FlyPT 6DOF/Stewart/Hexapod Interface for linear and rotating actuators
Discussion in 'FlyPt Mover' started by pmvcda, Jan 2, 2019.
  1. pmvcda
    15,702Coins
    Version 1.7.4
    Download in the first topic...
    Small change in rounding for rotating actuators and more decimal places in % of travel.
  2. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    I see, If you can get accurately rotational and translational separation with this method you will reach your goal. I am curious.
  3. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    The string given by @Thanos is correct.
    <255><255><Axis3a><Axis4a><Axis5a><Axis6a><Axis1a><Axis2a><0><0><0><0><10><13>
    I don't have much time to test in details but from what I see, the scaling math seems to work well.
    Good job !
  4. pmvcda
    15,702Coins
    Thank's.
    What do you think of the roll over?
    It should be used with the washout filter to avoid reaching the rig limits.
    It's just a low pass over an high pass filter. Seems to work good, but since I get the idea you are more of an air plane sim user, this is something crucial.
    Would like to have your opinion.
  5. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    I am not so far yet.
    Tell me, is there something you can do to make the return of your washout, band pass, less grainy?
    Can it be that the resolution is quite low or there is something wrong tuned in my servos?
    Is it suppose to use all 16bit steps?
    Slower it gets more steps I can feel. Do you understand what I mean ?
  6. wannabeaflyer2
    london uk
    8,351Coins
    Hi @pmvcda just wanted to add to the other guys, I finally Got my AMC Barebones Interface to Work with You Program and im currently testing The setup using Optical encoders and @Thanos Encoder2pos Interface ,
    Almost there with Full speed actuator operation, and Your Program Connects everytime so im in a good place again thanks to a lot of help from The Crew LOL , Still have one last snag whilst testing issue, with what seems to be Lost Encoder Position.
    When I Rapidly Move an Axis Cursor rapidly back and forth to simulate high speed actuator motion, But as with most of my self inflicted Issues, I need to find out what connection I missed of maybe fit A decoupling cap somewhere in case its noise .
    Both your FlyPThexpod and BFF and maybe simtools Output test sliders show the same lost position Condition, So im determined to find the Cause and then roll out this Actuator (with Optical encoder) to all my Other Actuators .
    Will Post Video at some point , but thanks again for making this Program available , hopefully a better update next time but wont clutter your Post..
  7. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Hi again,
    Would you agree to change your simtools interface to follow simtools AND heXpod dof interface order?
  8. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    There is something strange in your comport speed.
    When you choose 10ms it becomes extremely jerky. The transmission is certainly not updated 100 times a second.
  9. pmvcda
    15,702Coins
    Sorry, I'm seeing the notifications, but I'm with a big load of work right now.
    I will take a look later.
  10. pmvcda
    15,702Coins
    I will make it optional.
    Relative to the problems you are reporting, I was making a scan on the code, and found....
    A really stupid error in rotating actuators calculation.
    There was a loop of an old test code that made the calculation repeat multiple times (bigger the angle, more repeats :eek:).
    I'm correcting it and will post a new build.
    I'm also taking the chance to optimize the calculation formula.
  11. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    If it’s not unified It can lead into a nightmare while sharing presets and config files.
  12. pmvcda
    15,702Coins
    I'm just reordering the controls.
  13. pmvcda
    15,702Coins
    Version 1.7.5
    Go to first post for the download.
    New version with:
    -Optional order of pose components. Changes the order of the controls to match the Simtools order.
    -"Unrolled" some maths of the equation for solving rotating actuators. It's now faster.
    -Removed an old loop forgot in the rotating actuators code.
    -Changed some parts of the code related to serial output. Still needs optimisation, but the thread where it runs is better.
  14. C1500
    C1500 Active Member
    1,119Coins
    AC motor, 6DOF
    Hi FlyPT
    I had only short time for testing.
    But...
    Only one thing happen when I press on the start button.
    The Rig goes in lowest position an stops there.
    There was no movement on any slider activity
    I copied the *exe over the existing one.
    The last Version i used was 1.7.0
    Do I have to configure it completely new in every new version or can I use my settings from the older version?
    Hopefully I got more time this evening.
    Kind regards
    Peer
  15. pmvcda
    15,702Coins
    Old config should work.
    But you can load the old one and save a new one to remove the garbage (some values where removed from the config).
    Look at the left down corner and see if you have "Lock in lowest position" checked.
    Even if it's not checked, try to change the value and see if it works.
    Also, confirm that the serial config is OK.
    I will take a look to see if there's something wrong, but I was receiving data in my test.
  16. grgdnsvr
    grgdnsvr New Member
    40Coins
    Thank you @pmvcda so much for your reply. I can get some values now. I realized that i had been using an older version.
    Now i have another question. I can't relate the interval with the frequency of output that i got. For example, i use 5 ms interval for 160 seconds of motion but i got around 2000 lines of output. Is it possible that there is a problem about the interval option? or maybe it's something about the sniffer i use.
  17. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Very good improvement. Keep up your good work!
  18. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Do we need to update the interface dll as well?
  19. pmvcda
    15,702Coins
    No, there's no changes in the plugin.
    Did you try the serial communication?
    @C1500 had problems, just to confirm if it works for you.
    Thank's!
  20. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    - serial communication got better,
    - the dofs fits the simtools order.
    The washout still returns in a bit jerky way but it could be my Pid/servo accel parameters.
    Or serial speed, or output resolution, No idea.
    You could maybe try to isolate on a single core.
    Maybe it makes sense in your case
    If you like you could dig into it on your side.
