Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. yobuddy
    51,353Coins
    Can you post the text file buddy?
    thx!
  2. kastiel
    kastiel New Member Gold Contributor
    - 240Coins
    Sorry I'm French I'm not understood
  3. Piotr Janta
    Piotr Janta New Member
    Poland
    18Coins
    2DOF, SCN6
    You need to add line in hardware_settings_config_VR.xml under montion section.
    Its working with my monition platform and Pimax 5k
    <udp enabled="true" extradata="3" ip="192.168.x.x" port="4123" delay="1" />
    X=your PC Lan IP
  4. yobuddy
    51,353Coins
    @Piotr Janta,
    I can have the plugin also edit this file automatically, could you post the file?
    Thanks!
  5. Piotr Janta
    Poland
    18Coins
    2DOF, SCN6
    The uploaded file does not have an allowed extension.
  6. Piotr Janta
    Poland
    18Coins
    2DOF, SCN6
    please change .txt for xml
  7. yobuddy
    51,353Coins
  8. yobuddy
    51,353Coins
    Someone what to give this VR fix a try?
    All you need to do is install the new plugin, then unpatch and repatch the game.
    (Plugin now officially posted!) :thumbs
  9. kastiel
    - 240Coins
    its function for me thank you
    good work
  10. yobuddy
    51,353Coins
  11. Arielnac
    Arielnac Member
    Argentina
    240Coins
  12. kastiel
    - 240Coins
    heave and sway of seems not work, can someone confirm?
  13. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    What this updated plugin do? It just edits "hardwaresettings_vr"?
    Btw yesterday i made it work even with old plugin, clean reinstall of windows and editing "hardwaresettings_vr" helped:)
  14. kastiel
    - 240Coins
    hi martyn. is the heave and the sway working for you?
  15. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Not sure atm cause i was really just quick testing if the motion works after the pausing / unpausing the game, will let you know:)
  16. yobuddy
    51,353Coins
    Yes, it also edits this new file buddy.
    Take care!
  17. getupaaa
    getupaaa New Member Gold Contributor
    114Coins
    Bonjour Monsieur Youbuddy
    Merci pour vos
    excellents travaux.
    J'ai remplacé mon disque dur par 1 SSD et installé la version "simtools 2.4" et depuis j'ai quelques soucis. Par exemple quand je recommence 1 spéciale dans Dirt rally 2.0, les mouvements sont presque inexistants. Si je ferme les jeux d'achat "Game Engine" clignote bleu!
    (j'ai essayé de me renseigner sur les forums mais j'ai encore rien trouvé d'utile !!)
    Autre soucis, quand je joue à "Dirt 4", les mouvements sont à peine perceptibles. Pensez-vous que c'est en rapport avec la version 2.4 de "Simtools"?
    D'avance merci ...
    Cdt .... getupaaa
  18. value1
    14,174Coins
    Please check your MaxMin settings in GameEngine/TuningCenter. It sounds like these values are too high. Remember: the lower the MaxMin settings, the stronger the movements!
    See here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Hi, thanks Yobuddy for the plug in .. nice work
    I have a problem ... I start a track and the movement works, the following track does not, movment goes off. I noticed that even if I change the parameters on the steering wheel, fanatec dd1 and hub, the movement turns off. I am using Sim commander or Sim hub, oculus rift S.
    I notice Game Engine start to pulse in blu and i have to restart STools
    Maybe have to modify Hconfig file??
    TY
    Buongiorno, Yobuddy e grazie mille per il plug in..
    Riscontro uno problema..Inizio un tracciato e il movimento funziona, il seguente tracciato no, si spegne. Ho notato che anche se modifico dei parametri sul volante, fanatec dd1, si spegne.
    utilizzo sim commander or sim hub, oculus rift s e appunto il dd1.
    Ho notato che il game engine lampeggia e devo riavviare ST
  20. getupaaa
    114Coins
    Bon, j'ai diminué les forces appliquées aux axes et cela a pour effet de terminer le parcours (spéciale de rallye) en entier. Mais si je veux arrêter et recommencer le parcours depuis le départ alors les mouvements du simulateur deviennent imperceptibles !!
