JADs 6dof with ballscrews
Discussion in 'DIY Motion Simulator Projects' started by JAD, Feb 25, 2018.
  1. pmvcda
    15,440Coins
    Seeing your serial command, it wont work for the current version of the FlyPT interface.
    I have a new one that I will upload today, that allows sending commands of the type <#>.
    So before trying, wait for the new version (1.6.3). I need some feedback for that, specially because you are using decimal output and I have doubts it's working well.
    Great build!
    Hope you have no problems with bending ballscrews.
  2. cazsan
    cazsan Member
    Programmer
    444Coins
    Still looking very promising! I wonder if the noise produced by the ball will be comfortable when playing. Any other side noise so we can have a reference regarding the ones from your build?
  3. JAD
    JAD Active Member
    Australia
    1,446Coins
    It is a bit noisy. It seems to be mostly from the ballscrew nut.
    Perhaps it wont be so bad in normal use and regular game play.
  4. JAD
    JAD Active Member
    Australia
    1,446Coins
    Your update 1.6.3 fixed it for me. Cheers!
    I was having fun throwing the rig around using the sliders and I got about 30secs in and then thought, its jumping around too much, it really needs some filtering, .
    I was just about to apply the filter, but the last move pulled apart the top end connector and the actuator fell to the ground.
    This one is still fine but the rig fell on a back actuator and bent the screw and the Aluminium tube.
    So a bit of a setback.
    But Im still happy I got this far this weekend with the interface.
    Ive ordered some Ebay ballscrews from a local supplier that will hopefully arrive in time for this weekend.
    I couldnt find the same double nut supplier I used earlier(at reasonable price), so I will have to swap over the nuts when they arrive.
    I should be back in action after this weekend.
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    That's so bad. Hope you get back on it soon.
    I've learn that you should always film your first try, as it could be the only time you can do it before it breaks. :)
    Keep on!
  6. SilentChill
    20,595Coins
    Ouch !! All in the learning process I suppose :)
  7. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    Hey @JAD,
    thank you for your thread! There is plenty of important information for me:)
    What happend with your rig after the crash? ^.^
  8. JAD
    JAD Active Member
    Australia
    1,446Coins
    I did stop for a while. Not enough Sundays. But have got back to it the last few weeks
    I got it together again with a replacement ballscrew.
    Gave it another run all OK but I decided the bearing mount at the motor end of the ball screw was not suitable. With the two bearings stacked up against each other inside the bearing block, there is too much wobble and the screw can start to whip around uncomfortably at certain resonant speeds.
    I tried keeping the block and replacing the bearings with some quality name brand deep groove bearings but there was little difference.
    Next I tried angular contact bearings loaded up against each other but also not much improvement.
    So I have started making some custom bearing blocks (Aluminium) which separate the bearings around 50mm.
    This is only my second job ever on the lathe and it has taken me much longer than I care to admit.
    I had these finished yesterday.
    This coming weekend I'll be starting on machining the ballscrew to fit the new bearing block.
    Hopefully I can update again soon with a few completed actuators.
  9. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Those bearing do look really nice. I hope you get much improvement.
  10. JAD
    JAD Active Member
    Australia
    1,446Coins
    Finally have something to show and can now report all the actuators have been upgraded with the new bearing blocks.
    I also added a bottom limit switch for homing when starting up the sabertooth/kangaroo.
    It was getting a little uncomfortable watching the start up routine perform the homing and calibration by crashing into the stops.
    I can cope with it crashing into the bottom limit, but I was clenching every time it would run the ball nut to the top limit inside the tube.
    And no, that's not an upgrade to carbon fibre tube, its just a vinyl wrap.
    I also took the time to redo the whole assembly of electrics.
    Its now easier to pick up the whole thing and put it on the bench to work on.
    I have a few small things to finish up before connecting it all.
    Hopefully next update will be the thing moving again.
    • Dislike Dislike x 1
  11. Thanos
    Electronics Engineer
    2,862Coins
    Perhaps consider using servomotors... ...calibration via torque on power up and no limit switches at all (no need for)
  12. JAD
    JAD Active Member
    Australia
    1,446Coins
    They are certainly a great choice except way out of my price range.
  13. Thanos
    2,862Coins
    Not so much... all including power drive is $194 each:
    https://m.aliexpress.com/item/32352297491.html
    Perhaps less that what you spend for the DC motors, power supplies, sabertooths and kangaroos etc...
  14. JAD
    JAD Active Member
    Australia
    1,446Coins
    Thats surprising, last time I checked I thought we were facing $500+
    If I had my time over, I'd seriously consider those. Perhaps for Mark 2 rig
    Thanks for pointing them out.
  15. Thanos
    2,862Coins
  16. wannabeaflyer2
    london uk
    8,345Coins
    Hi @JAD man I have to say that is one seriously nice man cave lol and loving the progress with your platform , had my doubts about the potential side loads with your actuator at full stretch so its great to see nice you making nice Progress Greta stuff :)
  17. JAD
    JAD Active Member
    Australia
    1,446Coins
    Yeah, the cave is working out well. I took over the whole garage as soon as we moved in, no car has ever parked in here!
  18. Thanos
    2,862Coins
    Lucky... I have only a 1/8 of the garage available for "mancave". And I even get complains about it all the time... lol
  19. hannibal
    hannibal Active Member
    4,491Coins
    Wish i knew about these!!
  20. hannibal
    4,491Coins
    Im embarrassed to ask...
    What is a kangaroo?
