KartKraft Plugin 1.0.0.1
SimTools game plugin for KartKraft
  1. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,275Coins
    @yobuddy
    No, I'm sorry I don't have that info.
    If what you mean by "outputs", it's still UDP with IP 127.0.0.1 & PORT# 5000.
    I have only ever used your plugin with GameVibe support, as I don't have the original one.
    In Game Manager it's listed as "plugin by Keir / v0.0.0.0" (which is different than the original one posted earlier on May 10th which is v1.0.0.0).
    If you need someone to test an updated version of your GameVibe enabled plugin I'd be happy to do so.
    Your first one worked great up until the game update.
    Cheers!
  2. yobuddy
    50,750Coins
  3. Kranky Pantz
    Canada, Eh!
    1,275Coins
    @yobuddy
    Thank you....I've just tested it and it works perfectly now.
    Excellent work, as always!
    What an incredible community, and I never regret returning my Next Level Racing motion platform and going the DIY route with the help from the folks here.
    You are the best!!!!
    Cheers! :cheers
  4. yobuddy
    50,750Coins
    Fixed plugin with GameVibe
    (old file removed)
  5. Tifred07
    Tifred07 Member
    Design office engineer
    FRANCE
    270Coins
    Salut tout le monde.
    Je ne suis pas sure d'avoir bien compris, mais j'ai téléchargé le plug in en pièce attaché sur cette page.
    Cette version du plugIn ne prends pas en charge les mouvements ?
    J'étais pressé de monter sur mon simulateur ce soir pour tester sur kartkraft qui est devenu mon jeu favoris mais la je viens de redescendre sur terre... la douche froide :'(. Ce sera pas pour ce soir j'ai pas assez de points...
    En tout cas Chapeau pour les développeur du jeu. aucun jeu de kart ne m'a fait vibré comme celui là et en plus c'est très beau.
    Hi everybody.
    I'm not sure to understand but I download the plugin for Kartkraft in attached file from here.
    This plugin does not support movement?
    I was in a hurry to get on my simulator tonight to test on kartkraft which became my favorite game but I just come down on earth ... the cold shower :'( (<= only french expression ?) It will not be for tonight I have not enough coins...
    In any case congratulations to the developers of the game. No kart game has made me vibrated like this one and in addition it is very beautiful.
  6. Tifred07
    Tifred07 Member
    FRANCE
    270Coins
    @yobuddy.
    I don't know why, but i did not see your last post. I tried the last plugin but same results.
    I have activate the udp transmission in kartkraft but i don't have any movememt.
    I will test again tomorrow evening.
  7. yobuddy
    50,750Coins
    @Tifred07 Check your axis assignments for the game and also your min/max numbers.
    @Kranky Pantz has it working above, so it's probably something simple.
    Take care,
  8. Kranky Pantz
    Canada, Eh!
    1,275Coins
    Did you make sure to un-patch the game first in "Game Manager" to remove the old patch?
    That's what I did, and then dragged @yobuddy's new patch onto the "Plugin Manager", then finally re-activated the new plugin in "Game Manger".
    The only other thing I had to do was reverse the pitch axis (you may not need to do this) & finally tune with the "Tuning Center".
  9. Tifred07
    Tifred07 Member
    FRANCE
    270Coins
    My problem is that all the values stay equals to 0 when the game is running. The plugin is whell detected and the status is ok in simtools.
    I just replaced the old file by the new file.
    I will try to remove all files from simtools folder and repatch.
    Thank you for your answers
  10. yobuddy
    50,750Coins
    Where? in the tuning center?
  11. yobuddy
    50,750Coins
  12. Tifred07
    Tifred07 Member
    FRANCE
    270Coins
    Yes all values equal to 0 in the tuning center. No reaction.
  13. Tifred07
    Tifred07 Member
    FRANCE
    270Coins
    @Kranky Pantz
    Thanks you. I delete all files in simtools from appdata folder, I re-patch and everything works perfectly.
    Many thanks @yobuddy too.
    13th time on geel for national France ranking.. Only 115 in mondial ranking. I need to drive more :).
  14. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    Me too, I've no movement.
    The only version I installed is the last plugin , I use Simtools v2.4, in game telemetry is on, the plugin is whell detected and the status is ok in simtools, patch is ok, but all values equal to 0 in the tuning center .
    As Tifred, I delete all files in simtools from appdata folder, I re-patch but no reaction :(
  15. harwoodr
    harwoodr New Member
    441Coins
    Motion platform, 6DOF
    Tried this out today and got no output... I know my axis settings are good, as it works with No limits 2...
    I’ll play around with again tomorrow night and see if I can figure out if I’m doing something wrong.
  16. SeatTime
    Just tried it, works fine for me...
  17. Brandon Acree
    Brandon Acree efficientAF
    167Coins
    Hi Guys, I just tried to install the plugin but it failed saying that the KartKraft_GamePlugin was not a valid plugin when placed in the GamePlugins folder. Not quite sure what I'm doing wrong, any help would be appreciated.
    PS Sorry if this is a dumb question, everyone seems to have gotten further than this lol
  18. noorbeast
    151,467Coins
    +11,039 / 56 / -2
    Use the Plugin Updater to install the plugin: https://www.xsimulator.net/community/faq/how-to-install-plugins.310/
    The KartKraft plugin works fine for me.
  19. Brandon Acree
    167Coins
  20. FastBull
    FastBull New Member
    148Coins
    Hello, I am currently using Simtools and Simfeedback together with Kartkraft, but the two plugins use the same UDP 5000 port so I can only use one of the two software. Is there any way to change the listening port of Simtools to 5001 ?. Thank you
