3 DOF SCN6 Simulator with traction loss
Discussion in 'DIY Motion Simulator Projects' started by highi, Oct 20, 2018.
  1. highi
    highi Highi Racing Simulator 17 Gold Contributor
    8162 Steinmaur, Switzerland
    133Coins
    3DOF, SCN6, Motion platform
    I finished my test with arduino and MecVel actuator. Although I was able to reduce the problem with the interferences with a ferrite ring in the engine supply, but the engine was too slow. Thank you all again for the help.
    I have decided to order another SCN6 actuator:) To my delight, he arrived before Christmas …
    The third controller and Motor mounted
    On each side the range is 19cm:grin
  2. Sebj
    Sebj Active Member
    Canada
    492Coins
    Nice job. Well thought out and well put together. Did you do a video yet?
  3. highi
    133Coins
    @Sebj Thanks! A short video I can offer, where man sees what's going on, if you drive a Porsche 911 GT3 R with disabled TC. I'll upload a better video soon.
  4. highi
    133Coins
    At this moment I would like to present my keyboard/mouse alternative. I have assembled a controller with an old iPad and the app "CCP". This is really a cool thing and working properly.
  5. kang.emil
    kang.emil New Member
    52Coins
    what motor did you used?
  6. highi
    133Coins
    My equipment:
    3x SCN6-040-200-AB-M
    1x Mean Well MSP-300 power supply
    1x USB-Com485 Plus2
    1x 485 to USB Converter
    1x emergency switch
    1x Playseat Evolution with Gear Holder and Seat slider
    1x Turn One Oreca Store Belts
    1x Fanatec CSL Elite Wheel Base
    1x Fanatec ClubSport Steering Wheel Formula Carbon
    1x Fanatec CSL Steering Wheel P1
    1x Fanatec Club Sport Pedals V3
    1x Fanatec ClubSport Shifter SQ V 1.5
    A lot of square tubes & threaded rods, screws and ball joints and of course a universal joint.
    And last but not least: a lot of work. But it has paid off and brings a lot of fun:grin
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    3DOF, DC motor, Arduino, 6DOF
    The Ipad idea is a great one. Nice work.
  8. highi
    133Coins
    An update to reduce noise and roll resistance.
    IMG_4883.jpg IMG_4885.jpg IMG_4881.jpg IMG_4887.jpg IMG_4912.jpg IMG_4910.jpg
  9. Jonas Canopee
    Jonas Canopee Tech & fitness geek, daddy, car enthusiast
    Graphics designer
    Berlin, Germany
    145Coins
    Looks promising, but I think roll is set way to high as if the car banks, or?
  10. highi
    133Coins
    A recent video from my simulator with traction loss
  11. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    Small suggestion. At the back, in the center, you could add an arm and a rolling ball that would press on the top of the moving plate, to keep it down when theres a big change off direction. Once in a while, your lower rolling balls lift up on a big move.
    Really nice rig.
  12. highi
    133Coins
    Thanks for your feedback. I also noticed that my substructure is too weak for these forces. I think I have to redesign it. Man must have something to do otherwise the project is over. Who wants that? Your idea with the arm is also an option, probably with less effort.
  13. highi
    133Coins
    My project has become much bigger (and more expensive) than I imagined. The result and the feeling justifies the effort. Adding traction loss has taken the whole thing to another level. Without TL, I have seldom been able to bring the car back when it breaks out. But with TL this is often possible because you can react when you feel it and not when you see it visually. In retrospect, I would probably first implement TL and only then sway and surge.
    At this point, it's time to say thank you to everyone involved in SimTools and this community! Everything here is just great ...
  14. Jonas Canopee
    Graphics designer
    Berlin, Germany
    145Coins
    How exactly is TL achieved mechanical wise. I can see tracks from what I think are two rolls...how does pulling (?) from the sides work? Really looking to get TL as well for my rig. Your implementation looks exactly right
  15. highi
    133Coins
    The substructure is stored in the middle in front, in my case on a caster without a roll.
    I have mounted behind the universal joint a linear motor which makes the movement sideways.
    This position is only possible with a motor that has enough power. Of course, there are other ways to implement the sideways movement. Just search for traction loss in this community.
  16. highi
    133Coins
    I have made some improvements:
    1. I have an arm and a rolling ball mounted in the middle of the back to prevent lifting of the substructure. (Thanks to Pierre Lalancette)
    2. I reinstalled the gear lever and built a tunnel console with the PCB from a WingMan Formula Force GP
  17. highi
    133Coins
    Another story that has nothing to do with my rig but may be useful to someone:
    After a few hundred kilometers, a threaded bolt broken from my Fanatec P1 steering wheel:
    IMG_4944.jpg broken threaded bolt
    IMG_4945.jpg original threaded bolt
    IMG_4950.jpg After the drill out and installing larger (M5) threaded bolts (Tubtara)
    IMG_4952.jpg Mounted with M5 screw gives optimum stability
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    Cool! I never though I could give any good design advise to anyone. This is great!
  19. seppel
    seppel Member
    k-town rhp
    224Coins
    2DOF, SCN5
  20. highi
    133Coins
    Yes, the part has enough power. The fan has never turned on. Therefore, I assume that the performance limit is far from reached. You always have to include the simultaneity factor.
