SimTools v2 - Video Ride Recorder 2.1
Make instantly ride-able RideFilms
  1. yobuddy
    51,557Coins
    "In 57 seconds there are 57000 miliseconds which means divided..."
    The 16ms is the pause time between sending packets.
    It does not account for the time it takes to actually send the data.
    You can edit them with v2.4 of simtools i believe.
    Hope that makes sense buddy!
    take care,
  2. Metaverum
    Metaverum Member Gold Contributor
    146Coins
    2DOF, 3DOF
    I just wrote my own recorder from inside of Unreal Engine. I am recording the current telemetry data every 16 milliseconds, ran a small test, 10 seconds of recording, and it ended up as 625 lines of telemetry, which is correct.
    I figured out I could write my video player inside of Unreal as well, and use the same plugin from Claudio to read the telemetry data back from text file and send to SimTools.. no coding needed. :)
    I will report my results soon. :)
  3. Nagy Csaba
    Nagy Csaba New Member
    18Coins
    3DOF, DC motor, SimforceGT, Motion platform, 6DOF
    Hello
    I would like to ask if the settings shown in the 2 attached pictures must be done in order for the Recorder to work?
    Because I don't have a Network interface in Simtools Game Engine.
    (I have a SimTools Professional License)
  4. yobuddy
    51,557Coins
    Yes, it needs to be setup to work correctly.
    Take care!
  5. Nagy Csaba
    18Coins
    Hello
    Thanks for the reply.
    Could you tell me why the "Network" option disappeared from the interface list after purchasing the license?
    (There was also Network before purchase.)
  6. yobuddy
    51,557Coins
    The Network interface in SimTools v2 is built in, and should just need to be selected and setup.
    With SimTools v3, you will need to install the interface plugin from the plugin manager.
    Hope this helps buddy!
  7. Nagy Csaba
    18Coins
    Reinstallation solved the problem. Thanks for the help!
  8. peter stolmeier
    peter stolmeier Member
    558Coins
    I'm ready to start recording my own telemetry. Just to make sure, I have to roll back to simtools 2 to use the recorder, yeah?
    153,986Coins
    +11,162 / 57 / -2
    @yobuddy is best placed to advise, when he gets to grab a spare moment!
  10. yobuddy
    51,557Coins
    It should work with v3 without problems.
    Please let me know how it goes.
    Take care :thumbs
  11. peter stolmeier
    558Coins
    I attempted it today without success. I see this screen shot about how to configure it, but my system uses a different kind of controller. Is that what might be stopping it?
  12. yobuddy
    51,557Coins
    You need to setup the network interface in SimTools, as it sends the data to the recorder app, not the sim.
    You can simply add the network plugin as Interface #2 if your normal interface for you sim uses interface #1.
    Hope that makes sense buddy?
  13. peter stolmeier
    558Coins
    Yeah, i was able to add the network interface as 2 but the recorder still doesn't' see any telem.
    I'm wondering if I have the ip address right. the example says 172.0.0.1 but shouldn't it be 192.168.ect ect? Same question for the port.
    I also wonder about the interface output. I have a three pylon system so I named them for ease. Should I change what's in output?
    I tried renaming them back to Axis1a / Axis1b but no data yet.
    I know I'm close, this is going to be one of those "oooh duh" things.
  14. peter stolmeier
    558Coins
    I had to replace my PC and reinstall everything so I'm finally circling back around to this part of the project. I'm still trying to get the recorder to see the telm coming from simtools. I've set them up as you see in the post just about this one with no success. Are there maybe setting inside the recorder I don't know?
