24V Motor controller recommendation
Discussion in 'Motor actuators and drivers' started by cnupa4ka, Mar 17, 2019.
  1. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    You can use your PSU. The question is, whether your PSU can handle regenerative current.
    What I'm saying, is that you cannot use resistors to dissipate the energy from braking. Most guys here use batteries for that purpose. You can also clamp some brakes to your motors.
  2. cnupa4ka
    cnupa4ka Member
    385Coins
    Here is my SPUs
  3. SilentChill
    20,598Coins
    Yes but you need a 12v car battery in parallell to get rid of the regenerated current from the motors.
  4. cnupa4ka
    cnupa4ka Member
    385Coins
    or better replace it with 2x32?!
  5. BlazinH
    16,676Coins
    Not better if you need the additional amperage the 2x60 provides.
  6. cnupa4ka
    cnupa4ka Member
    385Coins
    This is the motors I will use..
  7. BlazinH
    16,676Coins
    Also I just use a 100 watt power supply with no battery to run two 2x60's so a battery isn't always required.
  8. cnupa4ka
    cnupa4ka Member
    385Coins
    So what about in my case? How do u think?
  9. BlazinH
    16,676Coins
    A 2x32 should run those okay although they may peak over 32 amps at times.
  10. BlazinH
    16,676Coins
    Depends on rig design and how much regen it makes. Also depends on robustness of supply.
  11. cnupa4ka
    cnupa4ka Member
    385Coins
    I mean can i drive the motors with these power supplies without batteries?!
  12. cnupa4ka
    cnupa4ka Member
    385Coins
    What about if I use this circuit?
    Is the PSUs replace the charger for the batteries?
  13. cnupa4ka
    cnupa4ka Member
    385Coins
    Use of our motor drivers with cheap AC adapters is not recommended. Use a battery or at least put a battery in parallel with a DC supply.
    They say that for 2x60
    So that means I can use it with my PSUs but with battery in parallel to pick the regenerative current?
    If yes what battery size I need to put?
    The motors is 24V and I will use 2pcs PSU in series.
    Thanks!
  14. BlazinH
    16,676Coins
    Yes.
    One 24 volt or two 12 volt in series with a minimum of 25 amps hour for 2x32 and 35 amps hour for 2x60.
    Since your supplies aren't designed for charging batteries just be sure to disconnect them when not in use so you don't risk overcharging.
    152,971Coins
    +11,115 / 56 / -2
    Succinct and to the point, added to the Sabertooth section of the FAQs :thumbs
  16. cnupa4ka
    cnupa4ka Member
    385Coins
    Thanks mate for the nice reply!!! :)
    I will think what to do.. May I will change for 2x32..
