3dof project [SMC3 issue]
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by heliomenezes, Nov 30, 2018.
  1. BlazinH
    16,661Coins
    It doesn't appear that you set smc3 to mode 2 in the sketch. It won't work with ibt-2 until you do.
  2. heliomenezes
    heliomenezes Member
    233Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Arduino, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    Look
    151,486Coins
    +11,041 / 56 / -2
  4. heliomenezes
    heliomenezes Member
    233Coins
    I did not understand ground isolated, I tested all the motors and they do not work, I have basic knowledge, smc3 running 100%, but they do not drive motors, maybe I should give up the project
  5. heliomenezes
    heliomenezes Member
    233Coins
    smc3 running ......... I made the links of the motors, direct wires in the coal
  6. heliomenezes
    heliomenezes Member
    233Coins
    smc3 not working, was the engine, has to make direct wires in the coal
  7. heliomenezes
    heliomenezes Member
    233Coins
    What am I doing wrong???
    Does not activate the motors
    smc3 100% running, but no simtools
  8. BlazinH
    16,661Coins
    Have you done at least one race in LFS before patching to setup necessary files?
  9. heliomenezes
    heliomenezes Member
    233Coins
    before using smc3, it worked normal, with another 2dof program, now with smc3 does not want to activate engines,
    Sorry for my translation.
  10. BlazinH
    16,661Coins
    You are using the wrong output settings for smc3.
    Setup for Simtools 2 is very straight forward:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Set for 10bit binary output
    • Agree Agree x 3
  11. heliomenezes
    heliomenezes Member
    233Coins
    Is my setup wrong? Simtools does not work, engine does not work, I've done everything and nothing, does anyone help me?
  12. heliomenezes
    heliomenezes Member
    233Coins
    smc3 ok, simtools not working
  13. BlazinH
    16,661Coins
    Really? :confused: Check your baud rate setting then look at my previous post again more carefully this time.
  14. heliomenezes
    heliomenezes Member
    233Coins
    already change everything and nothing, I believe to be here >>>> [A <Axis1a>] [B <Axis2a>] [C <Axis3a] because I use other software and it works, please give me a hint where I am wrong, Only the axes can be
  15. BlazinH
    16,661Coins
    Are you closing smc3 utilities before starting simtools? Two apps can't talk to an arduino on the same com port at the same time so the first one connected locks out the other.
  16. heliomenezes
    heliomenezes Member
    233Coins
    yes, I'm doing everything right, this makes me nervous, I'm wasting my patience kkkkk
  17. Pit
    30,482Coins
    Honestly good things come to those who takes patience. I suppose your settings are wrong somewhere. Please upload any screenshots of all related settings. And not to forget we are not paid for any support, we do this by choice.
  18. yobuddy
    50,757Coins
    @heliomenezes
    The video shows decimal output not binary.
    Please fix and try again.
    Take care,
  19. Pit
    30,482Coins
    The Guru @yobuddy himself ;), honestly this issue has been discussed above and the solution has been posted by @BlazinH. IMHO we should advise our members reading the manuals at first before we are going gray o_O
  20. heliomenezes
    heliomenezes Member
    233Coins
    Look at my configuration
