Ville Pesonen
War Thunder Plugin 2.0.0.0
SimTools plugin for War Thunder
  1. noorbeast
    152,331Coins
    +11,072 / 56 / -2
    The plugin works fine for me on SimTools 2, so likely you have some settings or other issues.
  2. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    2DOF, 3DOF, AC motor, SCN5, SCN6, SimAxe, Motion platform, 4DOF
    What version of simtools? 2.2.3 or 2.2.5? what version of the plugin? what can block data? I get them but not all!
    152,331Coins
    +11,072 / 56 / -2
    Use the latest version of both SimTools and the WT plugin from the Downloads section.
    Anti-virus and firewalls can somtimes be an issue, in either interfering in proper installation of plugins or in blocking data.
    But first please post pictures of all of your settings.
  4. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    i use the latest ver.
    152,331Coins
    +11,072 / 56 / -2
  6. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
  7. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    152,331Coins
    +11,072 / 56 / -2
    The plugin does work, but something on your system is likely interfering with it.
    What are your Interface Settings?
    Have you tried temporarily disabling your firewall and antivirus off, then reinstall the plugin, then try it.
  9. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    I only know that when your Simtuls became paid, it stopped working normally!
    with Simtools 1.3 there are no such problems as changing UNICODE, etc.
    152,331Coins
    +11,072 / 56 / -2
    SimTools 1.3 plugins do not work with SuimTools 2, nor are SimTools 1.3 plugins maintained.
  11. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    I know ! I'm talking about the fact that when Simtools was free, it worked perfectly, now Simtools 2.3 costs $ 50, and it's always buggy! the question is why it was necessary to spoil something that worked well!?
    152,331Coins
    +11,072 / 56 / -2
    War Thunder works fine in SimTools 2, it is something on your system that is the issue.
  13. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    Ok, I'll try!
    I will let you know if I solve this problem.
  14. yobuddy
    51,101Coins
    @ACTIVE-GAME
    When you upgrade to v2 from v1, please make sure you completely remove v1 first or you will have problems.
  15. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    I installed version 2.3 on a clean pc
  16. HECTOR SALCEDO
    HECTOR SALCEDO New Member Gold Contributor
    90Coins
    I installed the plugin, it recognizes the game and I get every force data but roll and pitch, what's wrong?
    152,331Coins
    +11,072 / 56 / -2
    Have you captured the Tuning Center Max/Min values?
  18. El_Batallitas
    El_Batallitas New Member Gold Contributor
    Spain
    37Coins
    Hello! I need a hand here.
    I have a 2dof sim and for this game I can't make the sim to emulate the plane's position because it goes back to the center (which I think is perfect for space ships but not WW planes) Well this only happens if I set "Extra1" and "Extra2" forces.
    If I set "Roll" & "Pitch" the sim does not go back to center position, but, it only reacts when the plane moves from + degrees to - degrees then sim moves from one extreme to another.
    I'm on last SimTools version and it happens on every WarThunder plugin that has been released.
    Thank u guys
    152,331Coins
    +11,072 / 56 / -2
    Extra 1 and 2 should return when the joystick returns to its neutral position.
    Roll and Pitch are the alternate traditional forces, but like with any flight sim you will need to use Filters and Anti-rollover to get the most out of the profile and rig.
  20. El_Batallitas
    Spain
    37Coins
    So that's the way it is? Now even when the plane is on the ground before take off if I move the joystick also does the sim, just like "Joystick simulator" profile would do. I though this WT profile could match plane's position,
