DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. electrolux
    electrolux New Member
    63Coins
    Hey all,
    Currently hoping to have this built by the end of the year and at the moment I'm working on the design in CAD. Didn't want to make a whole thread since I havent made much progress beyond design.
    I plan to have all the electronics in an external box to make it easier to make future mechanical mods.
    I want to use 1 24v 150w MY6812 motor with a 1:7 3m pitch timing pulley ratio. Should give around 4Nm at 350ish RPM. (if the motor performs as expected)
    Here are some more pics and I'd love any suggestions for improvement.
    The paddle shifter, I may add a magnet if I dont like the feel.
    Metal plate in front of motor for extra reinforcement.
  2. Sieben
    Sieben Active Member
    2,241Coins
    Listen, do the Wheelconfig realy need a set up every time it is loaded? Run through every bottons mapping etc.? Or there is some way to save it outhere?
  3. Sieben
    2,241Coins
    Hey. Build one with ArduinoLeonardo. FFB later on. Realy thanks Pals for info with stand alone power supply for encoder and push pull resistors on it.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  4. electrolux
    63Coins
    Which motor do you plan on using, or are you going for no FFB?
  5. Sieben
    2,241Coins
    The motor is MY1025 (250W). )
  6. Meyd
    Meyd New Member
    115Coins
    Hi guys. Is it possible to use a brushless motor? What are the hidden pitfalls? (I have a 1.5 kW motor from my RC aircraft).
  7. Sieben
    2,241Coins
    I guess there were no such kind of a build with this motors. May be no.
  8. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    Brushless motor only if you have a bldc type control.
    If you are going to control how RC will not work well, instead of having the effect of forcing it to one side, it will vibrate.
  9. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi, You could try Odrive Robitics to control your motor, refer to Zennix in this forum.
    Regards Jerry.
  10. Sieben
    2,241Coins
    I've got a question. Assembled all, but when turn on the power to the boards, the wheel continuosly rotates. I use Arduino Leo with Wheel Config. The pin 10, and 11 in Arduino Leo was checked to change the pins for L and R directions. It just rotates as just a motor with a power on to it and thats all.
  11. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Sounds like an issue with the encoder. The wheel beleives it needs to be in a certain position and will rotate to get to that position (centered). But if the encoder is not working properly or is wired in reverse the wheel will continue to spin as it is trying to reach a position but never gets there.
  12. Fernando Igor
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    First run without FFB.
    Once it is working, open the profile and configure the FFB according to its usage (example PWM and DIR).
    Connect pins 10 and 11. If it does not work correctly, test with a multimeter (or something like that) to try to understand the behavior of the doors.
  13. Sieben
    2,241Coins
    I mean, it just work even without anything, just apply power and U've got a scooter from your wheel)
    The Wheel config works fine itself with encoder. In the game also.
    In pics it is not already conneceted to it.
    Here are the pics of the rig. May it be a lack of proper wiring ( connection itself, lost contact i.m.) to the BTS drivers. Don't know. Also checked with the certain 5v+ and common ground to bts drivers.
  14. Sieben
    2,241Coins
    Allright. I messed up with ground to BTS. Lol.
    Now again) With "PWM +Dir" it still rotates like motor. When check "PWM +/-" it stops. When hit callibrate it rotates for a certain amount to the left and stops. Looked up in a game no ffb.
    The motor rotates beyond the calib triangle limit befor a stop.
  15. Sieben
    2,241Coins
    Don't know if that will be intresting here. IF hit calibrate, the wheel starts to rotate slowly, and if then hit it twice again somehere in its rotation, it change the direction but do rotate as it like further on, a bit some more. If hit calibrate once again, it acts like before by itself in direction change. It just memoraze the last action. I haven't read it anywhere before....But no FFB still. And angle stop too e.t.c
    Use 12V15A power in tests. Can be an issue m.b. too. What a mess, any way with it:D
  16. Sieben
    2,241Coins
  17. Sieben
    2,241Coins
    IR FFB test 1.72. Cycle test.
    • Like Like x 5
  18. Frederiksen
    Frederiksen Member
    420Coins
    I'd like to build a wheel with a stm32 and I was wondering what design I should use. I was reading this thread and I saw that Alexey was using a direct drive motor. But I was thinking about using a wiper motor with a belt drive since a wiper motor is fairly accessible. What would you guys recommend?
  19. Gadget999
    12,132Coins
    a wiper motor is normally a worm drive - it will not work for a ffb wheel
  20. Frederiksen
    Frederiksen Member
    420Coins
    Thanks for the reply. The reason I had thought that a wiper motor is possible was from this post. What would you recommend for a motor?
