Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. Gadget999
    12,053Coins
    Hello gadget 999, thanks for the tip. These power supplies are really cheap on Ebay as used goods. Can you recommend me here a thread in the forum, where Dell power supplies are treated? I suppose I need two of them 12V x 2 = 24V in series or?
    take a look here -- https://www.xsimulator.net/communit...-power-supply-for-12v.5774/page-4#post-143867
    you may find that 12v may be enough with a high current
    152,676Coins
    +11,089 / 56 / -2
    LED power supplies are another cheap option on ebay and they are not as sensitive to power spikes as computer PSUs, plus you can get them in 24V
  3. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    550Coins
    Motion platform, 6DOF
    Help! Can someone please tell me how to transfer the settings in SimTools to Arduino?
    And why can not I turn off the motors via button? Have a video
    made.
    (SMC3 tool is started with admin rights and firewall is off)
    Have read this tutorial. Unfortunately, there is nothing like the settings (PWMmin, PWMmax, PWMrev ... and so on) to be entered in Arduino firmware or where. I hope I have not overlooked in tutorial.
  4. BlazinH
    16,671Coins
    I think the correct link got broken on the smc3-sps thread when hyperlinks got broken before being restored but here you go.
    SMC3 Arduino 3DOF Motor Driver and Windows Utilities
    Edit: Link in SMC3- SPS thread fixed.
  5. Vitalius
    Bonn
    550Coins
    Thank you, looks very similar. I read the same through and I hope I can answer my questions.
  6. BlazinH
    16,671Coins
    When you make changes with smc3 utilities it also uploads them to the arduino.
  7. Vitalius
    Bonn
    550Coins
    OK that's easy :thumbs, I searched all the time for a button or command. One rarely finds good software that transfers data automatically.
    Can you please tell me in which variables these values are stored in Arduino source code? Thank you
  8. Vitalius
    Bonn
    550Coins
    Hi, finally I got there. But my engine has got twitches.
    I read about it here: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    "FPID / Standardmäßig führt die PID - Schleife 4000 Berechnung Updates pro Sekunde. Dieser Teiler ermöglicht es Ihnen , die Anzahl der PID - Berechnungen pro Sekunde durch die geteilte Menge zu reduzieren. Manchmal kann dies helfen , wenn die Motorwicklungen hörbare Geräusche produzieren. Die Anzahl von ca. Calcs pro Sekunde ist in der Mitte der unteren SMC3 Utils Fenster angezeigt. (Dies kann ein wenig herum springen , da es nur ein Indikator ist)"
    Und auch hier: https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/
    "10.Set Fpid to / 1. (If you experience motor twitching or other issues then try increasing it)"
    I tried to increase fpid, it only got worse.
    Here is a video of it
    Has anyone an idea of the reasons why?
    Can this possibly be due to pot interference? Disorders?
    I soldered contacts from Poti to Arduino!
  9. BlazinH
    16,671Coins
    I can't make out your deadzone setting. Have you tried increasing it?
  10. Vitalius
    Bonn
    550Coins
    Deadzone Setting is currently stands at 1
    I try to increase this value tomorrow.
  11. Vitalius
    Bonn
    550Coins
    I almost solved my problem.
    Potentiometer rewired with shielded cable and soldered. Also at the Arduino Uno I lost all contacts. In addition, an electrolytic capacitor 0,47 μF 160V between 5 volts and GND was attached. And here is the result:
    Potentiometer line has now become pretty straight
  12. Vitalius
    Bonn
    550Coins
    Did something good yesterday for my Sabertooth 2x60 made.
    Now awful insulating tape can go away. Maybe someone will find the insulating protection useful.
    IsolierSchutz_skp.rar
  13. BlazinH
    16,671Coins
    Nice work. I've always thought it quite asinine that DE didn't do anything to keep wires from shorting out on the 2x60's heat sink if you insert them just a hair bit to far. :thumbs
  14. Gadget999
    12,053Coins
    How fast are the actuators ? Can you measure the mm/s
    Can we see a video of the smc3 test output
  15. Vitalius
    Bonn
    550Coins
    Hi gadget999, I convert everything into a housing. When I'm ready, I'll answer your questions.
  16. Vitalius
    Bonn
    550Coins
    Hello everybody. I almost finished my 6DOF and immediately tried to try Elite Dangerous Plugin.
    Unfortunately, after an hour I discovered that this plugin works with the current version of Elite Dangerous: Horizons 3.3.0.3!
    But have already ED 3.3.05 now live!
    So a question for all: is still running on someone Elite Dangerous Horizons plugin (XML edition) 3.3.05?
    Thank you in advance!
    Kann ich eigentlich hier auf Deutsch schreiben ? :)
    • Disagree Disagree x 1
  17. Vitalius
    Bonn
    550Coins
    First try. But unfortunately without Elite Dangerous :-(
  18. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    The video does not work for me, is it perhaps marked private on YouTube?
  19. Vitalius
    Bonn
    550Coins
    hello, now it has to go! It's been a bit late yesterday. :)
    152,676Coins
    +11,089 / 56 / -2
    Cool, works now :thumbs
