Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. fuad
    fuad New Member
    kuwait
    23Coins
    hi...
    im facing problem with the vibe. im using 2 sound cards one mother board reltek for game sound and second external sound blaster for the game vibe.
    LFS is working fine for the vibe.
    the problem with other games like AC and PC2. every thing fine with the software. the vibe shows the RPM and other elements and also the game vibe tuning center shows the numbers but the problem the sound do not come from the shaker. maybe its a windows issue or steam????? any one have any idea???
    154,580Coins
    +11,190 / 57 / -2
    I have an issue with PC2, which for me does not register the game vibe plugins, but I expect that is a plugin issue.
    However AC works fine, so I am wondering about your tuning settings for it, if testing works fine and data is present in the Tuning Center.
  3. fuad
    fuad New Member
    kuwait
    23Coins
    yes the data are presented in the tuning center and testing the sound card from the vibe is ok.
    do you mean i have to do the vibe tuning center setting to make it work??? capture the H/L values???
    154,580Coins
    +11,190 / 57 / -2
    The Game Vibe volume needs to be enabled and set, plus capture then tweak H/L values in the Tuning Center.
  5. fuad
    fuad New Member
    kuwait
    23Coins
    @noorbeast thanx for the info .
    i checked the sound settings in windows
    for LFS game sound comming from the reltek sound card and game vibe from usb sound blaster
    for AC game sound ok but no vibe
    do you have any idea????
    154,580Coins
    +11,190 / 57 / -2
    There are no Hi/Low values set in the Tuning Center for Assetto Corsa, so run capture, drive a bit, save it then tweak as needed.
  7. fuad
    fuad New Member
    kuwait
    23Coins
    @noorbeast thanx its working now i will try it for PC2 and other games.
    cheers
    154,580Coins
    +11,190 / 57 / -2
    I am not certain but I don't think Game Vibe support has been implemented in assetto corsa competizione.
    154,580Coins
    +11,190 / 57 / -2
  10. Hocky
    Hocky Member Gold Contributor
    118Coins
    I have problems with getting sound out of Gamevibe for rpm and sqr.
    If I go sin it works but not sqr.
    When activating test I get no sound what so ever using sqr?!?
    What am I missing? Probably something obvious :)
  11. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Is there a DCS vibe plugin yet ???
    154,580Coins
    +11,190 / 57 / -2
    Not yet, but you can check out the new flight related improvements to Game Vibe using the War Thunder plugin, those cover: https://www.xsimulator.net/community/marketplace/war-thunder-plugin.176/
    Game Vibe types:
    Rpm - self explanatory
    Road detail - heave
    Turbulence - Speed + (Speed*flaps deployed*0,2) + (Speed*Landing gears deployed*0,2)
    Collision L/R - Sway
    Collision F/B - Surge
    Weapon1 - Weapon1 fire
    Weapon2 - Weapon2 fire
    Landing Gear - deploying/retracting landing gear
    Flaps - Deploying/retracting flaps
  13. Guus Franken
    Guus Franken New Member
    - 45Coins
    2DOF, AC motor, Arduino
    Hello
    Is it true that I do not have a vibe for gear shift with iracing?
    Guus.
    154,580Coins
    +11,190 / 57 / -2
    Have you configured it and can you please post a picture of your settings.
  15. Guus Franken
    - 45Coins
    RPM and Road detail works just fine....but I miss the kick in my back ;)
      779.1 KB
      604
      532.1 KB
      656
  16. Hocky
    118Coins
    I got the problem with the min sound is off...very loud and then off again. Very similar to the problem that was solved with the regional settings. For me changing the regional setting did not fix it. (Swedish initial)
    My initial problem with the sqr wave is still there to. Tried another sound card too. All other wave forms work (when listening on the sound).
    Is it just me or someone else experience the same?!?
    Thanks!
  17. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,057Coins
    Arduino, 4DOF
    I have been struggling several hours to get gamevibe working on a windows 10 enterprise because of the "unable to create form" error. The issue was not with DirectX but with the .Net framework 3.5 which is required by gamevibe and not installed by default on Windows 10. Installing it using the windows roles/apps/features kept failing.
    I finally had to install it using the ISO of windows 10 and an elevated powershell command :
    PS C:\Windows\system32> dism /online /enable-feature /featurename:NetFx3 /all /Source:E:\sources\sxs /limitaccess
    Outil Gestion et maintenance des images de déploiement
    Version : 10.0.17763.1
    Version de l’image : 10.0.17763.379
    Activation de la ou des fonctionnalités
    [==========================100.0%==========================]
    L’opération a réussi.
    In my ISO under sources/sxs I have for info:
    PS C:\Windows\system32> dir e:\sources\sxs
    Répertoire : e:\sources\sxs
    Mode LastWriteTime Length Name
    --r--- 06/03/2019 02:29 31331 Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~fr-FR~.cab
    --r--- 06/03/2019 02:30 1509278 Microsoft-Windows-NetFx3-OnDemand-Package~31bf3856ad364e35~amd64~fr-FR~.cab
    --r--- 06/03/2019 02:06 305497 microsoft-windows-internetexplorer-optional-package~31bf3856ad364e35~amd64~~.cab
    --r--- 06/03/2019 02:09 72729053 microsoft-windows-netfx3-ondemand-package~31bf3856ad364e35~amd64~~.cab
    Then reboot, re-install directX, and it works !
  18. yobuddy
    51,676Coins
    Can't you install it in "Programs and features" and then click "Turn Windows features on or off".
    In the window that pops up click .net framework 3.5 and press ok?
  19. vthinsel
    FRANCE
    6,057Coins
    Arduino, 4DOF
    No, it was failing with an error. This is on a windows 10 enterprise edition, which came pre-installed on the laptop.
    I couldnt find another option than going with this ugly command , which requires the install media.
  20. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi, I have two questions wrt GameVibe:
    Is it possible to use GameVibe with a PS4 ?
    If yes, how is the sound from the PS4 (or the game running on it) coming to the PC running Simtools and GameVibe ?
    Is it possible to test GameVibe somehow ?
    My simtools is running an a Macbook with Windows installed. Not sure if GameVibe supports this setup....
    cheers, Arazok
