Yobuddy’s ~EZ~ Series Layouts!
Discussion in 'SimTools compatible interfaces' started by yobuddy, Jan 18, 2012.
  1. yobuddy
    51,530Coins
    Even if you don't speak Dutch, hit the ThankPost button for floriske!
    Thanks a lot buddy!
    @Igorhr
    I only changed the layout, if it worked with the original AMC it will work for sure!
    Please post your connection in a new thread, I would like to see it, sounds like others could use it too.
    And save some doh on a serial converter!
  2. igorhr
    igorhr New Member
    computer technician
    Zagreb, Croatia
    405Coins
    I dont know on what connection you mind...I was make some sketch
    how I was connect AMC board with my motherboard and simulator .
    All work OK and KP settings with terminal also work OK
    For programming ATmega I use standard serial cable.
    I did not try use similarly solution with other DB9 programming port, but
    once is ATMEGA is programmed, you dont need that port....
    My intend is to put AMC board and Hbride in my PC case.
    So, I was disassemble tree old CDs and I will install inside AMC borad, h-bridhe and
    on a top two FANs and that is reason why I was looking for a solution
    to make all connections simplify
    regards
    igor
  3. yobuddy
    51,530Coins
    @ igorhr
    Please note, that you are using the max232 circuit on the original AMC.
    This is not on the ~EZ~ version, instead it uses a serial to usb adapter.
    You could build the max232 circuit on a separate board if you wanted to, and attach it all like in the pic.
    But it would be al lot easier to use the converter.
  4. dualin
    dualin Member
    Cáceres - Spain
    - 41Coins
  5. yobuddy
    51,530Coins
    Hi dualin,
    I don't seem to see the manual for this H-Bridge.
    If you can find and post a link to the H-Bridge manual i will look it over for you. :cheers:
    Dustin
  6. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Happy day, I will be building many of the pwm to analog EZ boards. Please post dimensions for the PCB. Blessing to all, John
  7. yobuddy
    51,530Coins
    Hi @MagicEdge The dimensions are in the PDF layout.
    the print is to size. :thumbs
  8. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Yobuddy, when printed at 100% the pcb is tiny. No way a 1/4 watt resistor would fit. At 150 % it may work. Please, could someone give actual size?
  9. yobuddy
    51,530Coins
  10. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Thanks yobuddy, All worked out and ready to transfer to clad boards for etching.
  11. yobuddy
    51,530Coins
  12. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Before etching starts, is there a pwm to analog shield for arduino out there? Just want a clean install.
  13. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    20140322_174742.jpg 20140322_174742.jpg Pretty picture
  14. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Yobuddy, Is there a circuit schematic for the pwm analog EZ available? I have sinister plans.
  15. yobuddy
    51,530Coins
    @MagicEdge , just the layout sorry buddy.
    I do have a all in one VFD add-on PCB from speed's design I'm working on too.
    Should be done soon.
  16. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Ok Yobuddy, Certainly will be watching for your post.
  17. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Great work, now i can use the old AMC1.5 controller that's laying arround beeing useless.:thumbs :grin
  18. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Guys,I see the pwm wires here connecting to the pwm to analogue convertor,but where are the direction wires?
  19. yobuddy
    51,530Coins
    @Llewelyn,
    0v up to 5v left, 5v center, above 5v to 10v is right.
    Take care,
  20. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Okay thanks,so that means the direction wires from the arduino are not needed,just the pwm wire connected to the PWM to analogue convertor and that causes changes in direction from voltage changes 0-10v.
