Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. fuad
    fuad New Member
    kuwait
    23Coins
    hi...
    im facing problem with the vibe. im using 2 sound cards one mother board reltek for game sound and second external sound blaster for the game vibe.
    LFS is working fine for the vibe.
    the problem with other games like AC and PC2. every thing fine with the software. the vibe shows the RPM and other elements and also the game vibe tuning center shows the numbers but the problem the sound do not come from the shaker. maybe its a windows issue or steam????? any one have any idea???
    151,467Coins
    +11,039 / 56 / -2
    I have an issue with PC2, which for me does not register the game vibe plugins, but I expect that is a plugin issue.
    However AC works fine, so I am wondering about your tuning settings for it, if testing works fine and data is present in the Tuning Center.
  3. fuad
    fuad New Member
    kuwait
    23Coins
    yes the data are presented in the tuning center and testing the sound card from the vibe is ok.
    do you mean i have to do the vibe tuning center setting to make it work??? capture the H/L values???
    151,467Coins
    +11,039 / 56 / -2
    The Game Vibe volume needs to be enabled and set, plus capture then tweak H/L values in the Tuning Center.
  5. fuad
    fuad New Member
    kuwait
    23Coins
    @noorbeast thanx for the info .
    i checked the sound settings in windows
    for LFS game sound comming from the reltek sound card and game vibe from usb sound blaster
    for AC game sound ok but no vibe
    do you have any idea????
    151,467Coins
    +11,039 / 56 / -2
    There are no Hi/Low values set in the Tuning Center for Assetto Corsa, so run capture, drive a bit, save it then tweak as needed.
  7. fuad
    fuad New Member
    kuwait
    23Coins
    @noorbeast thanx its working now i will try it for PC2 and other games.
    cheers
  8. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Hello All,
    I installed game vibe since one week and test only into assetto corsa competizione, but I meet some issues
    It works some seconds and a lot of pop pop windows appear
    I 've the latest release of simetool and gamevibe
    I checked Net 3.5 and directx
    Do you have a idea ?
    151,467Coins
    +11,039 / 56 / -2
    I am not certain but I don't think Game Vibe support has been implemented in assetto corsa competizione.
  10. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    ok, i will test on other sim-game and I will keep you informed
  11. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    same issues into assetto corsa
    151,467Coins
    +11,039 / 56 / -2
  13. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    For simtool, and game vibe, sure yes
    I will check the english settting
  14. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Thank you for your help, the issue come from the english settings who was not completely set in english
  15. Hocky
    Hocky Member
    126Coins
    I have problems with getting sound out of Gamevibe for rpm and sqr.
    If I go sin it works but not sqr.
    When activating test I get no sound what so ever using sqr?!?
    What am I missing? Probably something obvious :)
  16. Adrianstealth
    Adrianstealth Active Member
    director
    england
    334Coins
    SCN6, 4DOF
    Is there a DCS vibe plugin yet ???
    151,467Coins
    +11,039 / 56 / -2
    Not yet, but you can check out the new flight related improvements to Game Vibe using the War Thunder plugin, those cover: https://www.xsimulator.net/community/marketplace/war-thunder-plugin.176/
    Game Vibe types:
    Rpm - self explanatory
    Road detail - heave
    Turbulence - Speed + (Speed*flaps deployed*0,2) + (Speed*Landing gears deployed*0,2)
    Collision L/R - Sway
    Collision F/B - Surge
    Weapon1 - Weapon1 fire
    Weapon2 - Weapon2 fire
    Landing Gear - deploying/retracting landing gear
    Flaps - Deploying/retracting flaps
  18. Guus Franken
    Guus Franken New Member
    - 45Coins
    2DOF, AC motor, Arduino
    Hello
    Is it true that I do not have a vibe for gear shift with iracing?
    Guus.
    151,467Coins
    +11,039 / 56 / -2
    Have you configured it and can you please post a picture of your settings.
  20. Guus Franken
    - 45Coins
    RPM and Road detail works just fine....but I miss the kick in my back ;)
      779.1 KB
      510
      532.1 KB
      551
