  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Ok, I wall ask him (again), if source is available (or he has found his old machine)...
    thx anyway
  2. Trigen
    Trigen Active Member
    2,892Coins
    Got a question. I have a G seat with a small negative axis tolerance. Is it possible to edit the Ardunio file so it ignores anything that goes below pot center position? Or if possible limit it to a set range?
    152,571Coins
    +11,087 / 56 / -2
    It gets really confusing for others when members cross let the same question on multiple threads, please stick with the original thread: https://www.xsimulator.net/communit...ne-raise-or-axis-neg-clamp.13002/#post-171547
  4. KONIU
    KONIU Member
    Poland
    449Coins
  5. Arazok
    Arazok Member
    Computer scientist
    783Coins
    does anybody know, if you can use SimTools to let more than one motor move ?
    cheers,
    Dirk
    152,571Coins
    +11,087 / 56 / -2
    SimTools can handle a 6DOF plus a G-Seat at the same time, so yes it can handle more than one motor moving.
  7. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Sorry, my fault: I mean SimUtils (from RufusDufus, I cannot reach him), not SimTools, sorry.
  8. Pedro Andres Pineda
    Pedro Andres Pineda Member
    System engineer
    Colombia
    46Coins
    hi, I changed from motomonster to ibt-2 BTS7960B, I've changed the file in arduino to set mode2, but my motors don't move, in smc3 tool I can see the pwm with high values. Is correct wiring as example in mode 2 and set arduino in mode2? What can be my problem?
    152,571Coins
    +11,087 / 56 / -2
    Mode 2 wiring is like this:
    MODE2:
    Arduino to H-Bridge (Chinese 43A)
    ENA ----> IN1/RPWM
    ENB --+-> EN1/R_EN
    +-> EN2/L_EN (ie connect ENB to both R_EN and L_EN)
    PWM ----> IN2/L_PWM
    n.c. ----> IS1/R_IS
    n.c. ----> IS2/L_IS
    +5V ----> VCC
    GND ----> GND
    The image below shows wiring for two motors... Thanks to @eaorobbie for getting me started with the image :thumbs
  10. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Hi Pedro, If you wired it just like the picture it's 100% correct.
    Your motors are enabled in the SMC software?
    You can set your limits with the potentiometers and the SMC software, if your settings are out of bounce your motors wil not move!!!!
  11. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Hi. Thank you for your answer.
    I wired all with the picture for mode 2. And I set and compile the Arduino in modo2.
  12. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    And this is how Smc3 tools shows the info.
  13. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Ok, when you rotate the potentiometers can you see a change in te SMC3 console?
    I can't follow/see the wiring, that's a bit too hard to see :) (in the pictures)
    did you measured the +5V on the H-bridges?
    is enabled high? (~ +5v)
  14. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Yes, when I move the potenciometer smc3 shows the new position, in the h bridge I can measure correctly +5v.
  15. BlazinH
    16,671Coins
    So both mm and ibt-2 don't work? Have you tried a different arduino?
  16. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Thank you everyone for the help. After all, with my father, we decided disconnect the Arduino and h bridge from the motion platform and we connected it on the table with a small motor and another power supply. All worked fine on the table. We tried the old arduino with our old motomonster and it works too. Finally we need validate what happens with our motors in the motion platform and the 40 amp power supply.
  17. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    We don’t know if is valid put the power supply, h bridges and arduino together under the motors. Does this generate interference between the components? I tested each motor and the power supply and these works correctly, but when I connect these with the h bridge and arduino doesn’t work.
  18. noorbeast
    152,571Coins
    +11,087 / 56 / -2
    Are you using wiper motors and if so are they ground isolated: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
  19. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    152,571Coins
    +11,087 / 56 / -2
    No, the pgsaw motors are fine to use as they are, they do not need ground isolation like the wiper motors.
