Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    SimHub doesn't work. Should auto detect current game work?
  2. bruno1210
    bruno1210 schumi06
    103Coins
    did you activate 2017 f1 plugins with the correct port 20776?
  3. DoubleM
    Amsterdam
    - 23Coins
    Yes, I did
  4. DoubleM
    Amsterdam
    - 23Coins
  5. bruno1210
    bruno1210 schumi06
    103Coins
    parfait normalement ça marche! à la maison cela fonctionne, vous devez aussi lancer le jeu en dx11
    153,703Coins
  7. Deleted member 30486
    Hey Racers,
    I can't seem to get the motion working...
    Within Simtools game engine-output testing the DOF Reality P3 works fine.
    But within the game F1 2019 it does not respond.
    I run the game with DX11 and tried different options for telemetry...
    Did I miss anything?
    note: I patched the game.
    edit: I just noticed that within the simtools game manager - profile editor, the process name switches between: "F1_2019" and "F1_2019_dx12". Not sure what this means.
    153,703Coins
    The plug-in only works with dx 11.
    @yobuddy will review the plugin once he settles into his new home: https://www.xsimulator.net/community/threads/codemasters-f1-2019-plugin.13587/page-2#post-182940
  9. yobuddy
    51,518Coins
    It means it will launch when either process name available in the task manager.
    For now tho, only DX11 is up and running.
    Take care,
  10. Deleted member 30486
    Thanks, but I have the game running with DX11
    After removing the patch, completing a short race (5 laps) and patching the game again,
    the game now gives some kind of telemetry.
    But the motion behaves very strange. It constantly gives short shocks, even in the pit.
  11. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    you have to put telemetry on legacy
  12. alexdraco
    alexdraco Member
    278Coins
    Ciao De Castro,
    i'm following the discussion because I also have problems with F1 2019.
    What does "put telemetry on legacy" mean, how and where is this setting set?
    Grazie Ciao
  13. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    [QUOTE = "alexdraco, poste: 184048, membre: 30699"] Ciao De Castro,
    je suis la discussion parce que j'ai aussi des problèmes avec F1 2019.
    Que signifie « mettre la télémétrie sur l'héritage » signifie, comment et où est-ce paramètre est réglé?
    Grazie Ciao [/ QUOTE]
    In the telemetry settings of the game F1 2019
    Put UDP Format on Legacy.
    Start the game F1 2019 live 11.
  14. Coop
    Coop New Member
    England
    147Coins
    Can anyone tell me what the benefits of the DX12 version of the F1 2019 plugin will be when it is ready? (I'm aware of the frame rate benefits etc of DX12)
    I am going to download the current DX11 compatible plugin to use anyway for now but wondering if when the updated simtools plugin is released, will it have any effect on motion feedback etc.
  15. DoubleM
    Amsterdam
    - 23Coins
    V2.0.1.0
  16. DoubleM
    Amsterdam
    - 23Coins
    Port number is 20777
    153,703Coins
    Plugins that rely on the hook method, including all Codemaster games, will break the plugin whenever the game is updated, which for new titles could be pretty frequently.
  18. yobuddy
    51,518Coins
    Codemaster games are all udp based, but they seem to be adding a "hardware_settings_config_VR.xml" file to some newer titles.
    If they updated the game and motion stops working in VR, this could be the culprit.
    Be worth checking anyway, and is a pretty easy fix.
    Take care,
    153,703Coins
    Could you pleas post pictures of all of your settings, including the Tuning Center while the game is running.
  20. DoubleM
    Amsterdam
    - 23Coins
    Did you try it in DX11 UDP legacy mode?
