Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. getupaaa
    getupaaa New Member Gold Contributor
    114Coins
    152,640Coins
    +11,088 / 56 / -2
  3. yobuddy
    51,231Coins
    The blue centering is normal if you have centering on.
    The game not restarting, is not, and it being investigated.
    (Although it works for some people just fine)
    Could I see your interface settings please?
    Thanks,
  4. kastiel
    kastiel New Member Gold Contributor
    - 230Coins
    hello, I have the same problem as them
    and I'm not "heave", the value displayed in tuning center is NA (heave)
    152,640Coins
    +11,088 / 56 / -2
    Please post pictures of your Axis Assignments and also of the Tuning Center while the game is running in a stage.
  6. kastiel
    - 230Coins
    simulator in motion but no heave
    [​IMG] [​IMG] [​IMG] :)
    second race, no movement[​IMG]
  7. yobuddy
    51,231Coins
    @kastiel,
    What version are you running buddy?
  8. kastiel
    - 230Coins
    simtool 2.4
  9. yobuddy
    51,231Coins
    Are you running the newest plugin for the game?
    I don't seem to get that here.
    I know there is some test plugins for the game floating around is why I ask buddy.
  10. kastiel
    - 230Coins
    I downloaded the latest version
    when you have made the update for it to work vr
    j'ai télécharger la dernière version
    quand vous avez fait la mise a jour pour qu'il marche en vr
  11. yobuddy
    51,231Coins
    Did you unpatch and repatch the game?
  12. kastiel
    - 230Coins
  13. noorbeast
    152,640Coins
    +11,088 / 56 / -2
    Did you try unpatching, run a race, then repatch?
  14. kastiel
    - 230Coins
    yes I tried all the classic procedures ...
    software like fpsvr would pose problemme?
    152,640Coins
    +11,088 / 56 / -2
    Any program that could interfere with either the installation of the plugin, like antivirus, or messes with the game while running could be an issue, but I am not sure about fpsvr specifically.
  16. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    I also have problems since the last update that Codemasters did. The movement only works one stage and then stops working. Nor can I run Simhub and Simtools at the same time. Change version 2.3 to version 2.4 and do the same. In the rest of the games everything is going well, I even have to say that after updating to version 2.4 the movements have improved, congratulations, but here in Dirt Rally it does not work correctly, it is as if I did not finish recording the changes in the file game settings Greetings. (I use Google Translator)
    Yo también tengo problemas desde la última actualización que hizo Codemasters. El movimiento sólo funciona una etapa y luego deja de funcionar. Tampoco puedo hacer funcionar Simhub y Simtools a la vez. Cambien la versión 2.3 a la versión 2.4 y hace lo mismo. En el resto de juegos todo va bien, incluso tengo que decir que tras actualizar a la versión 2.4 los movimientos han mejorado, felicidades, pero aquí en Dirt Rally no me funciona correctamente, es como si no terminara de grabar los cambios en el archivo de configuración del juego. Un saludo. (Utilizo traductor Google)
  17. Tim Palmgren
    Tim Palmgren Maker / Motion Fanatic
    IT Recruiter
    Auckland, New Zealand
    82Coins
    3DOF, Motion platform, 4DOF
    I am also running DR2 in VR and having same issues. Even if I pause during a stage I often will lose the movement, if I change focus outside of the application (whether DR2 is windowed, borderless or full screen) I also lose motion.
    Something that I didn't see reported is that the mouse works inside of the DR2 UI initially but later disappears, often if you change focus and resume. SO I wonder if that might be related, like there is something that happens that disrupts the mouse from working which also prevents the telemetry from going into simtools.
    THe other possibility is this 'NA' reading inside the heave telemetry. I am noticing this on mine also and I think this is what causes the flashing blue recentering issue (resolved by decreasing shutdown/centering to off and back again). The heave telemetry definitely is sending values as I have tested it to make sure but when it outputs NA maybe that breaks something...
  18. kazkazkaz
    kazkazkaz New Member Gold Contributor
    Japan
    59Coins
    Hi,I also have a problem with DR2 now.
    My motion rig works well with other games like RBR,PCars2.
    The rig stopped working after the same update and I tried to put the value "2" into the "delay" option in a hardware setting file.
    After that the rig started working but 2 of 4 axis suddenly stop moving in a few seconds just after the race has started.
    Hope this helps some for a investigation.
  19. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    I have disable centering and now there s not blu blinking, and its better, but the problem remane..motion stop after pause...When i press esc go go in the menu axis return to the center instantly..
    My configuration to find some analogies?...
    I have steam version and oculus version but do the same problem
    oculus rift s
    1080ti
    intel 6700
    dd1 fanatec with fanatec hub
  20. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Has anyone found a solution? At the moment I am still without movement in this game, in all other perfect games. Greetings. (I use the Google translator)
    ¿Alguien ha encontrado una solución? De momento sigo sin movimiento en este juego, en todos los demás juegos perfecto. Un saludo. (Utilizo el traductor Google)
