Simtools and SimHub DashBoard no working
Discussion in 'Official Companion Apps' started by Djules, Oct 13, 2017.
  1. yobuddy
    51,558Coins
    Look at the post above yours ;)
  2. Leandro Kemp
    Brasil
    - 10Coins
    Yes.
    In Dirt Rally and Dirt Rally 2.0 worked by following the tips from the post above. Each application uses a port.
    In F1 both applications use the same port 20777 and so the system prioritizes what was first opened causing conflict when opening the second application.
  3. yobuddy
    51,558Coins
  4. Leandro Kemp
    Brasil
    - 10Coins
  5. bruno1210
    bruno1210 schumi06
    103Coins
    hello, they must use a software like Codemasters Proxy Server for f1 2018 but for f1 2019 does not work
  6. bruno1210
    bruno1210 schumi06
    103Coins
  7. Jasiek
    Jasiek New Member Gold Contributor
    - 43Coins
    Thank you! It worked.
    Worth mention u need also change the Documents/My Games/Dirt Rally 2.0/hardweresettings/
    hardwere_settings_config.xml file to:
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="20777" delay="1" />
  8. Kashif Saeed
    Kashif Saeed New Member
    49Coins
    2DOF, 3DOF, 6DOF
    hello there,
    i am new in simtools and simhub.
    i tried to use both of them at the same time using Arduino but simtools is not providing any output values and i did not find simtools com port in SimubWPF.exe.config.
    looking forward for the solution.
    TIA.
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    simhub works with proprietary codes and only a feel restrict list of games accept telemetry !
  10. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    Thank you @paulopsx2 for the reply.
    I was testing both on the LFS withthe demo mode of Simtools.
    Now, i purchased the professional license of Simtools and tried both simhub and simtools for dirt rally 2.0 by adding the line in configurations xml file and project cars 2, both of simtools and simhub working fine on both games.
    Still working on my platform and will reply after the final test.
    TIA
  11. paulopsx2
    brasil
    648Coins
    simhub offers support for pc2 and dr2
  12. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    @paulopsx2,
    You tried simhub and simtools togeather on Forza Horizon 4?
    Both of them work with the FH4 togeather?
  13. paulopsx2
    brasil
    648Coins
    yes, both are suported on simhub.
  14. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    Has anyone figured out how to have F1 2019 to work both SimHub and Simtools?
    Every other game I have from Codemasters works but this one. I wanna get F1 2020 but worried its going to be the same issues at F1 2019.
  15. bruno1210
    bruno1210 schumi06
    103Coins
    hello, for which games ?
  16. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    hy friend ca help me? i can't try line of inibite the por of simhub!!
    thanks
  17. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    now you can exclude com ports in simhub app.
  18. pfm21
    374Coins
    thanks friend i try it
  19. wolfdasi
    wolfdasi New Member
    36Coins
    Hello
    I have the same problem with Forza Horizon 5.
    if the verain works in simtool
    SIM Dashboard no longer works
    I am also looking for a solution
    sorry for the english translation
