Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.3.0.0 pointer update
  1. Torsten Böhnen
    Torsten Böhnen New Member
    - 90Coins
    and no error message
  2. Torsten Böhnen
    - 90Coins
    [QUOTE = "noorbeast, post: 177431, member: 10786"] Dann geben Sie bitte weitere Informationen zu Ihrer Rig-Hardware an und veröffentlichen Sie Bilder aller Ihrer Einstellungen. [/ QUOTE]
    Die H3 Consumer Motion-Simulatorplattform von DOF Reality
  3. Torsten Böhnen
    - 90Coins
    Ich könnte Teamviewer anbietem
  4. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,295Coins
    Elite received the update, I'm working on the new pointers. no ETA.
  5. Wagnard
    Wagnardsoft
    5,295Coins
    Here is the updated pointer for the ship only atm.
    Still working on the SRV.
    In the mean time, if you guys can test that the ship is working correctly it would be great. Once everything is confirmed working, I'll probably update the main plugin with the XML and some performance enhancement.
    • Like Like x 6
  6. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    919Coins
    3DOF, Arduino, Motion platform, 6DOF
    Just had a fly about. All good moves on the ship. Many thanks
    @Wagnard - quick work!
  7. Wagnard
    Wagnardsoft
    5,295Coins
    Thanks , I appreciate the confirmation !
  8. Wagnard
    Wagnardsoft
    5,295Coins
    Here is the XML with SRV support. I'm pretty sure it will not work for all as I had limited time for testing.
    Let me know of the result.
    If it doesn't work, be sure you try to go to SRV and back to ship, then back to SRV again. ( a known issue with the plugin itself fixed in a upcoming version once we are sure pointers are good.)
  9. Torsten Böhnen
    - 90Coins
    does not work for me Game Starts Game Manager Closes without error message
  10. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Haven't tried the update or your file yet but just wanted to say thanks in advance! If I forget :)
    07
  11. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Do other plugins work for you? Did you install ES on drive C or something else? vileich if there is a possibility to try on other PC or notebook?
  12. Vitalius
    Bonn
    540Coins
    Hello everybody. Is there a way to invert Axis? For me, the ring moves the ROLL in the wrong direction.
  13. noorbeast
    153,944Coins
    +11,158 / 57 / -2
    The Dir box in Axis Assignments being checked orange or not determines which way each axis moves. Sounds like you need to reverse whatever you have for roll.
  14. Wagnard
    Wagnardsoft
    5,295Coins
    Check in the plugin folder (usually c:\users\your username \appdata\local\simtools \simtools pluhin\
    Check if you have a file named wow64ext. DLL if so remove it. (backup. It before)
    Also be sure you are on latest simtool
  15. Torsten Böhnen
    - 90Coins
    [QUOTE = "Vitalius, Beitrag: 177507, Mitglied: 30381"] Funktionieren andere Plugins für Sie? Haben Sie ES auf Laufwerk C oder etwas anderem installiert? Vileich, wenn die Möglichkeit besteht, einen anderen PC oder ein anderes Notebook auszuprobieren? [/ QUOTE]
    JA auf Laufwerk C Im Standart Ordner .andere Spiele Laufen Prima
  16. Vitalius
    Bonn
    540Coins
    Hello, could test everything on SRV on the fast. Everything works fine. Thanks for a quick update!
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    First, Merci Beaucoup Wagnard.
    Some observation. The up down left right thrusts are reacting quite a lot, compare to the principal joystick. I guess this is configurable. Did not look into your xml file yet.
    The SRV cannot be use for me. The surge and heave are way too strong (probably so is the sway). I guess it can be calibrated too.
    The main movements are a bit choppy. I'm not sure what's causing it. It can come from so many sources.
    I'll take any tips.
  18. Wagnard
    Wagnardsoft
    5,295Coins
    Yes this can be calibrated via XML, but I'll do probably more test when I have some free time.
    Also, on what windows version are you? May update or October?
  19. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    Is this what you are asking for? I'm not sure.
  20. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    One other observation. When using the down (same for up, left and right) thrust, the release of it does not go back to zero. Lets say I put the thrust at an hypothetical value of -20, when I release it, it goes straight to +20 before going back to zero. Kinda strange. Thrust compensation? Not really good effect on sim.
