value1
Forza Motorsport 7 Plugin 2.0.0.0
Plugin for Forza Motorsport 7
  1. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    ok many thanks
  2. Drippz101
    Drippz101 New Member
    75Coins
    3DOF, Motion platform
    @optical10
    Since its 4123 port on the simtools.
    You will need to go to thr router (mine was verizon) and configure port foward from 4122-4123. You will need a ip address when u do this it needs the ip address of your computer.
    So configure the port forward 4122-4123 using computers ip address.
    Now In the forza game data output in the ip address you input the ISP of your router which is a crazy number , you can find that IP by going to google and type in whats my ip address and it will show you.
    Input that in the game plus the port # that simtools shows u. Like your snapshot above.
  3. Domingo Luna
    Domingo Luna New Member
    dominican republic
    - 262Coins
    How do I make it work with the xbox one, someone has tried it.
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    This plugin is for PC only.
  5. Domingo Luna
    dominican republic
    - 262Coins
    maybe they can write one that works
  6. Octavio Olvera
    Octavio Olvera G4m3r43ver
    Trade Marketing
    Veracruz. Mexico
    65Coins
    Yeah I did, but you need a PC to make it work, just download the forza demo on PC and run simtools as you were going to play on PC, from your xbox send udp data to your PC and the run the forza demo to trigger simtool plugin and that's it.
    A little tip if you want to also use a dashboard, the sim dashboard app let you forward data from whatever device you use to PC, hope you enjoy.
  7. Domingo Luna
    dominican republic
    - 262Coins
    ok, I'll try and tell you if it worked. Thank you
  8. yobuddy
    51,524Coins
    @value1,
    Hi Buddy, You mind removing the _ProcessName from the plugin and compiling a Console version of this plugin?
    From the post above, it look like it works just fine.
    Thanks man!
  9. value1
    14,236Coins
    Can you give this one a try. Run Forza Motorsport on the xbox and start this plugin manually. :)
  10. yobuddy
    51,524Coins
    Thanks buddy! :thumbs
  11. Domingo Luna
    dominican republic
    - 262Coins
    Thanks friend! it works excellent
  12. cazsan
    cazsan Member
    Programmer
    444Coins
    Now Forza Horizon 4 data output is available, could anyone test it ?
    I have no rig here to test it but I believe it will be the same data.
    In the end, it seems both games share the same game engine. We can guess so looking the last video they did with shared content between F7 and FH4.
    If it is the case, maybe you could update the plugin page to mention that both games are supported with this plugin.
  13. Jeongkyu Wi
    Jeongkyu Wi New Member Gold Contributor
    Seoul, South Korea
    - 344Coins
    SCN6, SimforceGT, Motion platform, 6DOF
    I've tried FH4 with FM7 manual start plugin and it works finely only few minutes after starting the free roam in my case.
    Game engine stopped working with no error message suddenly and can retry if I re-running the game engine and looping that issue infinitely.
    It's almost same situation with FM7 running with Car dash UDP mode.
    I don't know another guys have a same issue with me.
    #Add.
    Basically, FH4 also have a same issue like FM7 that localhost doesn't working and should follow setup guide about port forwarding first.
  14. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
    Wooow this is awesome, i've been waiting a long time for this and is finally here, I'll check as soon as i get home this.
    A little tip, i use dash mode with sim dash app on android and ios, it forwards the udp and translate it into sled mode so i can get the best of both worlds, this also could work on horizon 4.
  15. Jeongkyu Wi
    Seoul, South Korea
    - 344Coins
    Thank you for your great tip and could you share me a link for the app please?
  16. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
  17. Jeongkyu Wi
    Seoul, South Korea
    - 344Coins
    Thank you so much Octavio Olvera!
    I've succeed to play FH4 with motion now and my second little tip for other motion users is should platform setting to XBOX on the app.
  18. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
    I have motion too, but sadly only for a little moment, sim engine crashes as it does with udp dash format on forza 7, A plugin has to be exclusively written for fh4 but the good part is that it has to be very similar to fm7.
    @value1, your help is going to be very appreciated.
  19. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I'm a bit late to the party. Strangely, I couldn't seem to find any news on the new 'data out' feature that has been added to Forza Horizon 4, but when I checked in game, it is indeed there. How are you guys getting it to work with simtools? Assuming you are just using the FM7 plugin? I just wondered because the process name is different.
    If anyone needs it, the process name is; ForzaHorizon4.exe
  20. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
    Don't bother, it crashes, we only can wait for our genious friends to write a new plugin, unless you want to play for a minute or two.
