Haraguchi's DIY 2DOF cockpit project
Discussion in 'DIY Motion Simulator Projects' started by Haraguchi, Dec 13, 2017.
  1. Bruno Silva Rogano
    Bruno Silva Rogano New Member
    Brazil
    125Coins
    Well Done! Excellent job!
    I may try building an aluminum profile frame structure very similar to yours, could you please send some technical details ?
    I found a company on internet that actually assembles the aluminion structure the way you ask for.
  2. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    hi Bruno !
    Yes i used aluminium structrure by Estrutural
    www.estrutural.com
    Jacareí-SP
  3. Bruno Silva Rogano
    Brazil
    125Coins
    Thanks Haraguchi!
    May I ask you how much (no need to give the exact number) reais cost your plataform ?
  4. Marcelinho1979
    Marcelinho1979 New Member
    Brasil
    156Coins
    2DOF, Motion platform
    Blz Haraguchi. Concluiu seu projeto? Eu estou iniciando o meu. Estou pesquisando os motores que posso usar, pq meu hard é um pouco mais pesado que esse playseat e vi que vc relatou problemas na diferença de peso entre vc e sua filha.
    151,467Coins
    +11,039 / 56 / -2
  6. Marcelinho1979
    Brasil
    156Coins
    Hi,. Sorry. Replying your msg with question in english too:
    Hi Haraguchi. Did you complete your project? I'm starting mine. I am researching the engines that I can use, because my hard is a little heavier than this playseat and I saw that you reported problems in the weight difference between you and your daughter.
  7. Francisco Junior
    Francisco Junior Member
    Curitiba - Brasil
    285Coins
    What is your project proposal? 2 or 3dof?
    Which controller card will you use?
    Qual é a proposta do teu projeto ? 2 ou 3dof ?
    Qual placa controladora você irá usar ?
  8. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Hi my friend, sorry for delay in response. This thinks never fisinhed, hahaha. Really a had a problem with weight, but i think is a correct levers distance.
    I will post the News !
  9. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Hi Bruno, how are you?
    I spent about R$ 2500.
  10. Hendrik
    Hendrik New Member
    122Coins
    Hello, great build!
    Could you please tell me: From which car is this cardan joint? Thank you!
  11. grec pastor
    grec pastor Member
    Spain
    453Coins
    You have to read a little more ... do not you think?
  12. dominike
    dominike New Member
    462Coins
    hello
    beautiful work
    I hope to achieve something like yours. I will be proud of it
  13. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Thank you !
    Yes, there are many models that can be used.
    Good luck !
  14. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Good afternoon sirs !
    I've been away from the forum, working offshores, so it's hard to participate.
    Well I made some changes, mainly due to the heating of the engines. The heating was due to poor design I made. I had to study levers (Newton's laws). After some adjustments and with the help of this program (https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/)
    I came in the model below.
    Maybe the aesthetics did not look so beautiful, but now the engines work pretty cool!
    Then I'll make aesthetic changes.
  15. grec pastor
    grec pastor Member
    Spain
    453Coins
    I was looking at your design, the potentiometer part, you get 180 degrees? Could you tell me what potentiometers you used?
    Thank you.
  16. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Hi man.
    I'm using a linear 10k cheaper and simple potentiometer.
    I have used a precision model, but it dont works well.
  17. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Yes i got 180 defrees
  18. grec pastor
    grec pastor Member
    Spain
    453Coins
    Thank you, I'm trying to make some hall sensors with SS495A1 transistors and some magnets, I'll tell you
  19. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Hi men, i made a new video.
    Simtools is running in notebook and a i'm playing in XBOX ONE X.
  20. darlan
    darlan New Member
    147Coins
    Fala haraguchi.
    Sou fã do seu projeto.
    eu estou comprando as peças pra fazer um mas, queria que ele inclinasse 30 graus no roll. vc acha que com esses motores eu vou conseguir?
    pergunto isso porq vc ja teve problema de aquecimento com eles...
    eu vi projetos com motores de limpadores de parabrisas de 500w e que pareciam inclinar até mais que os seus. eles sao bem mais barato, achei estranho porque esses seu motores parecem ser bem mais fortes.
    abraço.
    Hi haraguchi.
    I'm a fan of your project.
    I'm buying the pieces to make one but I wanted to tilt 30 degrees on the roll. Do you think I can do it with these motors?
    I ask this because you already had heating problem with them ...
    I saw designs with 500w windshield wiper motors that seemed to tilt even more than yours. they are much cheaper, it is strange because yours engines seem to be much stronger.
    many thanks.
