Generic unity plugin
Discussion in 'SimTools Plugins' started by narthur157, Dec 16, 2015.
  1. Aitor Perez
    Aitor Perez New Member
    108Coins
    Yes, I have licence and I installed my plugin and I can try my game in Game Selection.
    154,106Coins
    +11,169 / 57 / -2
  3. Aitor Perez
    108Coins
    Now the SimTools GameEngine don't open. I close to try another plugin but i try to open and don't succes. No window opens and is not in toolbar. :(
    I restar and reinstall SimTool and nothing.
    Thanks for reply to fast!
    154,106Coins
    +11,169 / 57 / -2
    Try temporarily turning off firewall and anti-virus, as it sounds like something is interfering.
  5. Aitor Perez
    108Coins
    I turn off an turn on an now works.
    I use @perdicheco tool and I can send information from SimTool Engine to tool and works.
    But when I try to catch the information and send from my game don't work. I cath the information whit UDPReciver but in SimTools Engine don't recive nothing.
    This is my code in Unity:
    And this is the plugin:
    I upload .rar of plugin if necessary.
    Thank so much :)
  6. Aitor Perez
    108Coins
    I have continued trying to receive the information whit the plugin but I can't receive nothing in SimTools Engine. I have the same problem at my last post.
    I don't know what is wrong in the plugin. I set it wrong?
    I need to do something more?
    Tanks :)
    154,106Coins
    +11,169 / 57 / -2
    If I recall the port used in the Quplay demo is 4123, so try that in your interface settings.
  8. Aitor Perez
    108Coins
    I try to shitch port but it didn't work. Yesterday I got data to come out in Tuning Center / Game Data -Input and the 2DOF Vistual Sim and it receive the data successfully.
    Now I try to do the same but it didn't works, I don't undestand why. I only just made a plugin for other Game, and occasionally i have this problem https://www.xsimulator.net/community/threads/simtools-v2-4-released.13545/page-3#post-183918 I turn off the computer and sometimes it works and sometimes it doesn't.
    The only change i do before it worked is add a max and min in Roll and Pitch in Tuning Center, but it now didn't works.
    I'm super lost :(
    If anyone knows what happens please explain it to me.
    Thanks!
  9. yobuddy
    51,580Coins
    How are you installing you custom plugin buddy?
    You need to use the plugin updater or the properties of the plugin may get locked.
    Simply re-installing you custom plugin with the plugin updater will fix it if needed.
    Also, make sure you have some interface output.
    For testing purposes, select the Network output option, and then assign some Axis outputs.
    If you are using the (a) axis assignments, then assign "<Axis1a><Axis2a><Axis3a><Axis4a><Axis5a><Axis6a>" for interface output.
    Let me know how it goes buddy,
    Take care,
  10. Aitor Perez
    108Coins
    After doing a lot of test and I found that. If I use a client to see if I send the data well by udp, in Game Engine I don't recieve nothing. When I unisntall and install and testing whitout opening the udp client I recive data.
    Thanks for reply :)
  11. yobuddy
    51,580Coins
    Yes, you can only have one receiver going at a time buddy.
    Great job of working thru the problem!
    Take care,
  12. Snorch
    Snorch New Member
    - 13Coins
    Hey! This topic is amazing, I could get the QuSimTools plugin to work with my game on Unity.
    I just needed to modify the code a bit to avoid decimal separation problems with different localisations. (In Spanish decimal number separate with commas instead of dots).
    Thank you!
  13. Pitchoun511
    Pitchoun511 Member Gold Contributor
    Perpignan
    387Coins
    I’m trying to use Claudio Silva POC, and I’m unable to use it too. When I do a ncat on 4123 port, I see all the informations I try to send to my rig, I use claudio’s plugin but, my rig doesn’t move. can you tel me what you have done?!!
  14. Pitchoun511
    Perpignan
    387Coins
    Hi everybody
    I tryed again a lot of things, I think I'm not so far from the solution, but I can't get my rig to move... Not realy my rig, I try with The virtual sim. I have built the QuPlay.exe with unity and I think it works, because when I launch "ncat.exe -l -u 4123" I can see the values I send.
    I generated the claudio's plugin without change anythink. I import it in simtools, and I patch the game
    Now I start Virtual sim and I launch QuPlay.exe. Virtual sim start a right line, but never show the values I send from QuPlay.exe...
    Will you help me please. I think my error is the plugin but I can't repare it.
    Thank you for reading.
    154,106Coins
    +11,169 / 57 / -2
    Perhaps you could post your code and project, that way @yobuddy or someone else could have a look at it, in their spare time.
  16. Pitchoun511
    Perpignan
    387Coins
    OK, I understand.
    I'm just trying to use Claudio silva's tutorial. I think the unity's part is OK. It sends frame by UDP to 127.0.0.1 on the port 4123.
    But I can't create a functional plugin.
    The code is this one :
    https://github.com/ddkclaudio/QuplaySimTools/blob/master/SimToolsGamePlugin/GamePlugin/GamePlugin.vb
    I open GamePlugin.sln in visual studio 2017, and I generate the project. Then I have, in /bin/debug directory a file named QuPlay_gameplugin.dll, I drag and drop this file in simtools update plugin, and I hope that it's going to work fine... but not... it doesn't work.
  17. Pitchoun511
    Perpignan
    387Coins
    @yobuddy can you show me the function
    Public Sub Process_PacketRecieved(Text As String)
    of the Video ride player's plugin. I think I can make the same frame that wait this plugin.
    I don't konw how to debug the plugin I made. Is there a process to do that?
    Thx.
  18. rafalmrok2
    rafalmrok2 New Member
    - 79Coins
    3DOF, Arduino, Motion platform, 4DOF
    Hi, will this plugin work for anyone running UE5.2 or later? Has anyone tried modifying it for the later
    engine?
