Tutorial How to write a Game Plugin for SimTools 2.0 - API documentation
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Sep 23, 2016.
  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
    ok, thanks guys, I will do that as well.
  2. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Another question: What is the unit (degree ?) of the values like roll, pitch, yaw sent back to GAmeEngine ? I heard something about a min max file. Where is this described ?
    thx, Arazok
  3. yobuddy
    51,527Coins
  4. Arazok
    Arazok Member
    Computer scientist
    783Coins
    @yobuddy: Sorry, I am lost. Of course I know the simtools user manual, but where is written, how the values for a plugin must be ?
    And where (which page?) is the min max file described, which must be part of a plugin zip ?
    Thanks for any help appreciated :)
    (maybe I am blind!)
  5. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Best is anyway to reset the min/max when you install a new plugin to make sure it suits your driving style and rig. Plugins may come with max/min in the zip file... or not.
  6. yobuddy
    51,527Coins
    Here you go buddy!
    Page 26, Conventions for Game Plugins.
    Page 75 - 80, is the Min Max stuff.
  7. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Thx man, I overlooked it and wasn`t aware that with the min/max stuff also the tuning center is meant.
    *thumbs up*
  8. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi, I wrote a small test plugin by using C# template.
    When running the PluginValidator.exe it says "Test_GamePlugin.dll NOT valid!"
    What is the validator checking ? Is there a log file with more explanation what went wrong ?
    All the interfaces are implemented (as far as I can see).
    cheers,
    Arazok
  9. Arazok
    Arazok Member
    Computer scientist
    783Coins
    can nobody answer this ? Who wrote the pluginvalidator.exe ?
    @yobuddy ?
  10. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    You probably didn't go through the project settings a per the documentation. project name, assembly name, root namespace, etc.... all that must be aligned.
  11. Arazok
    Arazok Member
    Computer scientist
    783Coins
    You are right, as the c# template is provided here in this thread. I didnt changed, just compiled it. No one else uses the c# template ?
  12. yobuddy
    51,527Coins
    I personalty have not played with the C# template.
    So it's hard to say exactly what is keeping it from compiling.
    I bet its something small thou, maybe peek at a VB example and you will see what missing?
  13. Arazok
    Arazok Member
    Computer scientist
    783Coins
    No, it is compiling. But the validation check with the plugin validator says it is not a valid plugin dll... Why ?
  14. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Maybe you should @llluis as he is the one who made the C# template. "official" plugins are in VB
  15. yobuddy
    51,527Coins
    Because it was not unable to load the file as a plugin.
    It's missing something...
  16. Arazok
    Arazok Member
    Computer scientist
    783Coins
    ?? I don`t understand.
    To compile the C# template, you need to add the existing Game_PluginAPI.dll to the project.
    Then it compiles. But - as said - it isn`t validated, even if all of the interfaces are implemented (as far as I can see).
    Would be helpful to get more details about why the pluginvalidator throws an error...
    If needed, I can provide my compiled dll here.
  17. yobuddy
    51,527Coins
    Use any of the official plugin examples and they will compile buddy.
    Or give @llluis a shout, as he may know whats going on, take care!
  18. llluis
    Quebec
    1,632Coins
    Downloading and installing Visual Studio so I can have a look for you @Arazok
  19. llluis
    Quebec
    1,632Coins
    Hello @Arazok, I recompiled the files from zip
    and ran PluginValidator.
    So, something you changed broke the code.
    What did exactly you do?
  20. yobuddy
    51,527Coins
    thanks @llluis for testing this buddy!
