value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. noorbeast
    154,580Coins
    +11,190 / 57 / -2
    If it is connected and has some movement then a quick capture Min/Max should get basic movement. But to get the best out of your rig and games you will benefit from spending some time refining this and other motion profiles.
  2. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    0C02B9AC-0BC5-49F0-A595-41F818F2DD90.jpeg D3B3B34E-0BCE-44D2-889C-4119F7D5D713.jpeg FE59D20C-ABF9-48A9-8100-1D8956142D68.jpeg E2E2CD19-DCF0-4060-9539-EE8960856017.jpeg 3A3D7038-91EF-42AC-B107-C87DC6FCEF0F.jpeg 6281929D-5DC0-4038-83A5-6FE5A705726F.jpeg 75F2737E-C712-444E-B399-4153AD95333E.jpeg
    No idea why it isn’t just working
    Screen shots attached of all settings
    Frustrating
    I use x4 standard SCN6 actuators
    All seems normal at start up , but just a minor odd sound of movement only during DCS running in plane
  3. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Need a screen shot of tools/ tuning center while running...
  4. Happy Cat
    Happy Cat New Member
    Russia
    304Coins
    Hi everyone. The platform does not work after the last update. I move the slider and the platform moves 1%. Is there a problem?
  5. Happy Cat
    Russia
    304Coins
    I removed 2.3.1 and returned 2.2.5. Now the platform does not react to the slider at all. I installed 2.3.1 again and the platform doesn't respond to the slider either.
    154,580Coins
    +11,190 / 57 / -2
    Did you uninstall the plugin before messing with SimTools installs?
  7. Happy Cat
    Russia
    304Coins
    No. What to do now?
  8. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    I’ll post tuning centre pic when I get a moment if that helps
    Not used my setup/DCS for a while due to this )-:
  9. yobuddy
    51,676Coins
    @Happy Cat,
    Please check that you have data coming in from the game in game engine's tuning center.
    Also check that your Min / Max numbers look correct.
    Then look over your Axis Assignments for the game.
    Maybe post some pic's or we can't do much buddy.
    Take care,
  10. Happy Cat
    Russia
    304Coins
    OK thanks! I've sorted out the settings. The problem is solved. A great update to the flight! I expected it. Anti-roll.
  11. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    B65EF1AE-8AD3-4E2A-A80A-4671FDADCBC5.jpeg Here’s my pic
    Not really messed with this tuning centre before
    The Min - Max figures are the same but I’m not sure how to change them —EDIT I notice bottom box has a minus next to it ,
    “capture max min” doesnt do anything ,
    data is coming nicely from the sim as lots of digit changes in top boxes
    154,580Coins
    +11,190 / 57 / -2
    You need to Capture Max Min, fly for a bit including doing loop and roll, Save New Settings and then tweak from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  13. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Hi Noorbeast
    I did that , but nothing happened ,
    I saved anyway then exited everything & re-started everything , still sane )-:
    But I’ll try it again to see if it works
    Big thanks for help
    Fingers crossed
    154,580Coins
    +11,190 / 57 / -2
  15. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
  16. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Fine with P-51
    But like before no data coming from the spitfire,
    Is this a bug in DCS ?
    Was kind of hoping updating to latest version would sort this but maybe it’s DCS’s fault ?
    154,580Coins
    +11,190 / 57 / -2
    I don't have the Spitfire, so hard to say if it is a plugin or game issue, but perhaps @value1 can comment further.
  18. Elii
    Elii New Member
    61Coins
    3DOF, Motion platform
    Hello Sir!,
    I have probleb with my rig flipping when rolling/banking doing barrel roll. I see you and other user have overcome that problem using "antiroll" settings. I cant find enything in my settings that would make this flip to go away. I tried to change gain and returne filter but its acting very streange in game. It results in my dof rig staying banked left or right while my plane is already horizontal in game. Could you please explane about "antiroll" for me. Thanks alot!
  19. T R Para
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Sorry about that.. It only appears if you select
    Axis Type:
    Generic 2d Advanced
    And that is in the Axis Assignment menu...
  20. Elii
    Elii New Member
    61Coins
    Thank you for quick reply. If possible can you make a screenshot ? Where is this option, how its called ? Is it one box or diagram. Im lost here =)
