Tutorial Mjoy16 USB AVR Joystick
Discussion in 'DIY peripherals' started by tronicgr, Jan 3, 2008.
  1. Senetor
    Senetor Member
    Australia
    595Coins
    • Pcb.pdf
      11.1 KB
      1,713
  2. erecek
    erecek New Member
    0Coins
    I have built the Mjoy16. PCB and my soldering looks fıne. Also had no errors with the programming (Ponyprog).
    The version I built is the latest one that Senetor posted. (53x54mm basic)
    However problem, under device manager Xp shows 2 USB human interface devices. One of them seems fine. The error message under the other is : Windows has stopped this device because it has reported problems. (Code 43)
    Cannot find a solution yet, any ideas.
    If anyone wishes I can post the photo of my problematic Mjoy16
    Thanks.
  3. Sokol1
    Sokol1 Member
    14Coins
    After transfer the .HEX, the Security and configuration bit was done correctly?
    http://www.powernet.pl/~krzysiek/elektr ... 20Bits.jpg
    The majority of cases in failure after programming, refer to Security and configuration bit or bad solder/tracks in short. Put special attention in solders of crystal and associated capacitors.
    If you have a good cam, take a photo of PCB from solder side.
    You can try reset the ATMEGA and program again.
    Important - If using LPT1 cable after programing:
    1- Disconnect USB cable (acting as power source)
    2- Disconnect LPT1 cable
    Reverse order has the risk of lock ATMEGA clock in 1 MHZ
    3- Remove LPT1 plug and connect only USB plug an see if
    recognized as MJ16.
    Sokol1
  4. erecek
    erecek New Member
    0Coins
    Hello Sokol1 and rest of the forum,
    Thank you for your advice. However I believe the problem is not with the hard ware or the fuses. Fuses are correct as it is mentioned in the manual.
    The problem is not recognition. Windows recognizes the device actually. But for a second or two. Then passes to code 43 error state.
    I have used some usb diagnosis tools it is recognised as MJ16. A couple of seconds later yellow mark appears next to it.
    Then I opened game controllers setting windows from control panel, kept it open and plugged the device in. It lists the MJ16 with status OK. 2 seconds later disappears.
    Before it disappears I see the 32 buttons and 8 axes then there is the message says :
    your game controller is not connected correctly. Please verify it is connected to your computer.
    I dont understand. The Mjoy 16 gets recognised, installed, shown under game controllers. I see the axes wiggling, 32 buttons, the hot switch, then disappears.
    Any ideas why ?
    Thanks.
  5. Sokol1
    Sokol1 Member
    14Coins
    I suggest that you test this Mjoy16 in another computer, to see if really work OK, sometime Windows did strange things with USB ports...
    Try go to Regedit, search for Mjoy key and delete this, an plug Mjoy16 again.
    Another cause of problems, bad quality USB cable, I try reuse some mouse and
    keyboard USB cables :roll: and get not recognize...
    Sokol1
  6. Frakk
    Frakk Active Member
    328Coins
    Could you post a picture of the pcb, components, and soldering? It is most likely a communication error. Did you use a 12MHz crystal? Are you placing the board on an insulating surface when you plug it in?
  7. erecek
    erecek New Member
    0Coins
    Hello Forumers,
    I got it working at last, but not sure why it did not work in the beginning.
    Installed libusb32 then disappearance stopped.
    Funny thing it is still working after rebooting my deepfreeze protected laptop? Never changed the cable or fixed any soldering.
    Do you think that the problem was ungrounded pot ports which were not in use? If so can this be fixed by some additional component(s) to the board?
    I have tested all the pot ports. And a few buttons by shorting some colums and rows. They are working fine.
    One thing I did not quite undertand is the rotary swich. Suppliers here ( Istanbul TR ) did not understand what I meant.
    Can anyone post a photo of a rotary switch we should use with Mjoy 16 please?
    I have noticed that 10 bit resolution was not possible with a 5K and 10K pot. 100 K goes from -512 to +512. Senses even a touch.
    Now should begin building the matrix board.
    Thanks.
  8. Sokol1
    Sokol1 Member
    14Coins
    You need a Rotary Encoder - Mjoy16 support four, in two mode each.
    http://cgi.ebay.com/12mm-Rotary-Encoder ... 1|294%3A50
    To test, if you have a defective mouse, take this scroll wheel, this is a mechanical encoder (incremental type, I think, another type is absolute).
    http://img518.imageshack.us/img518/5771 ... r11ku9.gif
    Plug in Column1 and 2 and in Row K
    Don't forget SVMapper to see buttons upper than 32, since its Mjoy16 dont't have MODE jumper.
    Sokol1
  9. Senetor
    Senetor Member
    Australia
    595Coins
    I have Updated the previous post of the Basic MJoy16-16 PCB with a version that has INIT, Mode and Centre jumpers on the PCB board.
    Senetor.
  10. jeffreymstrong
    jeffreymstrong New Member
    0Coins
    OK, I can be considered a hobbiest at best when it comes to electronics. But looking at the updated Basic MJoy16 the INIT button and Mode button pads appear to be open. Is it wrong or am I?
  11. Frakk
    Frakk Active Member
    328Coins
    Those pads should be connected to row L.
  12. Sokol1
    Sokol1 Member
    14Coins
    In some revision of PCB, has a diode (1N4148 type) between these jumpers and row L (anode toward row L).
    In fact the are in original Mindaugas Key Matrix scheme:
    http://www.powernet.pl/~krzysiek/elektr ... rix_v1.pdf
    Using Key Matrix put the jumpers in J1 connector 1-2, 3-4, 5-6.
    Note the 10k resistor bridge between Columns and VCC. (LOL - I never note this detail before in Mindaugas scheme). :?
    See in this topic (in Russian), user swed say that although it is using all the required diodes in buttons - without the key matrix card - ghost buttons appeared.
    http://www.protu-154.com/forum/viewtopi ... &start=360
    Sokol1
  13. Senetor
    Senetor Member
    Australia
    595Coins
    Sorry for the mistakes in the previous post on the MJoy16-16
    http://www.x-simulator.de/forum/post17546.html#p17546
    I was having trouble with Adobe Acrobat, ( Print Spooler ) and could not get things to print and was running out of time and that's when you make mistakes. I have updated the files and they should be right this time. ( Measure twice, cut once.) so to speak.
    Mindaugas had two projects over the years, which were both called MJoy16. The first one used the ATmega8-16 and the second used the ATmega16-16 AVR which he called the MJoy16-C1. Hope this will save some of the confusion with some of the Schematics that people are finding on the internet.
    Senetor.
  14. Sokol1
    Sokol1 Member
    14Coins
    Sorry for obvious question:
    With AVC programmer, the +5V VCC in PCB is not used, correctly?
    Picture loaned from Erecek. :)
    In this case power for Mjoy is get from USB cable, like with LPT1 cable?
    Imagine that this VCC pin is useful for those that have professional programmers, but don't offer risk for one first time builder, if make mistake in plug cable?
    I think in build these AVC programmer, I have used successfully a LPT1 cable from Mindaugas scheme, but some times I got -24 int error and in 5 Mjoy no one was .HEX transferred in first try... :?
    And suggest the use of this programmer for a local DIY forum.
    http://forum.clubedohardware.com.br/mjoy-atmega8/472888
    Sokol1
  15. Senetor
    Senetor Member
    Australia
    595Coins
  16. mohsenk
    mohsenk New Member
    21Coins
    Hi guys ! I have a question about the potetiometers !
    I've bought some 10K potentiometers but I have a problem in my mind.
    Here it is : If the potentiometer knob is in the lowest position ! the resistance between the VCC and the output is 0.0 ohm. I read this on my ohm meter. So is this going to hurt the chip or not ?! cause this is short circuiting actually.
    If so, what should I do ? place an additional resistor in serie with the potentiometer ?
  17. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Nothing, it wont harm chip.
  18. Frakk
    Frakk Active Member
    328Coins
    As Mambo said it won't harm the chip because the ADC has a very high input resistance. It is however a good practice to place a current limiting resistor in series with any input, just in case.
  19. mohsenk
    mohsenk New Member
    21Coins
    Thanks for your replies. If it doesn't harm the chip is it going to harm the pc or not ? Since it's a bus powered device and pc can only provide 500mA. If the resistance get to 0 between the Vcc and GND what will happen ? Where it can get the current from ? Sorry if my question are basic, I'm really new in the electronics.
    I really like the Frakk's latest design ( The All in One Solution ). I think it's really great. However I have built the MJoy16 board based on the pcb layout which mindaugas had provided in his website. But the pc does not recognize it but I have managed to program the chip using the ISP terminal on the board which means both chip and board are working. I programmed the chip myself with a testing program ( test if all the pins are working by means of a multimeter ) which I wrote with WinAvr. I don't know what's wrong with the board. The only items which I couldn't provide as described in the manual were the 3.3V zener diodes which I have used the BZX85C instead.
    ( Here it is, sorry about the bad quality )
    So I want to build another board again, and I found these two layouts ( Frakk's all in one & Senator's layout ). I liked the Frakk's design but I don't know which one to build. Please recommend me one of these. I really need this MJoy16 on my project.
    One more thing, the supplier told me that the BZX85Cs are 1 watt ( and 3.3V as it's written on the diode ) so is it ok to use this or I should look for the 1N4728 ? I don't think if I can find the 1N4728 here easy so please tell me some other part numbers which I can use instead.
    Keep the good job going guys !
  20. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Nothing bad happen to the chip or PC . There is no short circuit the chip has own resistance.
