vthinsel
Assetto Corsa UDP (Consoles) - Manual plugin start 1.0
Assetto Corsa UDP plugin for consoles
  1. yobuddy
    51,558Coins
    Click the details button when you get the error so we can see what is happening buddy.
    Take care,
  2. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    92Coins
    These are the steps that I make to start the software:
    start ps4
    start router
    start pc
    start account ps4
    start game engine and game manager
    start Assetto Corsa
    start game practice or race, without change car or truck
    download game
    start plugin in Simtools
    I Drive but the playseat don't move
    The messages are in the attachment, the details too.
    Best Regards
  3. FrancescoRoberto
    Italia
    92Coins
    Yobuddy and Vthinsel: Have you any news or the solution about my problem to use plugin UDP Assetto Corsato console.
    I don't know what I can do.
    Best Regards
  4. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    No, no news from my side. I would need UDP data replay to track the problem. I can also make a debug version , or make the code more defensive. I'll have a look at options but AC is a real pain due to the UDP handshake making troubleshooting much more difficult. It used to work nicely when I had the game.
  5. FrancescoRoberto
    Italia
    92Coins
    I'm continuing to improve my 3dof playseat, but I'm very sorry because I don't to use my simulator with PS4 Assetto Corsa game.
    Now, a doubt has arisen:
    May be is the correct game to the vthinsel plugin "Assetto corsa Competizione"?
    If It isn't true, are there any upgrades about thhe UDP plugin about Assetto Corsa game to PS4?
    Best Reards
  6. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    The plugin is not for AC competizione, just AC. Maybe it works with competizione but as I dont have it I cant tell
  7. Morket
    Morket New Member Gold Contributor
    52Coins
    Hola. Me pasa exactamente lo mismo, ¿sabes si se puede resolver? Abro el exe con la dirección IP correcta de ps4 y el circuito, mi nombre y el auto aparecen, pero el simulador no se mueve.
    Hi. The exact same thing happens to me, do you know if it can be solved? I open the exe with the correct ip address of ps4 and the circuit, my name and the car appear, but the simulator does not move.
  8. ludo22420
    ludo22420 Member
    206Coins
    does the simulator move with another game?
    assetto corsa competition is coming out soon on ps4 will there be an udp plugin
  9. Morket
    52Coins
    the simulator works perfectly in both project cars 1 and 2, f1 2016 on ps4, they are the games that I was able to configure. I also have the Dirt Rally 1 and 2.0, Gran turismo sport but I think there is no possibility of udp yet.
  10. Morket
    52Coins
    My assetto corsa game is the ultimate edition, is not the competition. The ultimate edition is the basic game but with dlcs into the disc. I think it should work like normal game
  11. FrancescoRoberto
    Italia
    92Coins
    I apologize but I didn't find a solution about UDP plugin Assetto corsa, only a person could help us, Vthinsel, but may be He hadn't a PS4 yet.
  12. santanadany
    santanadany Member
    Chile
    605Coins
    Dear, I had the same problem, when windows did an update a couple of days ago, I solved it, forcing the file : AssettoCorsa_VB_UDP_Receiver.ex to run like windows 8, ever, and it was fixed !!
  13. FrancescoRoberto
    Italia
    92Coins
    Hy,
    Thanks, but I sent the PS4 and I bougth a PC, because the pc games have a FFB better than PS4 games.
  14. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Is there a new method to make it work?
    Simtools does not receive data.
    It worked normally until last week.
    Now it doesn't work.
    Is anyone managing to use?
    Was it due to a game update?
    Thanks.
    153,986Coins
    +11,162 / 57 / -2
    What changed between last week and now?
    It may not be a game issue, as it could also be related to system updates.
    So can you please check and report on what has changed.
  16. Leandro Kemp
    Brasil
    - 10Coins
    I don't know what has changed.
    It just worked and now it doesn't.
    I tried on three PC's and it didn't work.
    New PC.
    153,986Coins
    +11,162 / 57 / -2
    Being UDP it should not be a game change, perhaps try turning off things like firewall and antivirus to see if something is interfering with communications.
  18. Leandro Kemp
    Brasil
    - 10Coins
    Already did that.
    I will download the plugin again.
    You may have a corrupted file.
  19. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    I've done all the procedures and it didn't work.
    It was working until a month ago.
    Now it doesn't work now.
    I think it's something in the game.
    Is anyone getting it to work?
    153,986Coins
    +11,162 / 57 / -2
    It may be one for @vthinsel to have a look at.
