SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Yup many times... maybe its something with the axis assigment. Where can i see if the data is actually hooked from the game? tuning center?
  2. George Dobransky
    Hungary
    - 43Coins
    normally yes.
  3. splendiddd
    CCTV security
    Netherlands
    810Coins
    ok, thanks. indeed with other games. but not ED
    I was so looking forward to this... will keep trying. :-(
  4. splendiddd
    CCTV security
    Netherlands
    810Coins
    Ok, after hours of trying i am giving up... I did everything to try to make it to work. Reinstalled everything, simtools, elite, the plugin, did the offset trick, try to run in other gamemodes, nothing.
    Only thing i did not do is reinstall windows. every other game workes fine.
  5. George Dobransky
    Hungary
    - 43Coins
    One more thing you can try.
    Try to run plugin updater NOT in admin mode, you have to get the message that it will overwrite max/min values. You have
    to get this msg. If not, try as admin. After try to run game engine and manager as admin, and without admin.
    Try to do that xml trick I wrote before woth/without admin (game manager/ game engine)
    try to turn off virus checkers/windows defender.
    have luck!
    Cheers,
    George
  6. splendiddd
    CCTV security
    Netherlands
    810Coins
    Thanks for the support George. But its not working...
    "Try to run plugin updater NOT in admin mode, you have to get the message that it will overwrite max/min values. You have
    to get this msg. If not, try as admin"
    I cannot use the pluginupdater in admin mode, i get the block sign, when non admin mode i do get the message.
    "After try to run game engine and manager as admin, and without admin.
    Try to do that xml trick I wrote before woth/without admin (game manager/ game engine)"
    I did try all those combinations, no luck.
    "try to turn off virus checkers/windows defender."
    Tried that also no luck
    What i found out so far is that i everything is done as it should, you can hear the motors somewhat but that tuningcenter is not displaying any values when capture/max/min is on like other games
    Also whats strange is when you patch the game, the xml gets changed to a older version (april)
    I contacted dofreality for a good elite profile but i doubt thats the problem.
    I am using w10 and the steam version of elite ( i also tried the standaone) i guess vr or 2d mode dont matter ?
    Regards, Rob
  7. yobuddy
    50,746Coins
    Hi Guy's,
    Would someone with a working Offset file please zip and post the file?
    Then anyone running v2.3 of SimTools can just drop it into the plugin updater to update the offset file for this game.
    So then all you need to do is:
    1) Download and install the game plugin with the plugin updater.
    2) Patch the game with Game Manger.
    3) Install the new offset file with the plugin updater.
    4) Enjoy!
    Take care all,
  8. George Dobransky
    Hungary
    - 43Coins
    Here is a working xml attached.
  9. George Dobransky
    Hungary
    - 43Coins
  10. yobuddy
    50,746Coins
    151,461Coins
    +11,038 / 56 / -2
  12. splendiddd
    CCTV security
    Netherlands
    810Coins
    Thanks all for your efforts, but sadly it does not work for me. Still no game data output in tuning center. no matter what i do. followed all steps as described and even again with admin etc.
    Last resort is to try older version of simtools maybe?
    Cheers
    EDIT: Just tried older version of simtools that came with the rig, also no go... :-( Guess i am setting up the joystick plugin
  13. Mechromancer
    434Coins
    Do you have Bitdefender AV by any chance? I had to uninstall it for Simtools to work. It kept crashing the GameManager.
    I know it's not your issue, but if you have Bitdefender, try uninstalling it. Disabling didn't work for me.
  14. splendiddd
    CCTV security
    Netherlands
    810Coins
    No i dont have that program, i think i will try doing a second install of windows on the same machine.
    Still its really wierd, all other games work fine.
  15. Mechromancer
    434Coins
    Hmmm...my bad. I didn't read the part about your other games working.
    Yeah, a fresh partition is probably a good idea.
    I had a similar problem with my first VR HMD: Connected the HMD, installed the software...everything without a hitch. Spent the next to days trying to figure out why it would be recognized by Windows and display the default screen, but games would not display in the head set. I did a fresh install of Windows and like 15 minutes later I was playing ED in VR. :\
  16. George Dobransky
    Hungary
    - 43Coins
    I just suggest you guys to use 'your uninstaller' to uninstall programs from windows, 'coz normal uninstall
    won't clean windows registry entries, and other files. Y.U. do the job, sweeps out everything. Maybe that also counts....
    George
  17. Mechromancer
    434Coins
    Yeah, I use RevoUninstaller Pro.
    It's the first program I install when doing a clean Windows install. It monitors all the files and registry entries as you install the program(s). That way, it know where to go to get everything when you uninstall.
    Then, for good measure, I use Auslogics registry cleaner. :p
  18. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    165Coins
    hello, download this add-on but as soon as the profile is active the 2dof is knocked down to the right and I have no movement in game, any help? Thanks
    151,461Coins
    +11,038 / 56 / -2
    You will need to provide more information.
    Have you installed the latest Offset File: https://www.xsimulator.net/community/attachments/elitedangerous64_offsets-zip.55526/
    Can you please most pictures of all of your settings, including the Axis Assignments and Tuning Center allocations.
  20. polybasss
    Burgos Spain
    165Coins
    I have downloaded the file that is the same as the one I already had, the one I do not see where to download is the GetBaseAddress64.dll, I need to capture the configuration, it is the default with the plugin, I am new and I am very lost
Thread Status:
