Help with gears/ratio/reducer
Discussion in '3D Printing' started by SilentChill, Feb 4, 2017.
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,799Coins
    With a bigger pulley you need a longer belt to normaly, or shorten actuator stroke.
    With a shorter stroke he needs different gear math to.
    I adviced him a i=10 reduction to keep cost down and keep it simple
    Sorry for te bad english
    Regards Ad
  2. SilentChill
    20,598Coins
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,799Coins
    Not compleetly
    I did the math with youre motor in it
    Youre 10 turn pot will make 500rpm @ topspeed
    And this is the pot max shaft speed to (see tech spec sheet)
    I hope it last long!
  4. SilentChill
    20,598Coins
    My motor probably running at around 90% top speed so I think it should be fine. I will get one and try
  5. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,799Coins
    This is made on rated speed.
    A belt needs tension, when this tension come on pot shaft its give a shorter lifetime.
    Try to take tension from potshaft with a second bearingblock upon pulley for example!
  6. Mmcool
    Mmcool Member
    USA
    1,174Coins
  7. SilentChill
    20,598Coins
    Yes thanks been looking for some reasonably priced multi turn pots for a while but never stumbled across them
  8. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,945Coins
    Any .stl files for something like this ...
  9. Nick Moxley
  10. BlazinH
    16,676Coins
    I know you’re trying out the 10 turn halls @SilentChill but to answer this from your first post,
    , I wonder if you could modify this 200:1 plastic gearbox by removing the motor and make them work with yours and a 1 turn hall pot somehow? They're only $5.75 each too.
    https://www.pololu.com/product/1120
  11. Peacemaker105
    Perth, Aus
    2,019Coins
    Any pics on your final product @SilentChill . See you got them sorted a while ago. How often did you break your wire wound pots btw? Im commited to the pots i have for now as this build is already hemeraging cash as it is haha but if they start to break I'll be def keen on converting to hall sensors.
  12. Gadget999
    12,072Coins
    an alternative is to drop the potentiometer and use a shaft encoder instead
    get the arduino to count the pulses and convert them to one rotation using some maths
    i suggest 360 pulse encoder - if it turns 10 times for one main rotation you have 3600 pulses per revolution
    are you using the smc3 code ?
    maybe someone have converted one to read pulses instead of pot voltage already
