value1
Live For Speed Plugin 1.0.1.1
SimTools plugin for Live For Speed
  1. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    96Coins
    Good morning at all. I'm trying to uninstall simtools and reinstalling it and follow all of the points of the guide. Try to unpatching... repatching... etc etc but the problem still the same.
    151,979Coins
    +11,061 / 56 / -2
    There has been one report of the LFS config file causing a similar problem: http://www.xsimulator.net/community/threads/new-french-with-a-question.7265/#post-85277
    There is also a bug with SimTools and some language settings, try this: http://www.xsimulator.net/community/faq/udp-games-produce-no-output-data.181/
    Are you running any antivirus or firewall software that may interfere?
    If all else fails as the LFS plugin is bundled with SimTools you could try unpatching LFS, uninstall SimTools, do a reboot and reinstall SimTools.
  3. Stealthelius
    Office Clerk
    Rome, Italy
    96Coins
    Hi @noorbeast i've solving the problems. I've select a "Live for Speed" profile in tuning center and re-launch Game Engine and Game Manager with admin rights.
    But now i having another kind of problem....
    When i test a track, the movements of my wipers is too high and too reactive... i've just trying to lowering the force and axis percentage. Any suggestion?
    151,979Coins
    +11,061 / 56 / -2
    Use @bsft's guide to set each of the forces individually, starting at 20% with sway then surge: http://www.xsimulator.net/community...-set-up-simtools-jrks-and-write-profiles.112/
    When you have them sorted set base tuning values in the Tuning Center: http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
    You can the and then tweak the values further with` a bunch of other tuning and refinement tips: http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    If you get stuck shoot a video that shows the movement of the rig and the game at the same time and post it here with screenshots of your SimTools Axis and Tuning Center settings, that way the members can give you further advice.
  5. Stealthelius
    Office Clerk
    Rome, Italy
    96Coins
    Now it's all functionally. I've selected the "Save new settings" button and all goes fine. Thanks for support
    151,979Coins
    +11,061 / 56 / -2
    151,979Coins
    +11,061 / 56 / -2
    A new version of LFS, version 0.6P, has just been released, with integrated VR support for the Rift and Vive, plus omproved controller support: https://www.lfs.net/patch-6p
  8. value1
    15,025Coins
    This resource has been removed and is no longer available for download.
  9. vardar
    vardar Her Sabah Özgürlüğe Doğar Fenerbahçe
    Teacher
    TURKEY
    159Coins
    Merhaba, bu harika sim dünyasında yeni bir girişim. Simülatörle çok ilgileniyorum. Yeni başladım ve SimTools'u öğrenmek ve test etmek istiyorum , ancak hız eklentisi için canlı yayınlayamıyorum. Yeterli para yok. :( Ne kadar çok jeton indirmek istersiniz? :(
  10. vardar
    Teacher
    TURKEY
    159Coins
    Hello, this is a new venture in the wonderful sim world. I'm very interested in the simulator.I just started and want to learn and test SimTools, But I can not post it live for the speed plugin. :( There is not enough coins. :( How much coins are required?
  11. value1
    15,025Coins
    You don't need to download a LFS plugin. This is already built into Simtools.
    Just patch the game.
  12. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Ciao @value1
    After many years I reinstalled LFS to do some experiments using a mini reference system (photo :grin) and SimTools 2.3.1.
    Game Manager changes to blue, but I do not receive data from the game (virtual axes do not move).
    Is it possible that the 1.0.1.1 plugin is not compatible with the latest LFS release? (LFS_S3_6U).
    Or Simply the plugin 1.0.1.1 is not compatible with SimTools 2.3.1?
    Thank you :thumbs
  13. noorbeast
    151,979Coins
    +11,061 / 56 / -2
    Did you run a race in first person mode before patching LFS for motion?
  14. ilbiga
    Network Engineer
    103Coins
    Ciao @noorbeast
    Thank you! You're right! :thumbs
    I had forgotten the need to "capture game data" before patching! The problem is surely this!
    I have been using only the RIG PC for many ears and I'm rusted! :grin
    I will check as soon as possible.
  15. ilbiga
    Network Engineer
    103Coins
    Problem solved! It was very simple! o_O
    New tests started! :cheers
    Thank you @noorbeast
  16. gglavina
    gglavina New Member
    Brazil
    76Coins
    Hi, I need to take a doubt, I read in the forum that the plugin test of live for speed is no longer available, would have another method to get this plugin? because I am graduating in mechanical engineering and the sim is my graduation project, only the plugin is missing so I can finish the tests. Thank you and I await your response.
  17. ilbiga
    Network Engineer
    103Coins
    Ciao @gglavina
    The Live For Speed plugin has always been included with simtools.
    I think it's still like that. Have you already downloaded simtools 2.3.1?
    If nothing has changed, you will find the plugin already active in Game Engine & Game Manager.
  18. gglavina
    gglavina New Member
    Brazil
    76Coins
    @ilbiga I downloaded simtools 2.3.1 and the plugin did not come, and I also can not find this plugin anywhere. I already spent a lot of money on this project and since I live in Brazil, the license is very expensive, if you convert.
    151,979Coins
    +11,061 / 56 / -2
    The LFS plugin is bundled with SimTools and it can be found in the drop down Game List interface in Axis Assignments.
    If the LFS plugin does not show then there is likely something wrong with your SimTools install. So uninstall SimTools and delete the folder C:\Users\your_user_name\AppData\Local\SimTools
    Download SimTools and re-install: https://www.xsimulator.net/community/marketplace/categories/simtools.37/
    DIY builders can request a free DIY SimTools 2.0 license, conditions apply, see here for details: https://www.xsimulator.net/request-diy-key-simtools/
  20. DarkHunter82
    DarkHunter82 New Member
    96Coins
    hello, i'm new DIY builders... all is done...2 dof...but i need some help
    SMC3 is works perfectly. now i download simtools and try to play Live for Speed: the wipe motors move manually in the output testing section but not in the game. i have patched it but i don't receive info in the app from the game.
    i see is the same problem from other people.
    thanks in advance for the answers.
