value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. Benji85
    Benji85 Member Gold Contributor
    851Coins
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    i dont think so... ED its the same on oculus or steam. Maybe if you can provide us a VERSION of your game, ( numbers, specific ) ... i can say if its the same or not.
  3. Benji85
    851Coins
    Latest veesion definitely not working with ed plugin.
    Are you saying it's working for you or are we talking about the joystick plugin?...
    152,349Coins
    +11,074 / 56 / -2
  5. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    First off...this plugin is fantastic for games which don't officially support motion.
    Kudos to value1 for developing it! :thumbs
    With one small caveat, which may just be something I'm missing on how to properly use it.
    I'm re-posting this here (originally from the thread requesting support for the game Vector 36) in hopes of catching the ear of the plugin author and see if there is any sort of a solution, or steer me in the correct usage of it. :sos
    It appears that the game requires to be in focus for any controller to work with it, as does the joystick plugin for the motion platform to work.
    I can only choose one or the other at any given time. :(
    Several games do indeed allow for the game to be run in the background (such as Worlds At War & Wreckfest, etc.) while the joystick plugin is controlling the platform, so I assume that the fault is on the game side and not the plugin side when it doesn't work.
    Unless of course I'm doing something wrong with my usage of the plugin.
    The only way I can get it to work is if I leave the plugin as the last app in focus by clicking on the header bar, then just leaving it alone after that and not closing the joystick selection window.
    Whenever I allow something else to have focus the platform stops moving.
    I'm not sure if this is the way it's supposed to be, or if I'm doing something wrong. :think
    If in fact I am missing something, then I think that the joystick plugin would work with almost any game.
    I know that with my old Next Level Racing V3 motion platform that their similarly functional DirectInput controller app did still work while it wasn't in focus.
    Any help would be GREATLY appreciated.
    Cheers! :cheers
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    2,006Coins
    Hello!
    Does this plugin works with Vive controller or Oculus Touch ? It would be nice to use them in Eagle Flight or Google Earth VR !!!
  7. value1
    15,051Coins
    The plugin uses the Microsoft Direct3D Joystick API.
    Give it a try and let us know, please.
  8. Wanegain
    Bruxelles
    2,006Coins
    They do not appear in the list unfortunately :(
  9. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Are we supposed to keep the selection screen active once a joystick is chosen, or do we need to hit the "close" button afterwards?
    I can't seem to get it to work in game unless the plugin is the active window, which obviously doesn't work with a lot of games.
    Please see my other post, which is 4 above this one, for further details.
    Any help would be appreciated.
  10. Getchu
    Getchu New Member Gold Contributor
    - 14Coins
    Thanks @value1 to share the joystick plugin.But only can use the 360 controller emulator to run it.Please update software the hardware support.(e.g. xbox one controller)
  11. Kranky Pantz
    Canada, Eh!
    1,288Coins
    It works with any x-input device on Windows.
    I've used it with an XBox One gamepad, a HOTAS, a flight-stick, and my wheel/pedals/shifter setup.
    Each one will need tweaking in your Windows controller settings, as well as defining their axis movements in SimTools.
    It's worth taking the time to setup, and once you're done it adds a whole new dimension to games without official motion plugins.
    As far as I know there's no official support instructions or manual, just keep tweaking until things move in the correct directions and feel right.
    • Agree Agree x 3
  12. fuzzel4711
    fuzzel4711 New Member Gold Contributor
    76Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, 4DOF, 6DOF
    I can only select "Live for Speed". What do I have to do to let the Game Manager know the
  13. noorbeast
    152,349Coins
    +11,074 / 56 / -2
    Have you installed the plugin using the PluginUpdater?
  14. fuzzel4711
    76Coins
    Nope, this was missing from the instructions :thumbs
    Now it works.
    BTW the instructions say "Run GameEngine & GameEngine" I think it should be "Run GameEngine & GameManager" ;)
  15. paulopsx2
    brasil
    647Coins
    well, you dont needs to put GAME select on software. Just put Joystick.exe on the same folder as main simtools
  16. paulopsx2
    brasil
    647Coins
    Anybody try to use on xbox ONE bluetooth 4.0 controller? dont works for me. Pad works fine on windows, on control panel at "set up USB game controllers", as "bluetooth XINPUT compatible input device" but no choices for select on panel from joystick plugin !
  17. Big Destroyer
    Big Destroyer New Member
    South Africa
    4Coins
    @value1 Thanks for this amazing plugin. Is there any chance of making the recorder export the telemetry in a format compatible with the Video Ride Creator?
  18. yobuddy
    51,101Coins
  19. Big Destroyer
    South Africa
    4Coins
  20. kevinmarz
    kevinmarz Member
    346Coins
    Can anyone be nice enough to share the game manger plugin setting..
