Question help with 6 DOF platform
Discussion in 'Commercial Simulators and Peripherie' started by Billy Flores, Dec 22, 2017.
  1. Chican3
    Chican3 New Member
    125Coins
    Is there any way i would be
    @Thanos Is there anyway I would be able to purchase the necessary hardware to do my own conversion?
  2. Skullcrab
    Skullcrab New Member
    VR Developer
    USA
    149Coins
    At least they gave him something! Our contact refuses to help.
  3. Skullcrab
    VR Developer
    USA
    149Coins
    Well now! Your spec sheet helped me out a whole lot. We have successfully controlled our vegafu setup dynamically!! Where did you source your Vegafu SMC from?
    Here's the hiccups we ran into, and it may be unique to our model but maybe it can help you out.
    -our source port had to be UDP 8410 otherwise it wouldn't respond.
    -our Vegafu had a static IP of 192.168.15.201:7408 (UDP)
    -by studying existing functionality, we built a test app that was rate limited to 50ms intervals with no more than a 2.7% delta
    Also, @Thanos that spec sheet has a 6DOF mode in it as well as 3DOF mode.
    Essentially what you want to do is is look at Example 1 in your spec sheet. check out the highlighted boxes.
    1301 -absolute time mode
    0001 - 6DOF mode ( if this is 0, it's in 3DOF mode)
    00000000 - This part is not highlighted, but it's the 4 hex values right before the first 0000c350 value. This is the time value. It's in milliseconds (converted to hex). In Absolute time mode, the vegafu goes to the position as fast as possible. You must constantly increment this as it's used for error checking. (i.e. if you sent it something with a time code of 50, and then it receives a time code of 25, it's going to ignore it)
    0000c350 - this is the position on the cylinder you want to move to. In this case, 25mm (based on the math in the paragraph above).
    If it wasn't clear, you're sending this via UDP network packets to the SMC.
  4. Epseni
    Epseni New Member
    - 27Coins
    Is there any progress with Vegafu and possibly connecting it to Simtools? If not, what is the current best practice to control Dorna M1 that is compatible with Simtools?
    I am considering buying a chinese 3DOF simulator with Vegafu and it's likely to have Dorna setup too.
  5. Thanos
    Electronics Engineer
    2,854Coins
    Its more likely to use a AMC controller like this one connected to the Dorna servos: https://www.tindie.com/products/Tronicgr/amc-aasd15a-servo-motion-controller/
    ...than simtools supporting Vegafu...
  6. Thanos
    2,854Coins
  7. John Karuma
    John Karuma New Member Gold Contributor
    - 71Coins
    Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
  8. John Karuma
    - 71Coins
    Do you have documentation for the Dorna EPS M1 drive? I have a 6DOF using the same Vegafu controller and EPS servo driver. Already bought Thanos controller but I am getting an error on one of my driver ops. E28. Anyone?
  9. Thanos
    2,854Coins
    Looks like motor stall issue. See recommend actions:
    Thanos
  10. Thanos
    2,854Coins
    Also did you set the M1 parameters as in the github? Make sure the DB25 cables to 44pin, are also correct.
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/DornaM1_interface
  11. John Karuma
    - 71Coins
    Awesome, thank you Thanos
  12. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    all this great stuff and using a G29? i hope you have an upgrade in the future. i have read or heard that a G29 makes you faster on the corner.
  13. thyronn power
    thyronn power New Member
    2Coins
    hi can you help me
  14. Huzaima
    Huzaima New Member
    4Coins
    I am working on the same project containing the same components as yours. I have assembled the hardware but cannot program the controller. I have a Vegafu SMC_X24 controller. Can I get your help programming it?
    152,009Coins
    +11,061 / 56 / -2
  16. Huzaima
    Huzaima New Member
    4Coins
    Hello Ashraf. I am also working on the same controller, facing Err 1 in the controller. I need help in resolving the error. I also have the manual of this controller. I am sharing the manual here plz help me to resolve this error I have tried alot but failed to resolve this.
    - Manual is attached here
  17. Huzaima
    Huzaima New Member
    4Coins
    Here is the manual of the Vegafu SMC X24 controller
