My 6 DOF with ODrive
Discussion in 'DIY Motion Simulator Projects' started by Carelsbergh_Stijn, Jan 13, 2019.
  1. pmvcda
    15,396Coins
    Sorry, I don't understand.
    It doesn't move? Nothing?
    Do you see the 3D view moving?
  2. Carelsbergh_Stijn
    Carelsbergh_Stijn Member
    Belgium
    450Coins
    Yes, the 3D model moves, but I tought that when you were driving across a long straight road, it would slowly return to its Original position to get redy for a next turn in the course, but it doe't seem to do that, does it have something to do with filters?
    Cheers
  3. pmvcda
    15,396Coins
    Yes.
    Just for starting, you need to filter yaw.
    Use the last filter on the list. LP(LP(HP)).
    And set the left value to 40 and right one to 300.
    This is just for starting, you have to adjust them. They are new and I have not much experience with the recommended values.
    Those are the number of samples used to filter the signal for low pass and high pass.
    You can enable the graphic just for yaw and adjust the filter so the movement fit's your rig.
    Also don't forget to check rollover (should be by default).
    If you see the rig go out of range, for a fast adjustment, you can check the auto range on the actuators.
    This lowers gain automatically, each time the rig goes out of range.
    Uncheck later, or a simple crash makes the gain lower and lower and become completely unusable. Zero movement.
    Sorry for fast reply, but it's late here, need some sleep....
  4. Carelsbergh_Stijn
    Belgium
    450Coins
    I don't really get what you are saying, maybe it's simpler to send some pictures tomorrow? I will wait for your reply.
    Thanks for enerything!
    Cheers
  5. Carelsbergh_Stijn
    Belgium
    450Coins
    @pmvcda
    Can you please send a screenshot of the filter configuration please?
    Cheers
    Carelsbergh Stijn
  6. pmvcda
    15,396Coins
    s
    Sorry, forgot o send it to you. Give me 1h...
    I will post in the FlyPT interface thread.
  7. Carelsbergh_Stijn
    Belgium
    450Coins
  8. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi guys here is another video
    Hope you liked my project
    Subscribe to see my upcoming projects
    Cheers
    • Like Like x 5
  9. kunkurus
    kunkurus Member Gold Contributor
    Canada
    260Coins
    DC motor, 6DOF
    What do you use to control your BLDC motors (forward-reverse)?
    Thank you!
  10. hannibal
    hannibal Active Member
    4,491Coins
    looking amazingggg
    i have one question.. what is the angle that you make the chair frame?
  11. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi, I'm using 3 ODrive v3.6 56V motor controllers from ODrive robotics.
    Cheers
    Carelsbergh Stijn
  12. Carelsbergh_Stijn
    Belgium
    450Coins
    The tubes are bend 120°, first I wanted to do the same angle as my chair (±100°) but I knew that the more you bend the tube the worst the bend looks so I dicided to do it 120° because this also caused the bend to be close to the frame which looks kinda cool.
    Cheers
    Carelsbergh Stijn
  13. hannibal
    4,491Coins
    nice! i liked the way your sunken frame looks.
    what kind of tube material did you use?
  14. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi, the 'sunken' frame is because its now rotating around it's center of gravity so the motors are being less stressed. I used steel tubes ±∅35mm and a wall thinckness of ±3mm.
    Cheers
    Carelsbergh Stijn
  15. sagrada737
    sagrada737 New Member
    Retired from the computer industry
    Las Cruces, New Mexico USA
    247Coins
    Guten Tag Carelsbergh,
    Very nice project. I really appreciate the machining and welding you are doing with the motion platform and seat structure. Very nice work!
    Especially interesting is the use of "universal joints" for your actuators. Are these used on one end of the Actuator, with a Rod End on the other end?
    Mike
  16. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi
    I'm using them on top and bottom. ∅28mm just like the stainless steel tube.
    Cheers
    Carelsbergh Stijn
  17. sagrada737
    247Coins
    Hello Carelsbergh,
    Thank you for the comments on the universal joints for your project. I see now that you are using a Linear Actuator, so it makes sense to use such a coupling.
    Question: How much "noise" does the linear actuator make? I assume that it is Servo driven.
    Regards,
    Mike
  18. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,763Coins
    DC motor, 6DOF
    For high displacement platforms some users are using special bearing u-joints with 360 rotation ability.
    https://www.xsimulator.net/communit...l-joints-for-6dof-platform.13420/#post-180550
    Regards
  19. sagrada737
    247Coins
    Those are some very nice looking universal joints! If you don't mind sharing... Where did you purchase these? What are the mechanical specs?
  20. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    I would ask @Psionic001 in his thread.
