DOF Reality platforms presets, profiles and tips
Discussion in 'Commercial Simulators and Peripherie' started by Mpmo, Dec 9, 2017.
  1. Daniel_83
    Daniel_83 New Member
    Poland
    223Coins
    Sure, You can make a video.
  2. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Here you go, hope it helps.
  3. DOFreality
    DOFreality Member
    Montreal
    344Coins
  4. greatg67
    greatg67 Member Gold Contributor
    509Coins
    Great thanks! There are only 2 games supported in these profiles? Can these be used as template for other games? Will other profiles (like for P3) be available?
  5. DOFreality
    DOFreality Member
    Montreal
    344Coins
    we are working on others
    you can setup any game profile following these steps :
    1) Open SimTools Axis Assignments
    2) select from the drop down the game plugin you want to tune to 6DOF (eg "pCARS2")
    3) reset settings to the default 6 DOF profile by clicking "Load Default"
    4) in all effects (Pitch, Roll, Extra1/Yaw, surge, sway,Heave) in % column put "-"
    5) start with one effect lets say Roll and set it to 80% for all axis
    6) save and start the game to check the direction. if reversed invert Dir for it in the check-boxes for all axis
    7) set Roll % to "-" and set 80% for the one of next DOF (Pitch,Extra1/Yaw, surge, sway,Heave)
    8) repeat #4-6 for all 6 DOF (Pitch, Roll, Extra1/Yaw, surge, sway,Heave)
    9) tune the % values to your preference and realism. We suggest to start from lower values and go up as some games maybe super sensitive.
  6. marco balletta
    marco balletta Member
    1,445Coins
    Hi there . Do you have any new games profiles for the 6dof please ?
  7. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    Every time i email dofreality asking to post 6dof axis assignments they just ignore my question or just link me to this thread. What is this joke. If you make a 6dof and sell it you should also provide us with presets and axis assignments for popular games like assetto corsa/project cars 2/ATS/dirt rally, etc.... @DOFreality i wanna see how it should look. Can you PLEASE post a screenshot of the axis assignments of any driving game, because i tried loading the presets into simtools to see how it looks but it wouldn't load.
  8. greatg67
    509Coins
    I feel your frustration. It is not so simple with the P6 as it was with the P3. The presets were already developed for the P3 and all we had to do was a bit of tweaking. But for the P6 this is much more involved and very confusing.
  9. Mpmo
    Mpmo Member
    1,289Coins
    yeah but surely the ones selling it should be able to have made presets for the popular games no? I'll wait until they or someone makes good profiles before upgrading anyways
  10. marco balletta
    1,445Coins
    How many games were you able to make acceptable 6 dof presets for ?
  11. greatg67
    509Coins
    So far none. Except for the 2 that come pre-configured.
  12. splendiddd
    CCTV security
    Netherlands
    813Coins
    X-Plane 11 with Samsung Odyssey+ VR on the DOFReality P3
    Profile is in this post, remember to backup your settings!
  13. ChilliPepper
    ChilliPepper New Member
    217Coins
    Hi, how do I install this profile? I drag this into the Game Manager tools but it says is not a valid file. When I extract the file , inside there are 2 files, 1 is preset and 1 is cfg file, where do I install the cfg fle?
    153,938Coins
    +11,158 / 57 / -2
    Close SimTools Game Engine and Game Manager then use the PluginUpdater app to install plugins: https://www.xsimulator.net/community/faq/how-to-install-plugins.310/
  15. ChilliPepper
    217Coins
    Thank you. Got it working, and thank Splendiddd for the profile, work for my P2. I see that you got rid of the pitch assignment for X-plane, but work better than previous profiles. It's more responsive and could feel every little movement.
  16. splendiddd
    CCTV security
    Netherlands
    813Coins
  17. DOFreality
    DOFreality Member
    Montreal
    344Coins
    new 6DOF profiles and tuning settings for Acceto Corsa, Dirt Rally, Dirt 4, pCARs 1 and 2
    -download them,
    -unzip
    -drag ' n' drop to the Tools -> Preset Installer
    -In Axis Assignments select Generic 2D Standard
    -Select game from the game list
    -click Preset
    -Select proper 6 DOF preset
    -Click Save
    more to come
  18. DOFreality
    DOFreality Member
    Montreal
    344Coins
    iRacing and Dirt Rally 2.0 for 6 DOF
  19. splendiddd
    CCTV security
    Netherlands
    813Coins
    @DOFreality no offence but i think it would be more usefull to upload the actual min/max files instead of posting screenshots.
    You can extract them from appdata (hidden folder) local/simtools etc. (same location as the axis presets folder)
  20. marco balletta
    1,445Coins
    Thank you so much @DOFreality for the new 6DOF profiles and tuning settings !
