News SimTools v2.4 Released!!
Discussion in 'News' started by yobuddy, Jun 25, 2019.
  1. Pit
    30,510Coins
    @yobuddy what the heck! First day on (my) holidays and finally I could find a spare time to ride on my rig, just testing the new 2.4 release, and what can I say - I am speechless! Motion has never been more accurate. 2.4. is a huge progress over all former versions. It is like an upgraded simulation platform to the next level. Thank you for your endless effort making SimTools better and better.
    hug:
    • Like Like x 6
  2. yobuddy
    51,542Coins
  3. Twisted
    Twisted New Member
    - 5Coins
    Huge thanks for the update youbuddy!
  4. PetroVitallini
    PetroVitallini Member Gold Contributor
    Norway
    248Coins
    My rig is currently not in use because of upgrades. Would you mind describe how or what feels better? I'm just so curious and my rig won't be complete again for a few weeks.
  5. Twisted
    Twisted New Member
    - 5Coins
    Wow!
    So you got update`s and UPDATE`S this is one of the second kind
    Motion is smoother and indeed more accurate.
    I have been driving over couple of honderd laps now with same car and track.
    Things i noticed was it feels like there are more "steps" in forces.
    There is a tricky turn and I spinned out nearly already over 100 time`s there.
    Now I had the same, but i shocked but was able to keep it.
    The interesting part of it , this felt exactly the same when i had it with outdoor karting.
    And that was one thing i thought I never was able to reach , but here you go thanks to you!
    Really this whole motion platform is more amazing then i initially thought off.
    Thanks again for your hard work!
  6. johnmiller85
    johnmiller85 New Member
    92Coins
    DC motor, AC motor
    Thank you. I need the latest version.
  7. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    After this installation, I experienced many good changes, this is an awesome update, thanks for that,
    But I do not understand one thing,
    During dirt rally 2 game - after a pause and restart - simtools stops 2 axes from 5, and the game engine's icon blinking blue.
    I must restart simtools game engine all the time after this situation,
    what could be the problem with this?
    please help me, what does blue blinking of icon means?
    153,920Coins
    +11,156 / 57 / -2
    Can you please post a picture of the icon that blinks blue, as I am not sure if it is game manager or something else.
  9. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    Yes, here they are
  10. Marc Lindgren
    Marc Lindgren New Member
    R & D
    Pennsylvania
    70Coins
    Is this update available for those of us that already have a Sim Tools license?
    153,920Coins
    +11,156 / 57 / -2
    Yes, just download and install v2.4...then enjoy!
  12. yobuddy
    51,542Coins
    This happens when you try to exit GameEngine and the sim still needs to center.
    It will blink blue till the centering is done and then exit.
    Take care!
  13. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Sorry for being a grump, but I wanted to ask couple of questions before I upgrade (as this is my first upgrade):
    * will all of my settings get migrated 1:1 from v 2.3?
    * what should I do if I would like to make sure I can go back to v 2.3 if I hit issues? I've Appdata stuff backed up already.
    I am running v2.3 and it works perfectly aside from a few nitpicks, but performance rework in the changelist sounds really exciting, as every CPU cycle saved is good :)
    Thanks!
  14. Marc Lindgren
    R & D
    Pennsylvania
    70Coins
    Looks like, according to Kranky, the answer to your first question is yes.
    153,920Coins
    +11,156 / 57 / -2
    Your settings should be fine, but a backup is a good idea. However the performant changes may mean that you do need to tweak your settings a bit to take full advantage of the changes and tune your rig accordingly.
  16. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Thanks, I pretty much only use Min/Max ranges in tuning center - as plugins did not change, I suppose old Min/Max values should be still valid, or do they need to be re-captured?
    Edit: upgrade went smoothly, thank you @yobuddy and everyone involved!
  17. Grizus
    Grizus Member Gold Contributor
    Warsaw PL
    349Coins
    Hi ! @yobuddy after upgrade to simtools 2.4 I have the same problem in Dirt 2.0 . When I start first stage everything is good, simulator works but when I choose restart stage, moves just cut off, nothing happens with my simulator...
    I also noticed that after restart stage in Dirt 2, centering flashing into infinity in simtools, does not return to game mode
    I also tested iracing and assetto corsa - everything works great here
  18. mingorri
    mingorri New Member
    35Coins
    Hello to all. Im using 2 scn5 at the back of a seat and i installed the new simtools and arent working correctly. Im getting mad.
    The seat works correctly.
    I have the same axis asigments in a and b axis.
    And in interface settings 1 assigned axis:0 to axis 1a and interface 2 assigment axis id 0 to axis
    I also modified surge max and min but nothing happened.
    Please can somone help me ,
  19. yobuddy
    51,542Coins
    Does the seat center when you start GameEngine?
    Have you used the seat with a older version of SimTools?
    Have you tried Output Testing and setup your default Axis Assignment profile?
    Let me know buddy, take care!
  20. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    @yobuddy
    I'm loving the new version so far, it works great.
    One thing I'm curious about is the proper setting for the new feature of gently moving the seat into the center position.
    Should the values/slider be set to low, or high?
    I've tried both and the seat still quickly re-centers either way.
    I'm using JRK's, if that matters.
    Thx
