Hannibal's thread into DIY motion platform
Discussion in 'DIY Motion Simulator Projects' started by hannibal, Feb 15, 2019.
  1. hannibal
    hannibal Active Member
    4,492Coins
    finally dealing with e poxy..
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    The joy and absolute terror of commit to a final design.
    You'll get through. Just go on.
  3. hannibal
    4,492Coins
    thanks for support @Pierre Lalancette :)
    currently finalizing anti wobble ring and following this SMC3 for sabertooth...
    so much work.. i really hope after months of work.. this really works... im so close to testing out one actuator..
    i never made a prototype.. i just dived in making a complete version...
  4. hannibal
    4,492Coins
    i found my answer in sixdegreeofflight video!
  5. hannibal
    4,492Coins
    anti woble and more epoxy work
  6. hannibal
    4,492Coins
    not to shabby..
  7. hannibal
    4,492Coins
    my elaborate epoxy jig..
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    Your tubes are... Sexy.
    • Funny Funny x 2
  9. hannibal
    4,492Coins
    feeling accomplished. after 8 months i managed to assemble one actuator..
    • Like Like x 7
  10. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    The potentiometer setup looks really good.
    Keep on the good work!
  11. hannibal
    4,492Coins
    my actuators were alive today!
    i saw them work!
    i got them to go up and down with the SMC3 utility.
    i just have to get the simtools and LFS test working.
    to be continued..
    very excited!
    • Winner Winner x 4
  12. hannibal
    4,492Coins
    cant seem to get telemetry to show up from LFS on the tuning center...
    when i move actuators with the output testing, it is ok... just cant get any values from the LFS!
    help? :/
  13. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Did you run a race in first person mode before patching, as that generates some required files.
    If not then unpatch LFS, shutdown SimTools, run a race in first person mode then repatch.
  14. hannibal
    4,492Coins
    thank you @noorbeast .. i just went straight to the game. ill give it a try..
    also posting a photo or two..
  15. hannibal
    4,492Coins
    it works... did a quick test of running the actuators with simtools and LFS...
    i feel good!!! :D:D:D:D:D
    again, many thanks to everyone here, especially @wannabeaflyer2 @SixDegreesOfFlight @noorbeast @Pierre Lalancette @SilentChill @pmvcda
    i still dont believe i haz built actuators and being on my way to 6 dof...
    @SixDegreesOfFlight ARE YOU BACKKKKKKKK WHOLEY COW WELCOME BACK... your videos and post got gave me the knowledge to participate in 6 dof world.. i cant say thank you enough for all the info you provided.
  16. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    Nice pictures. So well organized and labeled.
    The step where everythings start to move to a game, you are getting there.
    Well done!
  17. hannibal
    4,492Coins
  18. hannibal
    4,492Coins
    My project is now set back :(
    i come to see that my bottom frame may have the wrong dimensions.
    when i prop up my actuators, i see that at when my actuators are at bottom height, i get 60 degrees between acuators at the heim joints.
    it was suggest that it should be at 60 degrees when the actuators are at middle position
    i tried to make heads and tails when using @pmvcda 's hexapod diagram and silentchill gave me some thoughts..
    but to sum it up in a picture, this is what i understand to be the main dimension of the bottom platform..
    need thoughts.. @wannabeaflyer2 @Flymen @Pierre Lalancette @SilentChill
    thank you!
  19. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hi ,
    See dimentions from FlyPT Hexapod If you are going to measure in the rig, it's easier specifying the dimensions (L1 to L4).
    Look at figures to guide you.
    Remember, those measures should be made between the center of rotation of the joints.
    My mine are : L1= 1240 , L2= 125 , L3 = 180 , L4 1220 ,
    Middle : 1170 and range 210
    Each arms have about 60 degrees at middle position .
  20. hannibal
    4,492Coins
    i studied your picture during the summer..
    i thought i knew what i was looking at, apparently not lol
    i tried to match silent chill's, sixdegreeofflight dimension, thinking i couldnt go wrong.. but i was wrong
    as you mention, 60 degrees at middle position is key. thanks.. @Flymen !
