
    yes you can use this board to make a steering wheel and No this Board/Circuit has Nothing at all to do with MMos what so ever.
    MMos is a thing of the past now with the Simucube.
  12. Matheus Henrique
    84Coins
    Will the firmware recognize the pins (pwm, analog, encoder, etc.) as well as stm32f4?
    Thank you very much in advance
  13. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    [QUOTE =“TOPMO3,帖子:163831,成员:17235”]大家好,
    我几乎完成了下一个版本,任何遇到加载/保存配置文件问题的人,请测试测试版0.15版本
    https://mega.nz/#!bMBx1ATB!OVh2-izGW-89DEPFcqPlCpQKAfntblzC0P8MOADjrws [/ QUOTE]
    版本0.15的问题:如果编码器和旋转开关或按钮和旋转开关一起被激活,则旋转开关将无效。只有单独激活旋转开关才能正常使用。请好好解决。
    The problem of version 0.15: if the encoder and rotary switch or the button and rotary switch are activated together, then the rotary switch will be invalid. Only when the rotary switch is activated separately can it be used normally. Please kindly fix it.
  14. TOPMO3
    Russia
    899Coins
    @mm982566 , please try 0.15fix version from my site
    @Matheus Henrique, no my fw cant work with MMOS and there aren't any of FFB functionality in it
    154,406Coins
    +11,181 / 57 / -2
  16. Wergilius
    43Coins
    I have a setup with 4pcs of 1/4 encoder and 2pcs of 1/2 encoders.
    If I configure 2pcs of 1/2 (or 1/1) I get no button presses.
    If I configure 1pcs of 1/2 and 1pcs 1/1 both work,
    The 4pcs of 1/4 always work.
    Works ok (either can be set to 1/2 or 1/1 but not same) but counting of 1/1 get a bit slower (as expected)
    Could I expect 0.15fix correct this (it will take me a while to dismount the wheel to attach the cables to load the fw)?
  17. thecure
    thecure New Member
    - 91Coins
    hi ..i want to try this software but he does not see the card ....i use a version 0.15
  18. Nick Moxley
    New Firmware ? Any details to share ?
  19. TOPMO3
    Russia
    899Coins
    Hi all
    0.16 version is ready
    new features:
    • Keyboard/Mouse emulation is added. With keyboard emulation you can configure some of your buttons/encoders for example as Volume Up/Down regulators, Browser Launch/Navigation, Music Player track switching, etc. With Mouse emulation you can for example mount small analog joystick on your wheel and use it as mouse
    • Now the app show not only axes value but raw sensor value as well, so during calibration you can see both values. I believe it'll lead to less confusion how calibration process is done
    • Axes shaping added, you can choose one of 6 predefined presets or make completely your own shape
    • Winner Winner x 4
    154,406Coins
    +11,181 / 57 / -2
