SMC3 Arduino 3DOF 3-Phase AC motor Opto-Coupler shield ...
Discussion in 'SimTools compatible interfaces' started by speedy, Jan 7, 2017.
  1. lemaitre
    lemaitre Member
    - 111Coins
    yes, actually, I did not connect it, I will do it and test
  2. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Good day Speedy,I have allocated all the components for this build,excepting the z5 1v diode,the lowest I can get here is a 2volt diode,will that be okay to use?Thanks so much.
  3. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Sorry realized it was a 5.1v.Thanks
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Good day every one ...
    I didn't update the board layer for the last discovered problem yet "inverting the PWM signal " ...
    So please be aware of that you'll get a 10v out to the VFD where it should be zero ... that would make the motor oscillate and never give a stop on the target point .
    So sorry for that error ...
    Update is coming ASAP .
  5. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Well Hello Speedy,
    I'm sure you remember ol' Tom in Alabama. I have been waiting about 20 months now for you to send me the pcb you owed me. If you remember, I advanced you shipping to help you out.
    I still have the old pcb that did not work. I have gone to the "1280" board which is professional and has a lifetime warranty.
    I wish you well. Do Unto Others Friend as You Would Have Them do Unto You.!
    Tom
    PS to Administrator: Kind sir, if you look in the past to all of my posts, you will find that I have never posted a negative or derogatory statement / or / slander another member.
    This post was to a former friend that used me on several occasions and would never return my personal email's to him. This will be the "first and last" post making reference to
    this member. Thank you for your understanding and consideration.
  6. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Good day Speedy.Is the inversion of the signal needed,will the circuit work without it or should I wait for the update.Sorry my understanding of electronics is a bit limited.Thanks so much for your expertise.
  7. speedy
    Alexandria , Egypt
    7,943Coins
    Dear Tom @cthiggin ... really sorry for that huge delay in delivering your board or even updating the discovered error for all others ... As you knew I had major setback made me selling every thing even my precious equipment and computer :(
    You have all the rights to complain but Please keep spare me for a while ...
    Massaging you from an old friend's phone how's sending you his regards and best wishes
    Sorry buddy I wish I can make it up to you
    Please note I still have my old hard drive where every thing is stored there even my e-mail password which is totally forgotten
  8. speedy
    Alexandria , Egypt
    7,943Coins
    Good day @Llewelyn ... yes this error must be updated first otherwise it will cause oscillations in motion ...
    I hope I can update it soon and be able to upload it to the first post
    Thanks for your understanding
  9. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Oh okay,no problem,sorry to hear about all your equipment,wish you back on your feet as soon as possible.Regards.
  10. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Good morning, speedy would be so kind to provide me with the gerber file of the plate?
  11. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Good day Speedy,any update as yet perhaps..Thanks so much.If not its fine.:thumbs
  12. speedy
    Alexandria , Egypt
    7,943Coins
  13. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Hi finally got the AC motor connections figured out,so if anyone ends up on this page,here is what I did.
    Used the mach3 analogue convertor 0-10v (very cheap) and added a octocoupler circuit (also just two octocouplers and two resistors) for the two directions to connect to the vfd.Tried this on 3 different VFD's ,Mitsubishi rf-e720s ,Bonfiglioli vector and a allen bradley 22a.
  14. Jan van Velzen
    Jan van Velzen New Member
    Technician, Retired
    Netherlands, IJmuiden
    - 44Coins
    Verry nice, thanks for the scedule its just where i was looking for :)
    I am still in the prototyping fase for my 3/4dof + track loss with AC 3phase power.
    • Dislike Dislike x 1
  15. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    No problem,took me a while to get this figured out,a lot of information to sort through on the site:grin,but thanks to member Yobuddy's help :thumbsI got it done.Still having problems with sensors,using pots,I think they are not good enough for AC motors configuration,going to try hall sensors and see from there.All the best.
  16. Danielw
    Danielw New Member
    Self-employed
    Sweden
    - 16Coins
    I know this is over a year old thread, but i hope someone maybe can help me with the optocoupler circuit.
    As i did mention in my own thread in this forum i am trying to gather used stuff from scrapheaps and old broken machines for my first build. I have managed to get some old Yaskawa freq drives and from what i can see they have an output called "Multi-Function Photocoupler Output at 48VDC 50mA or less". Does that mean that this VFD already have a built in optocoupler i can use for arduinio or is it only an auxiliary voltage output for external circuits? Im uploading the schematic here also so you can see what i mean. VSminiwiring.png
  17. Viktor
    Viktor New Member
    C# Developer
    39Coins
    3DOF, AC motor
    I Would connect the Emitter (the Lower pin named PC) to ground, the Collector (the upper Pin named PA) to the Arduino Input und also use an Internal (or External) Pullup to +5V. :)
  18. Danielw
    Danielw New Member
    Self-employed
    Sweden
    - 16Coins
    Thank you for your answer:) So it could work without any external optocoupler shield and just use a D/A converter like the cheap Mach3 board for the PWM speed control. By the way. What do i need the +5 pullup for?
  19. Danielw
    Danielw New Member
    Self-employed
    Sweden
    - 16Coins
    I just realized that i missed one obvious detail. I still have to use 2 optocouplers if i want to be able to control one motor in both directions.
  20. Billel
    Billel Member
    195Coins
    What MODE of the SMC3.ino program did you choose to run this set up ? and did it work ?
